hexzhen3x7 Posted November 16, 2024 Posted November 16, 2024 Dear Community, Everytime I build a new Armbian OS, it comes with "configng" which dosent support the Feature to enable I2C, SPI & UART, the category "Hardware" isnt available in my build. How can I add the armbian-config to my automated build-system which adds the armbian-config with support of enabling this? I add a picture of the armbian-config, which comes with the currently build. At "system" is an entry with "armv7l" , but I build the OS for sunxi8. What I need to do, to support the Hardware entry in my armbian-config? 0 Quote
hexzhen3x7 Posted November 16, 2024 Author Posted November 16, 2024 I Found the Entry, which was in "Hardware" in the old armbian-config. Now it seems to be categorised in Devicetree Overlays, is this right? 0 Quote
Werner Posted November 16, 2024 Posted November 16, 2024 Old armbian-config is deprecated. Correct way would be to fix the issue in the ng version. 0 Quote
hexzhen3x7 Posted November 16, 2024 Author Posted November 16, 2024 Do you know how i can add sun8i-r40-i2c0 , I2c1 & w1-gpio? 0 Quote
going Posted November 16, 2024 Posted November 16, 2024 3 часа назад, hexzhen3x7 сказал: Do you know how i can add sun8i-r40-i2c0 , I2c1 & w1-gpio? There's only one way. You need to write these overlays yourself. Then compile them and put them in the target folder of overlays. After that, they will appear for selection in the configurator window. After you test them and be sure that they are correct, you can call me @going and publish the sources of these overlays here and I will add them to the build system. 0 Quote
