PHLAK Posted September 17 Posted September 17 (edited) I've been using a few Rock Pi S devices as snapcast clients and after updating them to Armbian 24.8.2 audio does not work anymore. This seems similar to this old post (fix PR). Also, this PR may be a relevant to the issue. https://paste.armbian.com/aziwayelen $ snapclient --host [REDACTED] 2024-09-17 09-28-10.435 [Error] (Snapclient) PCM device "default" not found 2024-09-17 09-28-10.436 [Info] (Snapclient) Version 0.26.0 2024-09-17 09-28-10.437 [Info] (Connection) Resolving host IP for: [REDACTED] 2024-09-17 09-28-10.440 [Info] (Connection) Connecting 2024-09-17 09-28-10.442 [Notice] (Connection) Connected to 192.168.0.100 2024-09-17 09-28-10.442 [Info] (Connection) My MAC: "42:00:00:00:80:30", socket: 8 2024-09-17 09-28-10.518 [Info] (Controller) ServerSettings - buffer: 1000, latency: 0, volume: 75, muted: 0 2024-09-17 09-28-10.519 [Info] (Controller) Codec: flac, sampleformat: 48000:16:2 2024-09-17 09-28-10.520 [Info] (Player) Player name: alsa, device: default, description: <none>, idx: -1, sharing mode: unspecified, parameters: <none> 2024-09-17 09-28-10.520 [Info] (Player) Mixer mode: software, parameters: <none> 2024-09-17 09-28-10.520 [Info] (Player) Sampleformat: 48000:16:2, stream: 48000:16:2 2024-09-17 09-28-10.520 [Info] (Alsa) Using default buffer_time: 80 ms, default fragments: 4 ALSA lib confmisc.c:855:(parse_card) cannot find card '0' ALSA lib conf.c:5180:(_snd_config_evaluate) function snd_func_card_inum returned error: No such file or directory ALSA lib confmisc.c:422:(snd_func_concat) error evaluating strings ALSA lib conf.c:5180:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory ALSA lib confmisc.c:1334:(snd_func_refer) error evaluating name ALSA lib conf.c:5180:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory ALSA lib conf.c:5703:(snd_config_expand) Evaluate error: No such file or directory ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM default 2024-09-17 09-28-10.528 [Error] (Alsa) Exception: Can't open default, error: No such file or directory, code: -2 2024-09-17 09-28-10.530 [Fatal] (Snapclient) Exception: Can't open default, error: No such file or directory 2024-09-17 09-28-10.530 [Notice] (Snapclient) Snapclient terminated. $ aplay -l aplay: device_list:274: no soundcards found... When following the instructions on the official wiki to enable the audio jack I get a `Permission denied` error echoing a value to the `/sys/class/gpio/export` (but not gpio15). $ sudo echo 15 > /sys/class/gpio/export -bash: /sys/class/gpio/export: Permission denied $ sudo cat /sys/class/gpio/export cat: /sys/class/gpio/export: Permission denied $ ls -Al /sys/class/gpio/ total 0 --w------- 1 root root 4096 Sep 17 09:16 export lrwxrwxrwx 1 root root 0 Sep 17 09:16 gpio15 -> ../../devices/platform/pinctrl/ff220000.gpio/gpiochip0/gpio/gpio15 lrwxrwxrwx 1 root root 0 Dec 31 1969 gpiochip0 -> ../../devices/platform/pinctrl/ff220000.gpio/gpio/gpiochip0 lrwxrwxrwx 1 root root 0 Dec 31 1969 gpiochip128 -> ../../devices/platform/pinctrl/ff260000.gpio/gpio/gpiochip128 lrwxrwxrwx 1 root root 0 Dec 31 1969 gpiochip32 -> ../../devices/platform/pinctrl/ff230000.gpio/gpio/gpiochip32 lrwxrwxrwx 1 root root 0 Dec 31 1969 gpiochip64 -> ../../devices/platform/pinctrl/ff240000.gpio/gpio/gpiochip64 lrwxrwxrwx 1 root root 0 Dec 31 1969 gpiochip96 -> ../../devices/platform/pinctrl/ff250000.gpio/gpio/gpiochip96 --w------- 1 root root 4096 Sep 17 09:36 unexport Edited September 18 by PHLAK 0 Quote
Solution PHLAK Posted September 25 Author Solution Posted September 25 I was able to fix this by updating to the 6.7 kernel via `armbian-config`. 0 Quote
