IllSkillz Posted September 15 Posted September 15 Armbianmonitor: https://paste.armbian.com/uwixiqivox I believe that ethernet adaptor is not working properly because there's only one led blinking and its unable to receive ip address. I have tried to configure it with yaml files and manually with networkd and with static ip. I also tried to run dhcp on that interface and it received random ip outside of my network. Had no luck with network-manager either, it threw an error "ip configuration could not be reserved" With desktop image ethernet worked with no problem. So maybe there's a driver issue? 0 Quote
Solution Igor Posted September 15 Solution Posted September 15 2 hours ago, IllSkillz said: maybe there's a driver issue? Yes, most likely broken / incomplete driver. Desktop runs Network Manager and CLI / minimal systemd-networkd. If driver is not in a good state, this is how it could manifest. Possible workaround = build CLI server image which contain Network Manager. No warranty that it will work ... Topic was moved from https://forum.armbian.com/forum/25-beginners/ as Armbian don't work with this vendor / hardware so its on you (& community) to resolve the problem. Or not. When you find out what is the problem, you are welcome to share it with everyone. 0 Quote
