Impossible to connect USB Stick with USB Hub on Cubietruck
Here is another unsolved problem for me:
I can only get my USB Stick to work if i plug it to to the onboard USB.
If i use an USB-Hub ( tried different ones) it is not possible.
There is no message coming up with tail -f /var/log/messages.
If i try to mount: mount: /dev/sdb1 is not a valid block device
I need more than two USB devices, so a USB Hub is important for me.
I tried active and passive Hubs and off course different USB-Sticks.
What can i do to solve this problem?
dmesg | grep usb
[    0.399281] usbcore: registered new interface driver usbfs
[    0.403635] usbcore: registered new interface driver hub
[    0.407825] usbcore: registered new device driver usb
[    0.442458] [usb_manager]: CONFIG_USB_SW_SUNXI_USB0_OTG
[    0.446259] [sw_hcd0]: usb host driver initialize........
[    0.450484] [sw_hcd0]: open_usb_clock
[    0.475713] [sw_hcd0]: platform is usb host
[    0.520661] [sw_hcd0]: sw_usb_host0_disable start
[    0.537521] [sw_hcd0]: close_usb_clock
[    0.539983] [sw_hcd0]: sw_usb_host0_disable end
[    1.465566] usbcore: registered new interface driver usb-storage
[    1.474093] usbcore: registered new interface driver ums-alauda
[    1.479090] usbcore: registered new interface driver ums-cypress
[    1.486738] usbcore: registered new interface driver ums-datafab
[    1.491930] usbcore: registered new interface driver ums_eneub6250
[    1.496925] usbcore: registered new interface driver ums-freecom
[    1.501851] usbcore: registered new interface driver ums-isd200
[    1.506932] usbcore: registered new interface driver ums-jumpshot
[    1.511784] usbcore: registered new interface driver ums-karma
[    1.516867] usbcore: registered new interface driver ums-onetouch
[    1.521892] usbcore: registered new interface driver ums-realtek
[    1.526804] usbcore: registered new interface driver ums-sddr09
[    1.531731] usbcore: registered new interface driver ums-sddr55
[    1.536553] usbcore: registered new interface driver ums-usbat
[    1.821906] usb 3-1: new full-speed USB device number 2 using sw-ohci
[    1.827147] usbcore: registered new interface driver usbhid
[    1.830028] usbhid: USB HID core driver
[    2.191211] usb 4-1: new high-speed USB device number 2 using sw-ehci
[    2.621450] usb 4-1.1: new high-speed USB device number 3 using sw-ehci
[    2.769636] scsi1 : usb-storage 4-1.1:1.0
[    2.871453] usb 4-1.2: new full-speed USB device number 4 using sw-ehci
[    3.101461] usb 4-1.3: new full-speed USB device number 5 using sw-ehci
[    4.990008] usbcore: registered new interface driver usbserial
[    5.000132] usbcore: registered new interface driver usbserial_generic
[    5.008092] usbserial: USB Serial Driver core
[    5.031642] usbcore: registered new interface driver ftdi_sio
[    5.102168] usb 3-1: Detected FT232RL
[    5.133077] usb 3-1: Number of endpoints 2
[    5.168007] usb 3-1: Endpoint 1 MaxPacketSize 64
[    5.191657] usb 3-1: Endpoint 2 MaxPacketSize 64
[    5.220910] usb 3-1: Setting MaxPacketSize 64
[    5.246835] usb 3-1: FTDI USB Serial Device converter now attached to ttyUSB0
[    5.356697] usb 4-1.2: Detected FT232RL
[    5.381334] usb 4-1.2: Number of endpoints 2
[    5.389025] usb 4-1.2: Endpoint 1 MaxPacketSize 64
[    5.394416] usb 4-1.2: Endpoint 2 MaxPacketSize 64
[    5.399036] usb 4-1.2: Setting MaxPacketSize 64
[    5.415289] usb 4-1.2: FTDI USB Serial Device converter now attached to ttyUSB1
[    5.424796] usb 4-1.3: Detected FT232RL
[    5.428032] usb 4-1.3: Number of endpoints 2
[    5.435922] usb 4-1.3: Endpoint 1 MaxPacketSize 64
[    5.440169] usb 4-1.3: Endpoint 2 MaxPacketSize 64
[    5.443777] usb 4-1.3: Setting MaxPacketSize 64
[    5.464739] usb 4-1.3: FTDI USB Serial Device converter now attached to ttyUSB2
[ 1146.326270] usb 4-1: clear tt 1 (9041) error -110
[ 4057.151681] usb 4-1: clear tt 1 (9051) error -110
[14647.266733] usb 4-1: clear tt 1 (9041) error -110
[183851.069396] usb 4-1: USB disconnect, device number 2
[183851.073556] usb 4-1.1: USB disconnect, device number 3
[183851.084548] usb 4-1.2: USB disconnect, device number 4
[183851.105603] usb 4-1.3: USB disconnect, device number 5
[183886.688101] usb 4-1: new high-speed USB device number 6 using sw-ehci
[183901.844742] usb 4-1: device descriptor read/64, error -110
[183917.112428] usb 4-1: device descriptor read/64, error -110
[183917.343435] usb 4-1: new high-speed USB device number 7 using sw-ehci
[183932.861216] usb 5-1: new full-speed USB device number 2 using sw-ohci
[183933.078461] usb 5-1: not running at top speed; connect to a high speed hub
[183933.097990] scsi2 : usb-storage 5-1:1.0
[188674.645430] usb 5-1: USB disconnect, device number 2
lsusb
Bus 003 Device 002: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
uname -r
Debian Wheezy 3.4.109-sun7i
blkid
/dev/sda1: UUID="f64f5613-ce08-49e9-b13a-356dcdcb1893" TYPE="ext4"
/dev/mmcblk0p1: UUID="fbd8dfce-58fb-45a1-93d7-16895308a8d8" TYPE="ext4"
So here they are, your usb errors:
Now try to connect/disconnect you hubs, flash drives and other usb periphery directly or through hubs, checking dmesg each time, and try to figure out, what devices and device combinations produce these errors.
Hm, strange result:
if i plug in only the USB Hub i get sometimes the error message, sometimes not.
if i plug than the USB Stick into the hub i get sometimes the error message, sometimes not.
So currently i plug in the USB-Hub with no error message, than i try to plug in the USB-Stick till i get no error message.
And now the dmesg (after i plug in 2 more USB-devices):
[189805.287387] usb 4-1: new high-speed USB device number 8 using sw-ehci
[189820.444066] usb 4-1: device descriptor read/64, error -110
[189835.711679] usb 4-1: device descriptor read/64, error -110
[189835.942769] usb 4-1: new high-speed USB device number 9 using sw-ehci
[189851.390546] usb 4-1: new high-speed USB device number 10 using sw-ehci
[189866.838240] usb 4-1: new high-speed USB device number 11 using sw-ehci
[189881.994792] usb 4-1: device descriptor read/64, error -110
[189943.146429] usb 4-1: new high-speed USB device number 12 using sw-ehci
[189994.342016] usb 4-1: new high-speed USB device number 13 using sw-ehci
[190009.498603] usb 4-1: device descriptor read/64, error -110
[190024.776206] usb 4-1: device descriptor read/64, error -110
[190025.007375] usb 4-1: new high-speed USB device number 14 using sw-ehci
[190040.525009] usb 5-1: new full-speed USB device number 3 using sw-ohci
[190040.742316] usb 5-1: not running at top speed; connect to a high speed hub
[190041.106070] usb 5-1.1: new full-speed USB device number 4 using sw-ohci
[190041.282491] usb 5-1.1: not running at top speed; connect to a high speed hub
[190041.299615] scsi3 : usb-storage 5-1.1:1.0
[190060.255590] usb 5-1.1: USB disconnect, device number 4
[190067.929815] usb 5-1.1: new full-speed USB device number 5 using sw-ohci
[190068.106252] usb 5-1.1: not running at top speed; connect to a high speed hub
[190068.123502] scsi4 : usb-storage 5-1.1:1.0
[190169.395348] usb 5-1: USB disconnect, device number 3
[190169.399572] usb 5-1.1: USB disconnect, device number 5
[190191.220474] usb 4-1: new high-speed USB device number 15 using sw-ehci
[190206.377005] usb 4-1: device descriptor read/64, error -110
[190221.644718] usb 4-1: device descriptor read/64, error -110
[190221.875799] usb 4-1: new high-speed USB device number 16 using sw-ehci
[190237.323514] usb 4-1: new high-speed USB device number 17 using sw-ehci
[190252.480032] usb 4-1: device descriptor read/64, error -110
[190267.747713] usb 4-1: device descriptor read/64, error -110
[190267.978842] usb 4-1: new high-speed USB device number 18 using sw-ehci
[190283.576610] usb 4-1: new high-speed USB device number 19 using sw-ehci
[190298.733170] usb 4-1: device descriptor read/64, error -110
[190314.000812] usb 4-1: device descriptor read/64, error -110
[190314.231992] usb 4-1: new high-speed USB device number 20 using sw-ehci
[190329.669678] usb 4-1: new high-speed USB device number 21 using sw-ehci
[190344.826200] usb 4-1: device descriptor read/64, error -110
[190360.093852] usb 4-1: device descriptor read/64, error -110
[190360.325031] usb 4-1: new high-speed USB device number 22 using sw-ehci
[190413.041384] usb 4-1: new high-speed USB device number 23 using sw-ehci
[190428.197901] usb 4-1: device descriptor read/64, error -110
[190443.465525] usb 4-1: device descriptor read/64, error -110
[190443.696712] usb 4-1: new high-speed USB device number 24 using sw-ehci
[190459.214396] usb 5-1: new full-speed USB device number 6 using sw-ohci
[190459.431675] usb 5-1: not running at top speed; connect to a high speed hub
[190460.175426] usb 5-1.3: new full-speed USB device number 7 using sw-ohci
[190460.351848] usb 5-1.3: not running at top speed; connect to a high speed hub
[190460.369014] scsi5 : usb-storage 5-1.3:1.0
[190470.895948] usb 5-1.3: USB disconnect, device number 7
[190472.852419] usb 5-1.4: new full-speed USB device number 8 using sw-ohci
[190473.028838] usb 5-1.4: not running at top speed; connect to a high speed hub
[190473.046656] scsi6 : usb-storage 5-1.4:1.0
[190498.514417] usb 5-1.3: new full-speed USB device number 9 using sw-ohci
[190498.726266] usb 5-1.3: Detected FT232RL
[190498.729593] usb 5-1.3: Number of endpoints 2
[190498.733510] usb 5-1.3: Endpoint 1 MaxPacketSize 64
[190498.737342] usb 5-1.3: Endpoint 2 MaxPacketSize 64
[190498.740888] usb 5-1.3: Setting MaxPacketSize 64
[190498.750578] usb 5-1.3: FTDI USB Serial Device converter now attached to ttyUSB1
[190513.102507] usb 5-1.2: new full-speed USB device number 10 using sw-ohci
[190513.313270] usb 5-1.2: Detected FT232RL
[190513.316623] usb 5-1.2: Number of endpoints 2
[190513.320563] usb 5-1.2: Endpoint 1 MaxPacketSize 64
[190513.324390] usb 5-1.2: Endpoint 2 MaxPacketSize 64
[190513.327937] usb 5-1.2: Setting MaxPacketSize 64
[190513.337409] usb 5-1.2: FTDI USB Serial Device converter now attached to ttyUSB2
Are you using different cables to connect USB hubs?
I still would try another power supply (just to be sure it's not PSU related) and another armbian distribution with mainline kernel (to be sure it's not some weird software/kernel glitch, just install clean image on another microSD card or backup your existing card and restore it after testing).
Are there another errors in dmesg output (plain "dmesg" without grep, maybe post it on pastebin)?
