oqewipobin Posted November 4, 2024 Posted November 4, 2024 (edited) I'm having an issue where the prebuilt images dowloaded from https://www.armbian.com/radxa-rock-5c/ (released on Oct 12, 2024) works fine, including WiFi connectivity, even after reboots, but the moment I updgrade the packages (apt update && apt upgrade) and reboot the system, the WiFi network interface (wlan0) simply disappears and can I no longer search or connect to any wireless network.I've flashed both Bookworm Minimal/IOT and Server/CLI Bookworm, e the issue always occur after upgradin packages. the wlan0 does not appear on iwctl neither ip address commands, but the device (AIC Wlan) still appears on lsusb command: $ lsusb Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 004: ID a69c:8d80 aicsemi AIC Wlan Bus 005 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub armbianmonitor output: https://paste.armbian.com/oqewipobin I don't know if there is an issue with the newest kernel update, or if there is some overlay or kernel module for the AIC Wlan chip that is being erased/disabled during the kernel update process. Is there something I can try to reenable the wlan0 interface? or is it just a bronken update? Edited November 4, 2024 by oqewipobin Fix hyperlink 0 Quote
Solution oqewipobin Posted November 5, 2024 Author Solution Posted November 5, 2024 Looks like installing/reinstalling the Radxa provided packages for aic8800 (https://github.com/radxa-pkg/aic8800/releases) kernel modules AFTER the kernel update makes the WiFi module work again. 0 Quote
Vlastimil Menšík Posted November 6, 2024 Posted November 6, 2024 What packages did you install? The release page from Radxa contains several packages and I am not sure, which should I use. 0 Quote
tom_i Posted November 18, 2024 Posted November 18, 2024 (edited) Same for me. Installed Quote Armbian_24.8.4_Rock-5c_bookworm_vendor_6.1.75-backported-mesa.img to eMMc card, installation / configuration for 1st time without problem also with using WIFI connection. List of modules after installation: Then after apt update/upgrade wifi stop working, module was not found or somehow broken. What I found out, that upgrade Armbian deletes all aic8800 modules: After rebooting system, modules were not loaded and modprobe of them don't work either. Upgrade installs newer versions of Quote linux-headers-vendor-rk35xx linux-image-vendor-rk35xx linux-dtb-vendor-rk35xx to version 24.11.1 from 24.8.4 Edited November 18, 2024 by tom_i 0 Quote
tom_i Posted November 18, 2024 Posted November 18, 2024 dmesg found it.. but [ 12.854279] usb 7-1.3: New USB device found, idVendor=a69c, idProduct=8d80, bcdDevice= 1.00 [ 12.854323] usb 7-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 12.854353] usb 7-1.3: Product: AIC Wlan [ 12.854378] usb 7-1.3: Manufacturer: aicsemi [ 12.854403] usb 7-1.3: SerialNumber: 20220103 ... [ 14.555712] aicbsp_init [ 14.555720] RELEASE_DATE:2024_0109_ec460377 [ 14.555724] aicbsp_resv_mem_init [ 14.557550] systemd[1]: Starting systemd-sysusers.service - Create System Users... [ 14.567717] aicbsp: aicbsp_set_subsys, subsys: AIC_WIFI, state to: 1 [ 14.567736] aicbsp: aicbsp_set_subsys, power state change to 1 dure to AIC_WIFI [ 14.567741] aicbsp: aicbsp_platform_power_on 0 Quote
Igor Posted November 18, 2024 Posted November 18, 2024 7 hours ago, tom_i said: Installed Test most recent builds: (still in testing) https://rsync.armbian.com/incoming/schwar3kat/rock-5c/archive/ 0 Quote
ChrisO Posted November 18, 2024 Posted November 18, 2024 I've just tried Armbian_24.11.1_Rock-5c_bookworm_edge_6.11.7_minimal.img wlan works. No ZFS, however. Building zfs-dkms fails, from /var/lib/dkms/zfs/2.2.5/build/make.log: 93 | #error "Unsupported kernel" According to https://github.com/openzfs/zfs/releases: zfs-2.2.5 is compatible with 4.18 - 6.9 kernels zfs-2.2.6 is compatible with 4.18 - 6.10 kernels zfs-2.3.0 would be compatible with Linux kernels 4.18 - 6.11 Armbian_24.8.4_Rock-5c_bookworm_vendor_6.1.75_minimal.img - ZFS OK, wlan after 'apt upgrade' not anymore. But $ /sudo dkms install aic8800-usb/3.0+git20240327.3561b08f-2 does the trick. ------- Sign command: /lib/modules/6.1.75-vendor-rk35xx/build/scripts/sign-file Binary /lib/modules/6.1.75-vendor-rk35xx/build/scripts/sign-file not found, modules won't be signed Creating symlink /var/lib/dkms/aic8800-usb/3.0+git20240327.3561b08f-2/source -> /usr/src/aic8800-usb-3.0+git20240327.3561b08f-2 Building module: Cleaning build area...(bad exit status: 2) make -j8 KERNELRELEASE=6.1.75-vendor-rk35xx -C /lib/modules/6.1.75-vendor-rk35xx/build M=/var/lib/dkms/aic8800-usb/3.0+git20240327.3561b08f-2/build/USB/driver_fw/drivers/aic8800 && make -C /lib/modules/6.1.75-vendor-rk35xx/build M=/var/lib/dkms/aic8800-usb/3.0+git20240327.3561b08f-2/build/USB/driver_fw/drivers/aic_btusb....... .... depmod... -------- root@rock-5c:~# iw phy0 info Wiphy phy0 wiphy index: 0 max # scan SSIDs: 3 max scan IEs length: 200 bytes max # sched scan SSIDs: 0 max # match sets: 0 Retry short limit: 7 Retry long limit: 4 Coverage class: 0 (up to 0m) Device supports RSN-IBSS. Device supports AP-side u-APSD. Supported Ciphers: * WEP40 (00-0f-ac:1) * WEP104 (00-0f-ac:5) * TKIP (00-0f-ac:2) .... Regards, Chris 0 Quote
Sander de Leeuw Posted December 8, 2024 Posted December 8, 2024 (edited) I can confirm this issue. Tested on the following images: * Armbian_24.11.1_Rock-5c_noble_vendor_6.1.75_gnome-kisak_desktop.img.xz * Custom build image (vendor kernel 6.1 + GNOME) When updating the kernel, the aic8800-usb DKMS driver is removed from the old kernel, but not reinstalled on the new kernel. This can easily be fixed afterwards by running the following command: `sudo dpkg-reconfigure aic8800-usb-dkms`, which will recompile and install the kernel module again. I was playing around with Radxa's own Debian based image as well. When compiling a custom kernel with their `bsp` tool and installing it, the same thing happens. Therefore I believe this to be an upstream issue with the aic8800 deb packages. Maybe with the way they register the driver using DKMS... Edited December 8, 2024 by Sander de Leeuw 1 Quote
pepperheart Posted February 26, 2025 Posted February 26, 2025 @Sander de Leeuw thx for the solution, one thing is strange after applying it, an additional device apears which is not the wifi adapter of the rockt 5c p2p-dev-wlan0: disconnected "p2p-dev-wlan0" wifi-p2p, hw 0 Quote
