I've already enabled audio-codec in the overlays section
I've checked https://linux-sunxi.org/Linux_mainlining_effort#Status_Matrix and saw that audio-codec is supported for h3 since 4.10
Required Information: Linux orangepizero 4.11.9-sun8i #3 SMP Sat Jul 15 00:20:53 CEST 2017 armv7l armv7l armv7l GNU/Linux
-->arecord -l shows this
pi@orangepizero:~$ arecord -l
**** List of CAPTURE Hardware Devices ****
card 0: Codec [H3 Audio Codec], device 0: CDC PCM Codec-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
--> running the following command will just hang all the way till ctrl+c is entered
pi@orangepizero:~$ arecord -d 5 /tmp/test-mic.wav
Recording WAVE '/tmp/test-mic.wav' : Unsigned 8 bit, Rate 8000 Hz, Mono
--> This will ask me to put in some formats
pi@orangepizero:~$ arecord -D hw:0,0 -d 10 /tmp/test-mic.wav
arecord: set_params:1233: Sample format non available
Available formats:
- S16_LE
- S32_LE
--> The following will result in an error
pi@orangepizero:~$ arecord -f S16_LE -D hw:0,0 -d 10 /tmp/test-mic.wav
Recording WAVE '/tmp/test-mic.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Mono
arecord: pcm_read:2032: read error: Input/output error
Any one managed to enable arecord in mainline??
Thanks!
Problem solved.
For Mainline, do this
1) alsamixer
2) press TAB (Make sure it falls to F4: CAPTURE)
3) Move to Mic1 (Use arrow keys)
4) Press SPACE and (L R Capture will appear)
Quit and you are good to go.
On 8/23/2017 at 9:33 PM, kutysam said:
Problem solved.
 1) alsamixer
Hi! Earlier I had arecord: pcm_read:2032: read error: Input/output error when I'm trying to record. After I did some modifications which you mentioned above, it worked! :) (gives no error and terminates after times up when I set a time duration). But when I'm trying to play that audio using aplay test2.wav I got an error saying that test2.wav: No such file or directory. But the file already exists. So how can I sort it out? :( Thanks! :)
Sometimes you have to have to add ./ befor the filename even when you are in the actual directory of the file.
So if you did a arecord with the filename ./test2.wav then you also should use the same filename for aplay e.g.
aplay ./test2.wav
or you could give a complete path to the arecord and aplay like /temp/test2.wav
aplay ./test2.wav
I tried! But it didnt work! :( But when I execute dir, it shows the file
