Eloy Bote Falcon Posted September 9, 2024 Posted September 9, 2024 Hi, I'm trying to build armbian with the tutorial https://docs.armbian.com/Developer-Guide_Build-Preparation/#what-do-i-need but I get this error: ~/git/others/armbian/build$ ./compile.sh [🚸] Docker is installed, but not usable [ can't use Docker; check your Docker config / groups / etc ] [💥] Problem detected [ Docker installed but not usable ] [💥] Exiting in 10 seconds [ Press <Ctrl-C> to abort, <Enter> to ignore and continue ] Counting down: 9... 8... 7... 6... 5... 4... 3... 2... 1... 0... [💥] error! [ Exiting due to 'Docker installed but not usable' ] [💥] Exiting with error 43 [ at /home/eloy/git/others/armbian/build/lib/functions/logging/traps.sh:1 exit_with_error() --> lib/functions/logging/traps.sh:1 exit_if_countdown_not_aborted() --> lib/functions/general/countdown.sh:41 cli_standard_relaunch_docker_or_sudo() --> lib/functions/cli/utils-cli.sh:261 cli_standard_build_pre_run() --> lib/functions/cli/cli-build.sh:14 armbian_cli_pre_run_command() --> lib/functions/cli/utils-cli.sh:122 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:79 main() --> ./compile.sh:50 ] I have virtualbox installed, and my OS is: cat /etc/os-release PRETTY_NAME="Ubuntu 22.04.4 LTS" NAME="Ubuntu" VERSION_ID="22.04" VERSION="22.04.4 LTS (Jammy Jellyfish)" VERSION_CODENAME=jammy ID=ubuntu ID_LIKE=debian HOME_URL="https://www.ubuntu.com/" SUPPORT_URL="https://help.ubuntu.com/" BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/" PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy" UBUNTU_CODENAME=jammy lscpu Architecture: x86_64 CPU op-mode(s): 32-bit, 64-bit Address sizes: 43 bits physical, 48 bits virtual Byte Order: Little Endian CPU(s): 8 On-line CPU(s) list: 0-7 Vendor ID: AuthenticAMD Model name: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx What am I doing wrong? Thanks in advance. 0 Quote
Solution Werner Posted September 9, 2024 Solution Posted September 9, 2024 moved. neither a tutorial nor a review. 41 minutes ago, Eloy Bote Falcon said: Docker is installed, but not usable [ can't use Docker; check your Docker config / groups / etc ] Check if the user you are using has permission to use docker (usermod -aG docker yourusername) Alternatively use PREFER_DOCKER=no 0 Quote
