Errol Posted Wednesday at 10:34 AM Share Posted Wednesday at 10:34 AM Hi, How do enable I2C on pins 3,5 of the GPIO header? I need to enable I2C7_M3. How to enable spidev.0 on SPI0_M2? All these overlays are missing... Thank you, Errol 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted Wednesday at 10:36 AM Share Posted Wednesday at 10:36 AM Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote Link to comment Share on other sites More sharing options...
Errol Posted Wednesday at 10:39 AM Author Share Posted Wednesday at 10:39 AM Hi Werner, I don't know how this will help, as the issue is configuration/setup related, not system related, but attached anyway. https://paste.armbian.com/ufogojovit Thank you, Errol 0 Quote Link to comment Share on other sites More sharing options...
Solution Werner Posted Wednesday at 10:48 AM Solution Share Posted Wednesday at 10:48 AM It helps to tell you to try vendor kernel instead of mainline ("edge"). The support for the rk3588 in latter is still under heavy development and lots of stuff is still WIP and therefore missing. https://docs.armbian.com/User-Guide_FAQ/#why-does-hardware-feature-xy-work-in-old-kernel-but-not-in-more-recent-one 0 Quote Link to comment Share on other sites More sharing options...
Errol Posted Wednesday at 12:05 PM Author Share Posted Wednesday at 12:05 PM Ahh, the rock-5b page says this: Quote Kernel 6.8.y is at experimental support level! Not all features work but it runs fairy stable. But I suppose it now means 6.10 is experimental. And I twice accidentally downloaded 6.10 instead of 6.1 because the names are so similar. I installed the image for 6.1, kernel 6.1.75-vendor-rk35xx, but now armbian-config has even less options under System/Hardware. Previously all the PWMs where there, some SATA ports and a few I2C ports. Now there is just "opp-oc-24ghz" and "panthor-gpu". I was able to add the overlays manually to armbianEnv.txt. So all my devices are now enabled. Thanks! 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted Wednesday at 01:29 PM Share Posted Wednesday at 01:29 PM 1 hour ago, Errol said: rock-5b page says this: I see. Well this should be replaced with "mainline is at experimental...." I guess 1 hour ago, Errol said: , but now armbian-config has even less options under System/Hardware That is an issue with the naming of the overlays. Glad you figured out already. I think this also will be adressed with the next generation of armbian-config. 0 Quote Link to comment Share on other sites More sharing options...
