crosser Posted September 1, 2024 Posted September 1, 2024 I found my Helis64 unresponsive after about a week or so. Even heartbeat LED is not blinking (permanently on). I see this repeating on the serial console [495778.879711] rcu: rcu_preempt kthread timer wakeup didn't happen for 5324533 jiffies! g9706925 f0x2 RCU_GP_WAIT_FQS(5) ->state=0x200 [495778.880747] rcu: Possible timer handling issue on cpu=3 timer-softirq=2513452 [495778.881383] rcu: rcu_preempt kthread starved for 5324534 jiffies! g9706925 f0x2 RCU_GP_WAIT_FQS(5) ->state=0x200 ->cpu=3 [495778.882336] rcu: Unless rcu_preempt kthread gets sufficient CPU time, OOM is now expected behavior. [495778.883137] rcu: RCU grace-period kthread stack dump: [495778.883584] task:rcu_preempt state:R stack:0 pid:16 tgid:16 ppid:2 flags:0x00000008 [495778.884404] Call trace: [495778.884627] __switch_to+0xe0/0x124 [495778.884946] __schedule+0x308/0xa8c [495778.885263] schedule+0x34/0xf8 [495778.885549] schedule_timeout+0x98/0x1bc [495778.885902] rcu_gp_fqs_loop+0x150/0x670 [495778.886256] rcu_gp_kthread+0x234/0x274 [495778.886603] kthread+0x114/0x118 [495778.886896] ret_from_fork+0x10/0x20 [495778.887219] rcu: Stack dump where RCU GP kthread last ran: [495778.887705] Sending NMI from CPU 4 to CPUs 3: Aside from usual NFS server (unused at the time) and syncthing, it was running duplicity backup at the time. I cannot rule out that it ran out of memory. Though it did run full backup successfully a couple of days ago. helios64-rcu-stall.txt 0 Quote
prahal Posted September 5, 2024 Posted September 5, 2024 I guess this is one core not responding anymore, likely CPU 5 (one of the big cores). Which kernel do you run? Is this the first time you encounter this bug? You might want to run ebin-dev dtb (there are voltage hacks for the big CPUs in it). 0 Quote
crosser Posted September 15, 2024 Author Posted September 15, 2024 Edge from the deb package (6.8.11-edge-rockchip64). It was the first time; this Saturday I got a similar situation, _but_ I was able to ssh (after minutes of waiting) and save syslog. The first anomaly in the log was (this time): Sep 14 22:11:52 kobol kernel: BUG: Bad page state in process kcompactd0 pfn:1e320 Sep 14 22:11:52 kobol kernel: page:000000001709b832 refcount:0 mapcount:0 mapping:000000004953ae39 index:0x4c1a1c30 pfn:0x1e320 Sep 14 22:11:52 kobol kernel: aops:0xffff800081149ed8 ino:1 Sep 14 22:11:52 kobol kernel: flags: 0xffff1800000020c(referenced|uptodate|workingset|node=0|zone=0|lastcpupid=0xffff) Sep 14 22:11:52 kobol kernel: page_type: 0xffffffff() Sep 14 22:11:52 kobol kernel: raw: 0ffff1800000020c dead000000000100 dead000000000122 ffff0000009e8338 Sep 14 22:11:52 kobol kernel: raw: 000000004c1a1c30 0000000000000000 00000000ffffffff 0000000000000000 Sep 14 22:11:52 kobol kernel: page dumped because: non-NULL mapping and later there are repeated "rcu: INFO: rcu_preempt detected stalls on CPUs/tasks ..." (see attached file). I will try that other dtb, thanks! rcu-stall.txt 0 Quote
Trillien Posted November 21, 2024 Posted November 21, 2024 Hi, For info I had the same issue running OMV 6.0 with PhotoPrism. It seemed PhotoPrism consumes a lot of CPU to compute the pictures. And at a point (between a quarter and two hours), Helios64 failed with rcu_preempt detected stalls on CPUs error. This error was probably linked to the jump between frequencies : I solved it by limiting the max frequency on biggest cores at 1200 MHz. Note that was before Prahal's DTB to increase cpu voltage. 0 Quote
prahal Posted December 11, 2024 Posted December 11, 2024 @crosser was it stable with the other dtb? 0 Quote
crosser Posted January 28, 2025 Author Posted January 28, 2025 @prahal sorry for dropping off. I was too lazy to build the needed version of the kernel, and before long, a new edge release came out, and the device was rock solid since then. Knock on wood. (As a side note, I _do_ have a real problem with the hardware: after some research I figured that one of the two disk power circuits has gone bad, so now I have two disks (and SSD) working, and three slots empty.) crosser@kobol:~$ uname -a Linux kobol 6.12.1-edge-rockchip64 #1 SMP PREEMPT Fri Nov 22 14:30:26 UTC 2024 aarch64 aarch64 aarch64 GNU/Linux crosser@kobol:~$ uptime 20:32:31 up 56 days, 12 min, 1 user, load average: 0.04, 0.05, 0.00 (last reboot to upgrade the kernel, no crashes for quite a while) 0 Quote
prahal Posted January 29, 2025 Posted January 29, 2025 @crosser thanks for the feedback. By new edge release stable you mean vanilla armbian one? That is without copying ebin-dev dtb with the new edge kernel? 0 Quote
crosser Posted February 7, 2025 Author Posted February 7, 2025 @prahal I am running this now: crosser@kobol:~$ cat /etc/os-release PRETTY_NAME="Armbian 24.11.3 noble" NAME="Ubuntu" VERSION_ID="24.04" VERSION="24.04 LTS (Noble Numbat)" VERSION_CODENAME=noble ID=ubuntu ID_LIKE=debian HOME_URL="https://www.armbian.com" SUPPORT_URL="https://forum.armbian.com" BUG_REPORT_URL="https://www.armbian.com/bugs" PRIVACY_POLICY_URL="https://www.armbian.com" UBUNTU_CODENAME=noble LOGO="armbian-logo" ARMBIAN_PRETTY_NAME="Armbian 24.11.3 noble" crosser@kobol:~$ uname -a Linux kobol 6.12.1-edge-rockchip64 #1 SMP PREEMPT Fri Nov 22 14:30:26 UTC 2024 aarch64 aarch64 aarch64 GNU/Linux crosser@kobol:~$ dpkg --list|grep dtb ii linux-dtb-edge-rockchip64 24.11.1 arm64 Armbian Linux edge DTBs in /boot/dtb-6.12.1-edge-rockchip64 crosser@kobol:~$ without any kernel-level alterations (A few minor userspace config modifications are needed to make LED work, and nfs services start in the right order, but that is all) 0 Quote
prahal Posted February 15, 2025 Posted February 15, 2025 If LED issue was helios64:green:status in sysfs instead of helios64::status it is fixed in git. 0 Quote
