Hi armbian users,
I would like to know if it is possible to compile a own version of armbian with the following packages
git nginx php5-json php5-fpm php5
so I can run Linux-dash on my cubietruck.
This is the guide I am using to install linux-dash
Set up linux-dash on Debian, Ubuntu or Linux Mint
http://xmodulo.com/monitor-linux-server-desktop-remotely-web-browser.html
Now I know that some of the php packages are outdated. and the only I can think of to get the installation working is by using a older version of armbian.
which is obliviously somewhat backwards.
Also by using a older version I wont have access  to them armbian software and config tools.
Thx for any replies, blub4747
Thank you for the quick reply.
Should I than rename packages like this?
php5-json -> php7-json
php5-fpm-> php7-fpm
php5 -> php7
php5-fpm-> php7-fpm
php5 -> php7
Try simply without a number. Beware that running scripts on more recent php7 could lead into problems. There are some incompatibilities which are hard to solve for somebody without experiences. I would suggest you to stick to Debian Jessie and it's stock php5 ...
aeh sorry that did not work.
all three packages are not available under Debian Jessie
root@cubietruck:/home/blub# apt search php7-json
Sorting... Done
Full Text Search... Done
root@cubietruck:/home/xxx# apt search php7-fpm
Sorting... Done
Sorting... Done
I know, php7 is stock on Ubuntu Xenial and Debian Stretch.
Use php5
