farmerdave Posted July 5, 2017 Posted July 5, 2017 Hi, I've been running armbian (Debian Jessie) on my Cubietruck successfully for a while now, its mainly just an mpd server. It runs as a headless server and I use the optical spdif connection, ethernet (although I used to use the wireless). I have my root partition on a 2.5" hdd. I currently have: linux-image-3.4.106-cubieboard linux-headers-3.4.106-cubieboard linux-firmware-image-3.4.106-cubieboard I've seen the page http://www.armbian.com/kernel/ and added the repository as instructed. I really just want to confirm if you think I'll run into any trouble with spdif and ethernet if I upgrade to mainline kernel. My understanding is that I should install: linux-image-next-sunxi linux-headers-next-sunxi linux-u-boot-cubietruck-next linux-dtb-next-sunxi linux-jessie-root-cubietruck armbian-firmware Should I also remove the legacy cubieboard packages listed?
Igor Posted July 5, 2017 Posted July 5, 2017 You are trying to upgrade from an very old build, which in theory, should work but the problem might be boot script compatibility ... 27 minutes ago, farmerdave said: linux-image-next-sunxi linux-headers-next-sunxi linux-u-boot-cubietruck-next linux-dtb-next-sunxi linux-jessie-root-cubietruck armbian-firmware One small mistake: linux-jessie-root-next-cubietruck If you have nothing to loose, do it ... but be prepared for problems and to start from scratch with fresh Jessie Next install. 1
farmerdave Posted July 6, 2017 Author Posted July 6, 2017 Thanks! I think its a bit easy to make this mistake, the kernel page says to use "linux-jessie-root-DEVICE_NAME", perhaps it should read "linux-jessie-root-next-DEVICE_NAME"? Unfortunately I do have a bit to lose, so I might have to think carefully if its actually necessary and worth it. Assuming I do go ahead, I see the boot script you linked to will also install /boot/armbianEnv.txt, which may be edited. I then just need to run mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr before rebooting?
