Igor Posted November 13, 2024 Posted November 13, 2024 Mission: provide easy way to configure OS and install services armbian-config provides configuration and installation routines for customizing and automating tasks within Armbian Linux environment. These utilities help streamline setup processes for various use cases. Key Advantages Lightweight: Minimal dependencies for optimal performance. Flexible: Supports JSON, TUI, CLI, and API interfaces. Modern: A fresh approach to configuration. Low entropy: Byte clean uninstall for most targets. Features System Configuration: Kernel management, headers, hardware tweaks. NFS and ZFS storage management. SSH user access tweaks. System updates, rolling / stable, containers update. Network Management: Fixed / dynamic IP configuration. Connecting to wireless network. Access point management. Localization Settings: Configure time zone. Set language and locales. Change hostname. Software Management: Software installation and removal. Native and containerized environment. Standardised, updatable, maintained. Compatibility This tool is tailored to works best with Armbian Linux but it has also been automatically tested on: Debian Bookworm Ubuntu Jammy Ubuntu Noble In theory it should work on all systemd APT based Linux distributions: Linux Mint, Elementary OS, Kali Linux, MX Linux, Parrot OS, Proxmox, Raspberry Pi OS, ... Getting Started Armbian config is preinstalled on Armbian. Open or login into your terminal and run: armbian-config Spoiler This tool has clean and verified code with focus in security and ability for long term maintenance. It allows quick and easy user level functional expansion. For this reason we setup several automated tools that checks the code from various perspective at the development phase. Most of features are automatically testes with on Debian and Ubuntu based Armbian user-space. Even this tool was designed for Armbian and will be supported on Armbian OS only, and works best with it, you can (try to) use it on any APT based Linux operating system. End users: Request new software title Documentation: Armbian config | Optimised software Developers: Adding a new feature or software install title 1 Quote
Igor Posted February 6, 2025 Author Posted February 6, 2025 DNS ad blocker section: https://docs.armbian.com/User-Guide_Armbian-Software/DNS/ containerized with official images tested with networkd and Network Manager tested on arm64 1 Quote
Igor Posted February 16, 2025 Author Posted February 16, 2025 Desktop installation: (XFCE and Gnome at the moment) https://docs.armbian.com/User-Guide_Armbian-Software/Desktops/ automatic install and uninstall on code changes and daily modular packages assembly https://github.com/armbian/configng/blob/main/tools/modules/system/module_desktop_packages.sh clean and minimal (will be cleaned more, PR is welcome) 1 Quote
Igor Posted March 3, 2025 Author Posted March 3, 2025 Armbian OS updates: - enable / disable kernel upgrades - switch between stable and rolling repository - enable automatic updating of Docker containers images - automatic packages updating enable + configure (unattended-upgrade) 0 Quote
Igor Posted March 7, 2025 Author Posted March 7, 2025 System access: - enable & disable root login, password, key, 2FA on SSH access - sandboxed SSH server that allows ssh access without giving keys to the entire server. 0 Quote
greenais Posted August 25, 2025 Posted August 25, 2025 Any chance to get this new and great version on Oragepi3LTS working? I've got armbian-config.sources identical to what is described in user documentation above but still get probably old script version installed - with no additional menu items and, particularly, different name of Disable upgrades as follows: which, in turn, doesn't work for me anymore - nothing changes after I choose "Yes" at question "Disable?" and system has (according to apt-mark showhold) quite old kernel images holded while new updates keep coming and install... Thank you in advance for any suggestions. I know it's community-maintained image for Oragepi3LTS but hope there is some workaround for armbian-config 0 Quote
