I´m new to arm and linux; could you pls tell me how can i disable the login prompt at startup still in the command lines ?
Thanks
You mean that you will start directly in desktop?
You need to login once to create a username, than desktop goes on and next time you will be running desktop ... if you downloaded desktop image in first place, otherwise you need to repeat the job. Check docs.armbian.com for basics.
