wildcat_paris Posted November 21, 2015 Posted November 21, 2015 (edited) Hello, FYI for prospective on Odroid XU4, testing images for XU4 (I also have a Cloushell (mini NAS including LCD display)) desktop image link folder Ubuntu 14.04.1 : ok, upgrade to 14.04.3 ok, upgrade to kernel 3.10.92 ok, upgrade to odroid final kernel 4.2.0 DEAD Ubuntu 15.04 : DEAD after reboot (kernel 4.2.0) It seems the image with kernel 4.2.0 just removed "journal" feature of ext4 on startup, so at next reboot, the ext4 fs is dead. trying to fix the SD card on a amd86 Ubuntu gives error like "/usr/sbin" dead, filesystem is garbage server image link ubuntu server image is not usable, dead after first reboot (kernel 4.2 ?) archlinux image using kernel 4.2 3.10.92 (existing 4.3/4.4-rc1 general kernel - untested) pretty ok after rebooting. Only drawback, everything is to be installed, I don't know much of archlinux tools. edit : Do not install odroid-cloudshell package, it really breaks the filesystem after reboot. edit2: in fact, kernel 3.10.92 make the ethernet interface (USB=>ETH) no longer working. It seems the drivers is "closed" sourced edit3: looking at images maybe edit4: ArchlinuxArm seems stable, kernel is old. but image is fine after reboots over and over. pacman is pretty cool! Edited November 25, 2015 by wildcat_paris
wildcat_paris Posted November 27, 2015 Author Posted November 27, 2015 quick update (2015/11/27) the Odroid XU4 is running Archlinux ARM as for now with kernel 3.10.92 (ok it is creepy) more ARM generic 4.2/4.3/4.4-rc2 are online, won't test it so far, testing what I can get of the hardware. The XU4 is able to compile thunderbird 38.4.0 with lightning (with ccache) on a SSD, quite powerful. 1
wildcat_paris Posted December 12, 2015 Author Posted December 12, 2015 FYI switch back a while from a 15.04 hardkernel rootfs, upgraded to Ubuntu 15.10 gr@odroid:~$ cat /proc/version Linux version 3.10.92 (root@xu-b1) (gcc version 4.6.4 (Ubuntu/Linaro 4.6.4-6ubuntu2) ) #1 SMP PREEMPT Tue Nov 17 00:15:24 BRST 2015 Got my 32GB eMMC module, cloudshell (nas) working (cloudshell screen not tested so far) + a separate SD card let me boot to make a backup of the eMMC Stable let's see odroid)#enabled #description Exynos5422 XU3/XU4 octa core #build 3wip LINUXFAMILY="odroid" BOOTSIZE="16" BOOTCONFIG="odroid_config" MODULES="ethernet wlan_8723bs bonding" MODULES_NEXT=""
Igor Posted December 12, 2015 Posted December 12, 2015 I made one image but I don't know why is not booting. I have to construct level convert to be able to use a normal serial console. I forgot the fact it uses different voltage logic. You have serial console?
wildcat_paris Posted December 12, 2015 Author Posted December 12, 2015 (edited) Igor, Nope. I did not get the cable to have the serial console, my bad. Considering they send from UK with Fedex... and Fedex has been a PITA for xu4 and cloudshell, I have ordered the eMMC module from Hardkernel directly (UPS which is better at delivering but paid VAT TAX toll from South Korea to France) forgetting to order the cable as well... :-( edit: I mean this "cable" http://www.hardkernel.com/main/products/prdt_info.php?g_code=G134111883934 looking for something compatible, odroid needs 1.8V logic not 3.3V+ I might order this cable for 6€ http://www.amazon.fr/gp/cdp/member-reviews/AF3948B6XWFHI/ref=pdp_new(sorry in French) One comment mentions using it with Odroid + Mac, adding do not connect the VCC red cable, it might break your card By spec, PL2303HX can handle 1.8V depending on the implementation (some only do 3.3v+) => too risky... EDIT ordered hardkernel cable in South Korea (10 USD + 16 USD for shipment + toll fees if any), with odroid.co.uk it's 15€ + 22€ shipment Edited December 16, 2015 by wildcat_paris
Igor Posted December 23, 2015 Posted December 23, 2015 While waiting for my cable to arrive ... http://mirror.igorpecovnik.com/test/Armbian_5.00_Odroid_Debian_wheezy_3.10.93.zip this is the image which should by the theory work but it doesn't.
wildcat_paris Posted December 24, 2015 Author Posted December 24, 2015 @Igor it seems the image boot / reboot I have tried SSH (then the session stops) login as: root root@192.168.1.15's password: Access denied root@192.168.1.15's password: Access denied root@192.168.1.15's password: Access denied root@192.168.1.15's password: Access denied root@192.168.1.15's password: Server refused to set environment variables You are required to change your password immediately (root enforced) Welcome to ARMBIAN (Debian wheezy 3.10.93-odroid) Changing password for root. (current) UNIX password:
Igor Posted December 25, 2015 Posted December 25, 2015 I guess there was something wrong with my previous build. This is working fine with me so we have first official Armbian build: http://www.armbian.com/odroid-xu4/ Thank you for assistance. 1
