backing up SD to filename.img
Rein
Hi, I am running Armbian Jessie (4.11.6-sunxi) on Banana Pi M1.
For reading and writing SD cards I use linux dd cmd on another box.
I do not have a Windows system.
My question is this: My SD card is a 16Gb device. With gparted I can reduce the size of the system to a partition that would easily fit on a 4Gb device.
But when writing the .img file dd will still see and write an image of 16 Gb
There must be a way to make an image that can be written to and booted from a smaller device to save resources on the backup disk.
Can anyone point me in the right direction ?
Link to comment
Share on other sites
Using "truncate" with the "endsect" number shown by fdisk after gparted shrinking.
Here is the sequence :
sudo modprobe loop
sudo losetup -f
sudo losetup /dev/loop0 myimage.img
sudo partprobe /dev/loop0
sudo gparted /dev/loop0
sudo losetup -d /dev/loop0
fdisk -l myimage.img
sudo truncate --size=$[(endsect+1)*512] myimage.img
Link to comment
Thank you, martinayotta, I'll try this today ! As I understand it I still have to make an imagefile of the full 16Gb before I can shrink it to below 4Gb. Maybe you can confirm this?
Link to comment
