Boot fails after NVMe/SPI install
Go to solution Solved by Werner,
DDR 2d653b3476 typ 24/01/20-15:04:19,fwver: v1.21
In
LP4/4x derate en, other dram:1x trefi
ddrconfig:0
LPDDR4X, 324MHz
BW=32 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=2048MB
tdqss: cs0 dqs0: -48ps, dqs1: -96ps, dqs2: -96ps, dqs3: -192ps,
change to: 324MHz
PHY drv:clk:36,ca:36,DQ:29,odt:0
vrefinner:24%, vrefout:41%
dram drv:40,odt:0
clk skew:0x64
rx vref: 26.4%
tx vref: 36.0%
change to: 528MHz
dram drv:40,odt:0
clk skew:0x58
rx vref: 28.4%
tx vref: 36.0%
change to: 780MHz
PHY drv:clk:36,ca:36,DQ:29,odt:60
vrefinner:16%, vrefout:41%
dram drv:40,odt:0
clk skew:0x58
rx vref: 16.6%
tx vref: 32.0%
change to: 1560MHz(final freq)
vrefinner:16%, vrefout:22%
dram drv:40,odt:80
vref_ca:00000071
clk skew:0x30
rx vref: 15.6%
tx vref: 18.8%
cs 0:
the read training result:
DQS0:0x34, DQS1:0x34, DQS2:0x34, DQS3:0x31,
min  : 0xe 0x10 0x11  0xe  0x1  0x6  0xa  0x7 , 0xb  0x9  0x3  0x2  0xe  0xe  0xe  0xc ,
      0x10 0x10  0xd  0xa  0x3  0x2  0x3  0x7 , 0xc  0x8  0x7  0x2  0xe 0x10  0xc 0x14 ,
mid  :0x29 0x2a 0x2c 0x29 0x1d 0x21 0x25 0x23 ,0x26 0x24 0x1d 0x1d 0x29 0x28 0x29 0x27 ,
      0x2c 0x2b 0x27 0x25 0x1e 0x1d 0x1d 0x21 ,0x27 0x23 0x22 0x1d 0x29 0x2b 0x28 0x2e ,
max  :0x45 0x45 0x47 0x44 0x39 0x3d 0x40 0x3f ,0x42 0x40 0x38 0x39 0x45 0x42 0x44 0x42 ,
      0x48 0x47 0x41 0x41 0x3a 0x38 0x38 0x3c ,0x42 0x3e 0x3d 0x38 0x44 0x46 0x44 0x49 ,
range:0x37 0x35 0x36 0x36 0x38 0x37 0x36 0x38 ,0x37 0x37 0x35 0x37 0x37 0x34 0x36 0x36 ,
      0x38 0x37 0x34 0x37 0x37 0x36 0x35 0x35 ,0x36 0x36 0x36 0x36 0x36 0x36 0x38 0x35 ,
the write training result:
DQS0:0x27, DQS1:0x1d, DQS2:0x1d, DQS3:0xa,
min  :0x6e 0x72 0x73 0x70 0x63 0x67 0x6a 0x69 0x6a ,0x5e 0x5c 0x55 0x55 0x61 0x60 0x60 0x5f 0x5d ,
      0x67 0x65 0x60 0x5f 0x59 0x57 0x57 0x5d 0x5f ,0x54 0x50 0x4e 0x49 0x55 0x58 0x53 0x5a 0x50 ,
mid  :0x88 0x8c 0x8d 0x8a 0x7c 0x80 0x83 0x82 0x83 ,0x78 0x77 0x6f 0x6f 0x7c 0x7a 0x7a 0x79 0x76 ,
      0x83 0x81 0x7b 0x7a 0x73 0x71 0x72 0x77 0x79 ,0x6e 0x6a 0x68 0x62 0x71 0x72 0x6f 0x74 0x6b ,
max  :0xa2 0xa6 0xa8 0xa4 0x95 0x99 0x9d 0x9b 0x9c ,0x92 0x92 0x89 0x89 0x97 0x94 0x94 0x93 0x90 ,
      0x9f 0x9e 0x96 0x96 0x8e 0x8c 0x8d 0x92 0x94 ,0x89 0x84 0x82 0x7c 0x8d 0x8d 0x8b 0x8e 0x86 ,
range:0x34 0x34 0x35 0x34 0x32 0x32 0x33 0x32 0x32 ,0x34 0x36 0x34 0x34 0x36 0x34 0x34 0x34 0x33 ,
      0x38 0x39 0x36 0x37 0x35 0x35 0x36 0x35 0x35 ,0x35 0x34 0x34 0x33 0x38 0x35 0x38 0x34 0x36 ,
CA Training result:
cs:0 min  :0x49 0x45 0x3f 0x38 0x3d 0x35 0x40 ,0x49 0x42 0x3e 0x36 0x3b 0x37 0x40 ,
cs:0 mid  :0x86 0x86 0x7a 0x78 0x79 0x75 0x6d ,0x85 0x82 0x7a 0x75 0x77 0x77 0x6d ,
cs:0 max  :0xc3 0xc8 0xb6 0xb9 0xb6 0xb5 0x9b ,0xc2 0xc2 0xb6 0xb4 0xb4 0xb7 0x9b ,
cs:0 range:0x7a 0x83 0x77 0x81 0x79 0x80 0x5b ,0x79 0x80 0x78 0x7e 0x79 0x80 0x5b ,
out
U-Boot SPL board init
U-Boot SPL 2017.09-armbian-2017.09-Sbf16-P2429-H8c72-Vadec-Bda0a-R448a (Oct 22 2024 - 09:34:44)
Trying to boot from MMC2
Card did not respond to voltage select!
mmc_init: -95, time 9
spl: mmc init failed with error: -95
Trying to boot from MMC1
mmc_init: -95, time 13
Trying to boot from MTD2
No misc partition
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 ... sha256(b5946ac63d...) + OK
## Checking uboot 0x00a00000 ... sha256(f1535ab009...) + OK
## Checking fdt 0x00b55910 ... sha256(3364e18f3b...) + OK
## Checking atf-2 0xfdcc1000 ... sha256(b8dca786b4...) + OK
## Checking atf-3 0x0006b000 ... sha256(2f91089eb7...) + OK
## Checking atf-4 0xfdcce000 ... sha256(86ef885748...) + OK
## Checking atf-5 0xfdcd0000 ... sha256(0b2b146c60...) + OK
## Checking atf-6 0x00069000 ... sha256(a9a1e63bef...) + OK
Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000)
Total: 549.918/721.616 ms
INFO:    Preloader serial: 2
NOTICE:  BL31: v2.3():v2.3-645-g8cea6ab0b:cl, fwver: v1.44
NOTICE:  BL31: Built : 16:36:43, Sep 19 2023
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    pmu v1 is valid 220114
INFO:    l3 cache partition cfg-0
INFO:    dfs DDR fsp_param[0].freq_mhz= 1560MHz
INFO:    dfs DDR fsp_param[1].freq_mhz= 324MHz
INFO:    dfs DDR fsp_param[2].freq_mhz= 528MHz
INFO:    dfs DDR fsp_param[3].freq_mhz= 780MHz
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0xa00000
INFO:    SPSR = 0x3c9
U-Boot 2017.09-armbian-2017.09-Sbf16-P2429-H8c72-Vadec-Bda0a-R448a (Oct 22 2024 - 09:34:44 +0200)
Model: Radxa ROCK3 Model A
MPIDR: 0x81000000
PreSerial: 2, raw, 0xfe660000
DRAM:  2 GiB
Sysmem: init
Relocation Offset: 7d20a000
Relocation fdt: 7b9f65d8 - 7b9fecc8
CR: M/C/I
Using default environment
DM: v1
dwmmc@fe2b0000: 1, dwmmc@fe2c0000: 2, sdhci@fe310000: 0
mmc_init: -95, time 10
Device 0: unknown device
Device 1: unknown device
Unknown command 'scsi' - try 'help'
Device 1:
Device 2: JEDEC id bytes: c2, 25, 38
SF: Detected sfc_nor with page size 256 Bytes, erase size 4 KiB, total 16 MiB
Vendor: 0x2207 Rev: V1.00 Prod: sfc_nor
            Type: Hard Disk
            Capacity: 16.0 MB = 0.0 GB (32768 x 512)
... is now current device
Bootdev(scan): mtd 2
PartType: EFI
No misc partition
boot mode: None
FIT: No boot partition
Failed to load DTB, ret=-19
No valid DTB, ret=-22
Failed to get kernel dtb, ret=-22
I2c0 speed: 100000Hz
vsel-gpios- not found! Error: -2
FAN53555 Option[12] Rev[15] Detected!
vdd_cpu init 900000 uV
PMIC:  RK8090 (on=0x40, off=0x00)
vdd_logic init 900000 uV
vdd_gpu init 900000 uV
vdd_npu init 900000 uV
io-domain: OK
Failed to get scmi clk dev
dmc_fsp failed, ret=-19
MPIDR: 0x81000000
## Error: Can't overwrite "ethaddr"
## Error inserting "ethaddr" variable, errno=1
## Error: Can't overwrite "eth1addr"
## Error inserting "eth1addr" variable, errno=1
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
  apll 816000 KHz
  dpll 780000 KHz
  gpll 1188000 KHz
  cpll 1000000 KHz
  npll 1200000 KHz
  vpll 24000 KHz
  hpll 24000 KHz
  ppll 200000 KHz
  armclk 816000 KHz
  aclk_bus 150000 KHz
  pclk_bus 100000 KHz
  aclk_top_high 300000 KHz
  aclk_top_low 200000 KHz
  hclk_top 150000 KHz
  pclk_top 100000 KHz
  aclk_perimid 300000 KHz
  hclk_perimid 150000 KHz
  pclk_pmu 100000 KHz
Net:   eth1: ethernet@fe010000
Hit key to stop autoboot('CTRL+C'):  0
starting USB...
Bus dwc3@fcc00000: usb maximum-speed not found
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
Bus dwc3@fd000000: usb maximum-speed not found
USB XHCI 1.10
scanning bus dwc3@fcc00000 for devices... 1 USB Device(s) found
scanning bus dwc3@fd000000 for devices... 1 USB Device(s) found
pcie@fe260000: PCIe Linking... LTSSM is 0x0
pcie@fe260000: PCIe Linking... LTSSM is 0x1
pcie@fe260000: PCIe-0 Link Fail
unable to get syscon device for rockchip,pipe-grf
snps pcie3phy FW update! size 8192
pcie@fe280000: PCIe Linking... LTSSM is 0x0
pcie@fe280000: PCIe Linking... LTSSM is 0x2
pcie@fe280000: PCIe Linking... LTSSM is 0x210023
pcie@fe280000: PCIe Link up, LTSSM is 0x230011
pcie@fe280000: PCIE-0: Link up (Gen3-x2, Bus0)
pcie@fe280000: invalid flags type!
Device 0: Vendor: 0x1c5c Rev: 20005A00 Prod: EJ74N204210504P61
            Type: Hard Disk
            Capacity: 244198.3 MB = 238.4 GB (500118192 x 512)
Scanning nvme 0:1...
pcie@fe260000: failed to find reset-gpios property
mmc_init: -95, time 14
## Error: "mtd_boot" not defined
ethernet@fe010000 Waiting for PHY auto negotiation to complete. done
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
DHCP client bound to address 172.17.117.202 (3822 ms)
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-f2-87-c0-75-70-d6
*** ERROR: `serverip' not set
Retrieving file: pxelinux.cfg/AC1175CA
Retrieving file: pxelinux.cfg/default-arm-rockchip
Config file not found
BOOTP broadcast 1
DHCP client bound to address 172.17.117.202 (67 ms)
## Executing script at 00c00000
Wrong image format for "source" command
Could not find misc partition
ANDROID: reboot reason: "(none)"
optee check api revision fail: -1.0
optee api revision is too low
### ERROR ### Please RESET the board ###
Boots fine from microSD but fails from NVMe/SPI.
tested with current noble minimal 24.8.1
Retried with kwiboo's 2024.10 branch. No luck either
In
ddrconfig:0
LPDDR4X, 324MHz
tdqss: cs0 dqs0: -48ps, dqs1: -96ps, dqs2: -96ps, dqs3: -168ps,
change to: 324MHz
dram drv:40,odt:0
clk skew:0x64
rx vref: 24.4%
tx vref: 36.0%
change to: 528MHz
dram drv:40,odt:0
clk skew:0x58
rx vref: 28.4%
tx vref: 34.0%
change to: 780MHz
dram drv:40,odt:0
clk skew:0x58
rx vref: 15.6%
tx vref: 32.0%
dram drv:40,odt:80
vref_ca:00000071
clk skew:0x2b
rx vref: 15.6%
tx vref: 19.8%
cs 0:
DQS0:0x34, DQS1:0x34, DQS2:0x34, DQS3:0x30,
min  : 0xe 0x10 0x11  0xe  0x2  0x6  0xa  0x7 , 0xb  0x9  0x2  0x2  0xe  0xe  0xf  0xc ,
       0xf  0xf  0xc  0xa  0x3  0x2  0x2  0x7 , 0xc  0x7  0x5  0x2  0xe 0x10  0xc 0x13 ,
mid  :0x2a 0x2a 0x2c 0x29 0x1d 0x21 0x25 0x23 ,0x26 0x24 0x1d 0x1d 0x2a 0x28 0x29 0x27 ,
      0x2b 0x2b 0x26 0x25 0x1e 0x1d 0x1d 0x21 ,0x26 0x22 0x20 0x1c 0x29 0x2b 0x28 0x2c ,
max  :0x46 0x45 0x47 0x44 0x39 0x3d 0x40 0x3f ,0x42 0x40 0x38 0x39 0x46 0x42 0x44 0x42 ,
      0x48 0x47 0x41 0x41 0x3a 0x38 0x38 0x3c ,0x41 0x3d 0x3b 0x37 0x44 0x46 0x44 0x46 ,
range:0x38 0x35 0x36 0x36 0x37 0x37 0x36 0x38 ,0x37 0x37 0x36 0x37 0x38 0x34 0x35 0x36 ,
      0x39 0x38 0x35 0x37 0x37 0x36 0x36 0x35 ,0x35 0x36 0x36 0x35 0x36 0x36 0x38 0x33 ,
DQS0:0x22, DQS1:0x18, DQS2:0x18, DQS3:0xa,
min  :0x69 0x6c 0x6e 0x6b 0x5e 0x62 0x64 0x63 0x65 ,0x5a 0x58 0x51 0x51 0x5e 0x5c 0x5c 0x5c 0x59 ,
      0x63 0x62 0x5d 0x5c 0x54 0x53 0x53 0x5a 0x5b ,0x54 0x51 0x4e 0x49 0x56 0x59 0x53 0x5a 0x50 ,
mid  :0x83 0x86 0x88 0x84 0x77 0x7b 0x7d 0x7c 0x7d ,0x73 0x72 0x6a 0x6a 0x78 0x75 0x75 0x75 0x71 ,
      0x7e 0x7e 0x77 0x77 0x6f 0x6c 0x6d 0x73 0x75 ,0x6e 0x6b 0x68 0x63 0x71 0x73 0x6f 0x74 0x6b ,
max  :0x9d 0xa1 0xa2 0x9e 0x90 0x94 0x96 0x96 0x96 ,0x8d 0x8d 0x84 0x84 0x92 0x8f 0x8f 0x8e 0x8a ,
      0x9a 0x9a 0x92 0x92 0x8a 0x86 0x88 0x8d 0x8f ,0x89 0x85 0x82 0x7d 0x8d 0x8d 0x8b 0x8f 0x86 ,
range:0x34 0x35 0x34 0x33 0x32 0x32 0x32 0x33 0x31 ,0x33 0x35 0x33 0x33 0x34 0x33 0x33 0x32 0x31 ,
      0x37 0x38 0x35 0x36 0x36 0x33 0x35 0x33 0x34 ,0x35 0x34 0x34 0x34 0x37 0x34 0x38 0x35 0x36 ,
CA Training result:
cs:0 min  :0x49 0x45 0x3f 0x37 0x3d 0x35 0x40 ,0x49 0x42 0x3e 0x35 0x3b 0x37 0x40 ,
cs:0 mid  :0x86 0x86 0x7b 0x78 0x79 0x74 0x6d ,0x85 0x82 0x7a 0x74 0x77 0x77 0x6d ,
cs:0 max  :0xc3 0xc8 0xb7 0xb9 0xb6 0xb4 0x9b ,0xc2 0xc2 0xb6 0xb3 0xb4 0xb7 0x9a ,
cs:0 range:0x7a 0x83 0x78 0x82 0x79 0x7f 0x5b ,0x79 0x80 0x78 0x7e 0x79 0x80 0x5a ,
out
U-Boot SPL 2024.10-rc6-armbian-2024.10-rc6-Saf53-P0000-H3950-Vea36-Bda0a-R448a+ (Oct 22 2024 - 13:08:19 +0200)
Trying to boot from SPI
## Checking hash(es) for config config-1 ... OK
## Checking hash(es) for Image atf-1 ... sha256+ OK
## Checking hash(es) for Image u-boot ... sha256+ OK
## Checking hash(es) for Image fdt-1 ... sha256+ OK
## Checking hash(es) for Image atf-2 ... sha256+ OK
## Checking hash(es) for Image atf-3 ... sha256+ OK
## Checking hash(es) for Image atf-4 ... sha256+ OK
## Checking hash(es) for Image atf-5 ... sha256+ OK
## Checking hash(es) for Image atf-6 ... sha256+ OK
INFO:    SPSR = 0x3c9
ns16550_serial serial@fe660000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
U-Boot 2024.10-rc6-armbian-2024.10-rc6-Saf53-P0000-H3950-Vea36-Bda0a-R448a+ (Oct 22 2024 - 13:08:19 +0200)
Model: Radxa ROCK 3A
DRAM:  2 GiB
PMIC:  RK809 (on=0x40, off=0x00)
Core:  343 devices, 31 uclasses, devicetree: separate
MMC:   mmc@fe000000: 2, mmc@fe2b0000: 1, mmc@fe310000: 0
Loading Environment from nowhere... OK
In:    serial@fe660000
Out:   serial@fe660000
Err:   serial@fe660000
Net:   eth0: ethernet@fe010000
Scanning for bootflows in all bootdevs
Seq  Method       State   Uclass    Part  Name                      Filename
Scanning global bootmeth 'efi_mgr':
Card did not respond to voltage select! : -110
No EFI system partition
Failed to persist EFI variables
Scanning bootdev 'mmc@fe2b0000.bootdev':
Scanning bootdev 'mmc@fe310000.bootdev':
pcie_dw_rockchip pcie@fe260000: PCIe-0 Link Fail
Scanning bootdev 'nvme#0.blk#1.bootdev':
scanning bus for devices...
Bus usb@fd000000: Register 2000140 NbrPorts 2
USB XHCI 1.10
Bus usb@fd800000: USB EHCI 1.00
Bus usb@fd880000: USB EHCI 1.00
Bus usb@fd8c0000: USB OHCI 1.0
scanning bus usb@fd000000 for devices... 1 USB Device(s) found
scanning bus usb@fd800000 for devices... 2 USB Device(s) found
scanning bus usb@fd880000 for devices... 1 USB Device(s) found
scanning bus usb@fd8c0000 for devices... 1 USB Device(s) found
ethernet@fe010000 Waiting for PHY auto negotiation to complete........ done
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
DHCP client bound to address 172.17.117.201 (3780 ms)
Scanning bootdev 'ethernet@fe010000.bootdev':
Retrieving file: pxelinux.cfg/01-f2-87-c0-75-70-d7
Retrieving file: pxelinux.cfg/AC1175C9
Retrieving file: pxelinux.cfg/default-arm-rk3568-evb_rk3568
BOOTP broadcast 1
DHCP client bound to address 172.17.117.201 (23 ms)
Cannot autoload with TFTPGET
No more bootdevs
(0 bootflows, 0 valid)
I guess it all boils down to "pcie_dw_rockchip pcie@fe260000: PCIe-0 Link Fail"
How I switched uboot:
shamelessly copied from another board :D
function post_family_config_branch_edge__rock-3a_use_mainline_uboot() {
	display_alert "$BOARD" "Mainline U-Boot overrides for $BOARD - $BRANCH" "info"
	declare -g BOOTCONFIG="rock-3a-rk3568_defconfig"     # override the default for the board/family
	declare -g BOOTDELAY=1                                       # Wait for UART interrupt to enter UMS/RockUSB mode etc
	declare -g BOOTSOURCE="https://github.com/Kwiboo/u-boot-rockchip" # We ❤️ mainline U-Boot
	declare -g BOOTBRANCH="branch:rk3xxx-2024.10"
	declare -g BOOTPATCHDIR="asdf" # empty
	declare -g BOOTDIR="u-boot-${BOARD}" # do not share u-boot directory
	declare -g UBOOT_TARGET_MAP="BL31=${RKBIN_DIR}/${BL31_BLOB} ROCKCHIP_TPL=${RKBIN_DIR}/${DDR_BLOB};;u-boot-rockchip.bin u-boot-rockchip-spi.bin"
	unset uboot_custom_postprocess write_uboot_platform write_uboot_platform_mtd # disable stuff from rockchip64_common; we're using binman here which does all the work already
	# Just use the binman-provided u-boot-rockchip.bin, which is ready-to-go
	function write_uboot_platform() {
		dd "if=$1/u-boot-rockchip.bin" "of=$2" bs=32k seek=1 conv=notrunc status=none
	function write_uboot_platform_mtd() {
		flashcp -v -p "$1/u-boot-rockchip-spi.bin" /dev/mtd0
  • Solution
armbian-install issue.
The contents of /boot were not copied over. After doing so and adjust UUID it boots just fine.
23.10.2024 в 06:58, Werner сказал:
Can you describe the selection scenario (order) in the "armbian-install" interface?
I could narrow it down a bit. If there is a separate boot partition rsync for some reason fails to copy its contents over even though it is mounted into the file system. Also I read somewhere that some rsync parameters might be incompatible with vfat but I guess this only goes into effect when writing to vfat and not when reading from.
The same OS without dedicated boot partition installs just fine.
29 минут назад, Werner сказал:
Thank you very much.
I collect in a notebook all possible bugs when using this utility.
I want to redo it.
Huh awesome :D :love:
As mentioned I am unsure about vfat is actually an issue or not. So perhaps you may want to dive a bit deeper. This is what I found: https://superuser.com/questions/763366/rsync-seems-to-overwrite-already-existing-file-on-exfat/1785111#1785111
As a workaround for now I simply duplicated the line where rsync is exected silently a second time to catch any missing files, adjusted a bit and used that to copy over the contents of /boot. However this UUID still needs to be adjusted manually.
7 часов назад, Werner сказал:
In fact, I found a lot of problems, these two were not on my list.
The build system does some steps more correctly, but this utility lags behind.
I think we need to teach her how to split empty space into sections and mount it the way the user wanted.
The work is slow, but it is progressing.
