Hello Igor,
Jessie and Wheezy wont start with kernel 4.0.4. The image from your page (wheezy) will not start completely and now a tried a self compiled (jessie) .
On the console I saw  "Please wait, rebooting" or something like this and later
"restarting sshd, please wait" (or so)
After that, nothing more happend.
System is a lime2 (different) and I deleted lib/ and output/ before compiling.
Best,
Jan
(Yes, I want to try the lime2-problems with a newer kernel :)
Actually it hangs only sometimes - I think the problem is in Eth initialization. Cut the power and try again. (reset won't help).
Stick to Wheezy and Trusty.
Sorry, same for Trusty 4.0.4 (no connection). Unfortunatelly I couldn't check the screen output.
Downloaded Trusty 4.0.4, copied to sd card, reboot & wait 5 minutes, disappeared from net, also after several restarts and unplugging the akku.
Current U-boot 2015.4 is broken. Ethernet fails to init also on Lime. I only changed u-boot for the latest archived and it worked.
This is temporally solution so working on permanent.
How can I install it?
1. attempt from sources:-----------------------------------------------------------
  CC [M]  /home/jan/lime2/output/rt8192cu/os_dep/linux/recv_linux.o
  CC [M]  /home/jan/lime2/output/rt8192cu/os_dep/linux/ioctl_cfg80211.o
  CC [M]  /home/jan/lime2/output/rt8192cu/os_dep/linux/rtw_android.o
/home/jan/lime2/output/rt8192cu/os_dep/linux/rtw_android.c: In function ârtw_android_cmdstr_to_numâ:
/home/jan/lime2/output/rt8192cu/os_dep/linux/rtw_android.c:229:3: error: implicit declaration of function âstrnicmpâ [-Werror=implicit-function-declaration]
   if(0 == strnicmp(cmdstr , android_wifi_cmd_str[cmd_num], strlen(android_wifi_cmd_str[cmd_num])) )
cc1: some warnings being treated as errors
make[2]: *** [/home/jan/lime2/output/rt8192cu/os_dep/linux/rtw_android.o] Fehler 1
make[1]: *** [_module_/home/jan/lime2/output/rt8192cu] Fehler 2
make[1]: Verzeichnis »/home/jan/lime2/output/linux-mainline« wird verlassen
make: *** [modules] Fehler 2
2. Second attempt from Website: ---------------------------------
- Downloaded image and wrote to sd cart
- Downloaded http://mirror.igorpecovnik.com/u-boot/linux-u-boot-4.0.4-lime2_1.8_armhf.deb
- chroot to /mnt
- dpkg -i linux-u-boot-4.0.4-lime2_1.8_armhf.deb
- reboot
- nothing :(
3. Searched for archive uboot ------------------------
Didnt find any Uboot*-Lime2-*4.0* - files...
