i have a problem whit usb wifi dongle rtl8192cu, from latest armbian desktop in network manager show the essid network but it's impossible connection!
board: Orangepipc
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.4.113-sun8i (root@devel) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) ) #16 SMP PREEMPT Tue Jun 13 14:15:57 CEST 2017
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: sun8i
[    0.000000] cma: CMA: reserved 256 MiB at 50000000
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] On node 0 totalpages: 262144
[    0.000000] free_area_init_node: node 0, pgdat c098d5c0, node_mem_map c0ac6000
[    0.000000]   Normal zone: 1710 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 192850 pages, LIFO batch:31
[    0.000000]   HighMem zone: 594 pages used for memmap
[    0.000000]   HighMem zone: 66990 pages, LIFO batch:15
[    0.000000] script_init enter!
[    0.000000] script_init exit!
[    0.000000] PERCPU: Embedded 8 pages/cpu @c13dc000 s11968 r8192 d12608 u32768
[    0.000000] pcpu-alloc: s11968 r8192 d12608 u32768 alloc=8*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 259840
[    0.000000] Kernel command line: root=UUID=08833519-b742-4494-a900-22da45d06026 rootwait rootfstype=ext4 console=tty1 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1 ubootpart=e27f69c7-01 ubootsource=mmc   cgroup_enable=memory swapaccount=1
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] allocated 2097152 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 1024MB = 1024MB total
[    0.000000] Memory: 757312k/757312k available, 291264k reserved, 270336K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc08ce730   (8986 kB)
[    0.000000]       .init : 0xc08cf000 - 0xc0921ec0   ( 332 kB)
[    0.000000]       .data : 0xc0922000 - 0xc0991e30   ( 448 kB)
[    0.000000]        .bss : 0xc09925e4 - 0xc0ac5a00   (1230 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Additional per-CPU info printed with stalls.
[    0.000000] NR_IRQS:544
[    0.000000] Architected local timer running at 24.00MHz.
[    0.000000] Switching to timer-based delay loop
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.000265] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.000289] pid_max: default: 32768 minimum: 301
[    0.000454] Security Framework initialized
[    0.000478] AppArmor: AppArmor disabled by boot time parameter
[    0.000666] Mount-cache hash table entries: 512
[    0.001656] Initializing cgroup subsys cpuacct
[    0.001673] Initializing cgroup subsys memory
[    0.001718] Initializing cgroup subsys devices
[    0.001731] Initializing cgroup subsys freezer
[    0.001744] Initializing cgroup subsys blkio
[    0.001768] Initializing cgroup subsys perf_event
[    0.001853] CPU: Testing write buffer coherency: ok
[    0.001895] ftrace: allocating 24815 entries in 73 pages
[    0.030313] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.030330] [sunxi_smp_prepare_cpus] enter
[    0.030367] Setting up static identity map for 0x4061df18 - 0x4061df70
[    0.031329] CPU1: Booted secondary processor
[    0.031329] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.031460] CPU2: Booted secondary processor
[    0.031460] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.040504] CPU3: Booted secondary processor
[    0.040504] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.040624] Brought up 4 CPUs
[    0.040624] SMP: Total of 4 processors activated (19200.00 BogoMIPS).
[    0.040920] devtmpfs: initialized
[    0.051791] wakeup src cnt is : 2.
[    0.051803] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.051814] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x0
[    0.051825] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40
[    0.051836] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.051847] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x8
[    0.051857] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40
[    0.051869] sunxi pm init
[    0.052014] pinctrl core: initialized pinctrl subsystem
[    0.062190] NET: Registered protocol family 16
[    0.063120] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.063120] script_sysfs_init success
[    0.063120] sunxi_dump_init success
[    0.063120] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl
[    0.063120] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.063120] plat: add bmp085 device
[    0.063120] plat: add pcf8591 device
[    0.063120] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.063120] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.063120] script config pll_video to 297 Mhz
[    0.063120] script config pll_de to 864 Mhz
[    0.063120] script config pll_ve to 402 Mhz
[    0.063120] sunxi_default_clk_init
[    0.063120] try to set pll6ahb1 to 200000000
[    0.063120] try to set ahb clk source to pll6ahb1
[    0.063120] set ahb clk source to pll6ahb1
[    0.063120] try to set ahb1 to 200000000
[    0.063120] try to set apb1 to 100000000
[    0.070242] bio: create slab <bio-0> at 0
[    0.070313] [ARISC] :sunxi-arisc driver v1.04
[    0.091549] [ARISC] :arisc version: [v0.1.58]
[    0.181507] [ARISC] :sunxi-arisc driver v1.04 startup succeeded
[    0.183122] SCSI subsystem initialized
[    0.183122] usbcore: registered new interface driver usbfs
[    0.183122] usbcore: registered new interface driver hub
[    0.183122] usbcore: registered new device driver usb
[    0.183122] twi_chan_cfg()340 - [twi0] has no twi_regulator.
[    0.183122] twi_chan_cfg()340 - [twi1] has no twi_regulator.
[    0.183122] twi_chan_cfg()340 - [twi2] has no twi_regulator.
[    0.183122] Linux video capture interface: v2.00
[    0.183122] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.183122] cfg80211: Calling CRDA to update world regulatory domain
[    0.183122] NetLabel: Initializing
[    0.183122] NetLabel:  domain hash size = 128
[    0.183122] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.183122] NetLabel:  unlabeled traffic allowed by default
[    0.183122] Switching to clocksource arch_sys_counter
[    0.193510] FS-Cache: Loaded
[    0.193810] CacheFiles: Loaded
[    0.205197] NET: Registered protocol family 2
[    0.216423] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.217033] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.218797] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[    0.219851] TCP: Hash tables configured (established 131072 bind 65536)
[    0.219863] TCP: reno registered
[    0.219876] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.219914] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.220308] NET: Registered protocol family 1
[    0.220736] RPC: Registered named UNIX socket transport module.
[    0.220749] RPC: Registered udp transport module.
[    0.220757] RPC: Registered tcp transport module.
[    0.220766] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.220976] Trying to unpack rootfs image as initramfs...
[    0.555869] Freeing initrd memory: 5040K
[    0.556373] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available
[    0.556503] sunxi_reg_init enter
[    0.557443] audit: initializing netlink socket (disabled)
[    0.557500] type=2000 audit(0.550:1): initialized
[    0.558751] highmem bounce pool size: 64 pages
[    0.559123] VFS: Disk quotas dquot_6.5.2
[    0.559313] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.559875] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.560106] misc fatfs initialized
[    0.560322] NFS: Registering the id_resolver key type
[    0.560746] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.560761] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.561540] NTFS driver 2.1.30 [Flags: R/W].
[    0.561851] fuse init (API version 7.18)
[    0.562272] msgmni has been set to 1472
[    0.563744] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.563762] io scheduler noop registered
[    0.563771] io scheduler deadline registered
[    0.563835] io scheduler cfq registered (default)
[    0.564242] [DISP]disp_module_init
[    0.564549] cmdline,init_disp=
[    0.564581] cmdline,disp=
[    0.580303] [DISP] Fb_map_kernel_logo,line:932:Fb_map_kernel_logo failed!
[    0.616179] Console: switching to colour frame buffer device 240x67
[    0.652923] [DISP]disp_module_init finish
[    0.653159] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[    0.653481] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.653494] sw_uart_pm()890 - uart0 clk is already enable
[    0.653513] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n
[    0.653654] console [ttyS0] enabled
[    0.654209] sunxi_cmatest_init enter
[    0.654248] sunxi_cmatest_init success
[    0.658387] brd: module loaded
[    0.662400] loop: module loaded
[    0.662703] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[    0.662718] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
[    0.663302] spi spi0: master is unqueued, this is deprecated
[    0.664390] PPP generic driver version 2.4.2
[    0.664588] PPP BSD Compression module registered
[    0.664599] PPP Deflate Compression module registered
[    0.667478] PPP MPPE Compression module registered
[    0.667496] NET: Registered protocol family 24
[    0.667576] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.687689] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.687726] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    0.688329] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    0.700047] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    0.700738] hub 1-0:1.0: USB hub found
[    0.700763] hub 1-0:1.0: 1 port detected
[    0.721139] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.721167] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus number 2
[    0.721605] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000
[    0.740034] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00
[    0.740579] hub 2-0:1.0: USB hub found
[    0.740602] hub 2-0:1.0: 1 port detected
[    0.760965] sunxi-ehci sunxi-ehci.3: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.760992] sunxi-ehci sunxi-ehci.3: new USB bus registered, assigned bus number 3
[    0.761393] sunxi-ehci sunxi-ehci.3: irq 108, io mem 0xf1c1c000
[    0.780031] sunxi-ehci sunxi-ehci.3: USB 0.0 started, EHCI 1.00
[    0.780046] ehci_irq: highspeed device connect
[    0.780548] hub 3-0:1.0: USB hub found
[    0.780573] hub 3-0:1.0: 1 port detected
[    0.800935] sunxi-ehci sunxi-ehci.4: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.800964] sunxi-ehci sunxi-ehci.4: new USB bus registered, assigned bus number 4
[    0.801349] sunxi-ehci sunxi-ehci.4: irq 110, io mem 0xf1c1d000
[    0.820028] sunxi-ehci sunxi-ehci.4: USB 0.0 started, EHCI 1.00
[    0.820042] ehci_irq: highspeed device connect
[    0.820589] hub 4-0:1.0: USB hub found
[    0.820609] hub 4-0:1.0: 1 port detected
[    0.820984] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.841066] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    0.841095] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 5
[    0.841128] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    0.904554] hub 5-0:1.0: USB hub found
[    0.904575] hub 5-0:1.0: 1 port detected
[    0.924948] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    0.924976] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus number 6
[    0.925007] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400
[    0.984605] hub 6-0:1.0: USB hub found
[    0.984625] hub 6-0:1.0: 1 port detected
[    1.005037] sunxi-ohci sunxi-ohci.3: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.005066] sunxi-ohci sunxi-ohci.3: new USB bus registered, assigned bus number 7
[    1.005109] sunxi-ohci sunxi-ohci.3: irq 109, io mem 0xf1c1c400
[    1.064605] hub 7-0:1.0: USB hub found
[    1.064625] hub 7-0:1.0: 1 port detected
[    1.085061] sunxi-ohci sunxi-ohci.4: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.085089] sunxi-ohci sunxi-ohci.4: new USB bus registered, assigned bus number 8
[    1.085121] sunxi-ohci sunxi-ohci.4: irq 111, io mem 0xf1c1d400
[    1.100039] usb 3-1: new high-speed USB device number 2 using sunxi-ehci
[    1.144530] hub 8-0:1.0: USB hub found
[    1.144550] hub 8-0:1.0: 1 port detected
[    1.144893] Initializing USB Mass Storage driver...
[    1.145127] usbcore: registered new interface driver usb-storage
[    1.145138] USB Mass Storage support registered.
[    1.145199] usbcore: registered new interface driver ums-alauda
[    1.145247] usbcore: registered new interface driver ums-cypress
[    1.145299] usbcore: registered new interface driver ums-datafab
[    1.145345] usbcore: registered new interface driver ums_eneub6250
[    1.145391] usbcore: registered new interface driver ums-freecom
[    1.145447] usbcore: registered new interface driver ums-isd200
[    1.145493] usbcore: registered new interface driver ums-jumpshot
[    1.145539] usbcore: registered new interface driver ums-karma
[    1.145588] usbcore: registered new interface driver ums-onetouch
[    1.145649] usbcore: registered new interface driver ums-realtek
[    1.145700] usbcore: registered new interface driver ums-sddr09
[    1.145748] usbcore: registered new interface driver ums-sddr55
[    1.145796] usbcore: registered new interface driver ums-usbat
[    1.146006]  uinput result 0 , vmouse_init
[    1.146631] mousedev: PS/2 mouse device common for all mice
[    1.146847] sunxikbd_init failed.
[    1.147613] ls_fetch_sysconfig_para: type err  device_used = -1073057456.
[    1.147623] =========script_get_err============
[    1.147632] ltr_init: ls_fetch_sysconfig_para err.
[    1.148203] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    1.148252] i2c /dev entries driver
[    1.148653] sunxi cedar version 0.1
[    1.148694] [cedar]: install start!!!
[    1.148898] [cedar]: install end!!!
[    1.149142] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x18)
[    1.149313] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x19)
[    1.149483] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    1.149651] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x29)
[    1.149820] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    1.149989] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    1.150184] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    1.150351] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    1.150516] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    1.150713] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18)
[    1.150904] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19)
[    1.151096] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    1.151287] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x29)
[    1.151479] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    1.151670] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    1.151861] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    1.152052] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    1.152244] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    1.152258] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[    1.152421] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[    1.152575] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[    1.152588] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[    1.152599] timeout_to_interv, line 167
[    1.152607] interv_to_timeout, line 189
[    1.152617] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[    1.153040] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    1.153269] calibrat: max_cpufreq 1200Mhz Type 0!
[    1.153592] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.111 2015-4-13 15:24) Compiled in Jun 13 2017 at 14:14:41
[    1.153625] [mmc]: get mmc0's sdc_power is null!
[    1.153654] [mmc]: get mmc1's sdc_power is null!
[    1.153664] [mmc]: get mmc1's 2xmode ok, val = 1
[    1.153673] [mmc]: get mmc1's ddrmode ok, val = 1
[    1.153689] [mmc]: MMC host used card: 0x3, boot card: 0x0, io_card 2
[    1.157285] [mmc]: sdc0 power_supply is null
[    1.159142] no blue_led, ignore it!
[    1.159377] Registered led device: red_led
[    1.159490] Registered led device: green_led
[    1.159504] no led_0, ignore it!
[    1.159512] no led_1, ignore it!
[    1.159519] no led_2, ignore it!
[    1.159526] no led_3, ignore it!
[    1.159533] no led_4, ignore it!
[    1.159540] no led_5, ignore it!
[    1.159547] no led_6, ignore it!
[    1.159554] no led_7, ignore it!
[    1.160476] usbcore: registered new interface driver usbhid
[    1.160488] usbhid: USB HID core driver
[    1.164633] asoc: sndcodec <-> sunxi-codec mapping ok
[    1.165694] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly!
[    1.165890] [I2S]snddaudio cannot find any using configuration for controllers, return directly!
[    1.165904] [DAUDIO0] driver not init,just return.
[    1.169005] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok
[    1.170330] oprofile: using arm/armv7-ca7
[    1.170537] u32 classifier
[    1.170545]     Performance counters on
[    1.170552]     input device check on
[    1.170559]     Actions configured
[    1.170877] TCP: bic registered
[    1.170887] TCP: cubic registered
[    1.170895] TCP: westwood registered
[    1.170903] TCP: highspeed registered
[    1.170911] TCP: hybla registered
[    1.170918] TCP: htcp registered
[    1.170926] TCP: vegas registered
[    1.170933] TCP: veno registered
[    1.170941] TCP: scalable registered
[    1.170948] TCP: lp registered
[    1.170955] TCP: yeah registered
[    1.170963] TCP: illinois registered
[    1.170970] Initializing XFRM netlink socket
[    1.171193] NET: Registered protocol family 10
[    1.172299] NET: Registered protocol family 17
[    1.172331] NET: Registered protocol family 15
[    1.172378] Registering the dns_resolver key type
[    1.172824] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    1.172848] ThumbEE CPU extension supported.
[    1.172871] Registering SWP/SWPB emulation handler
[    1.173451] registered taskstats version 1
[    1.173904] cmdline,disp=
[    1.174206] [HDMI] power vcc-hdmi-18
[    1.205277] ths_fetch_sysconfig_para: type err  device_used = 1.
[    1.206508] CPU Budget:corekeeper enabled
[    1.206734] CPU Budget:Register notifier
[    1.206746] CPU Budget:register Success
[    1.206760] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0
[    1.210153] [rf_pm]: module power0 name vcc-wifi-33
[    1.210169] [rf_pm]: Did not config module_power1 in sys_config
[    1.210180] [rf_pm]: Did not config module_power2 in sys_config
[    1.210190] [rf_pm]: Did not config module_power3 in sys_config
[    1.210200] [rf_pm]: mod has no chip_en gpio
[    1.210208] [rf_pm]: failed to fetch lpo_use_apclk
[    1.210216] [rf_pm]: regulator on.
[    1.210226] [wifi_pm]: no wifi used in configuration
[    1.210237] [rfkill]: init no bt used in configuration
[    1.210245] ALSA device list:
[    1.210252]   #0: audiocodec
[    1.210259]   #1: sndhdmi
[    1.211231] Freeing init memory: 328K
[    1.223384] mmc0: new SDHC card at address 0001
[    1.224001] mmcblk0: mmc0:0001 TO 29.1 GiB
[    1.226280]  mmcblk0: p1
[    1.226952] mmcblk mmc0:0001: Card claimed for testing.
[    1.226974] mmc0:0001: TO 29.1 GiB
[    1.251772] hub 3-1:1.0: USB hub found
[    1.251939] hub 3-1:1.0: 4 ports detected
[    1.370085] usb 4-1: new high-speed USB device number 2 using sunxi-ehci
[    1.521068] vmouse_input_dev_open
[    1.600088] usb 3-1.1: new low-speed USB device number 3 using sunxi-ehci
[    1.600136] vmouse_input_dev_close
[    1.724951] generic-usb 0003:046E:55A5.0001: input,hidraw0: USB HID v1.10 Keyboard [BTC USB Multimedia Keyboard] on usb-sunxi-ehci-1.1/input0
[    1.735374] generic-usb 0003:046E:55A5.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [BTC USB Multimedia Keyboard] on usb-sunxi-ehci-1.1/input1
[    1.810065] usb 3-1.3: new low-speed USB device number 4 using sunxi-ehci
[    1.810078] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device0, type=4, mode=10
[    1.933237] generic-usb 0003:046D:C51B.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-sunxi-ehci-1.3/input0
[    1.936475] generic-usb 0003:046D:C51B.0004: hiddev0,hidraw3: USB HID v1.11 Device [Logitech USB Receiver] on usb-sunxi-ehci-1.3/input1
[    2.003154] Btrfs loaded
[    2.010126] usb 3-1.4: new high-speed USB device number 5 using sunxi-ehci
[    2.121736] hub 3-1.4:1.0: USB hub found
[    2.122212] hub 3-1.4:1.0: 2 ports detected
[    2.505037] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    3.302355] systemd[1]: System time before build time, advancing clock.
[    3.820298] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[    3.820643] systemd[1]: Detected architecture arm.
[    3.851857] systemd[1]: Set hostname to <orangepipc>.
[    4.512801] systemd[1]: Reached target Remote File Systems (Pre).
[    4.530467] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    4.550221] systemd[1]: Reached target User and Group Name Lookups.
[    4.570159] systemd[1]: Reached target Encrypted Volumes.
[    4.590623] systemd[1]: Created slice User and Session Slice.
[    4.610435] systemd[1]: Listening on Journal Socket (/dev/log).
[    4.630170] systemd[1]: Reached target Remote File Systems.
[    4.650847] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    4.670535] systemd[1]: Created slice System Slice.
[    4.690200] systemd[1]: Reached target Slices.
[    4.710609] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    4.730526] systemd[1]: Listening on Journal Audit Socket.
[    4.750425] systemd[1]: Started Trigger resolvconf update for networkd DNS.
[    4.770337] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    4.790273] systemd[1]: Listening on fsck to fsckd communication Socket.
[    4.810316] systemd[1]: Listening on Journal Socket.
[    4.910616] systemd[1]: Starting Restore / save the current clock...
[    5.080778] systemd[1]: Starting Load Kernel Modules...
[    5.210951] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    5.323818] [mmc]: sdc1 power_supply is null
[    5.375190] [mmc]: sdc1 power_supply is null
[    5.379297] [mmc]: sdc1 power_supply is null
[    5.390430] systemd[1]: Mounting Debug File System...
[    5.422273] [wifi_pm]: set wl_reg_on 1 !
[    5.437042] UMP: UMP device driver  loaded
[    5.438731] [mmc]: sdc1 power_supply is null
[    5.442674] [mmc]: sdc1 power_supply is null
[    5.465434] mali clk: 252 MHz
[    5.465664] mali clk: 252 MHz
[    5.467664] Mali: Mali device driver loaded
[    5.505318] [mmc]: sdc1 power_supply is null
[    5.509429] [mmc]: sdc1 power_supply is null
[    5.520779] systemd[1]: Starting Set console keymap...
[    5.582050] [mmc]: sdc1 power_supply is null
[    5.730466] systemd[1]: Mounting POSIX Message Queue File System...
[    5.750660] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    5.770312] systemd[1]: Reached target Paths.
[    5.880526] systemd[1]: Starting Nameserver information manager...
[    5.900468] systemd[1]: Listening on Syslog Socket.
[    6.080691] systemd[1]: Starting Remount Root and Kernel File Systems...
[    6.100496] systemd[1]: Listening on udev Control Socket.
[    6.120401] systemd[1]: Listening on udev Kernel Socket.
[    6.208335] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[    6.293464] systemd[1]: Mounted Debug File System.
[    6.310316] systemd[1]: Mounted POSIX Message Queue File System.
[    6.480134] systemd[1]: Started Restore / save the current clock.
[    6.620157] systemd[1]: Started Load Kernel Modules.
[    6.770131] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    6.910138] systemd[1]: Started Set console keymap.
[    7.440197] systemd[1]: Started Remount Root and Kernel File Systems.
[    7.620772] systemd[1]: Started Nameserver information manager.
[    7.684449] systemd[1]: Time has been changed
[    8.007975] systemd[1]: Reached target Network (Pre).
[    8.080741] systemd[1]: Starting Load/Save Random Seed...
[    8.220816] systemd[1]: Starting udev Coldplug all Devices...
[    8.370528] systemd[1]: Activating swap /var/swap...
[    8.490799] systemd[1]: Starting Create Static Device Nodes in /dev...
[    8.502754] Adding 131068k swap on /var/swap.  Priority:-1 extents:1 across:131068k SS
[    8.600421] systemd[1]: Mounting FUSE Control File System...
[    8.710677] systemd[1]: Starting Apply Kernel Variables...
[    8.737726] systemd[1]: Activated swap /var/swap.
[    8.753910] systemd[1]: Mounted FUSE Control File System.
[    9.020160] systemd[1]: Started Load/Save Random Seed.
[    9.310331] systemd[1]: Started Create Static Device Nodes in /dev.
[    9.470157] systemd[1]: Started Apply Kernel Variables.
[    9.610134] systemd[1]: Started udev Coldplug all Devices.
[    9.666314] systemd[1]: Reached target Local File Systems (Pre).
[    9.790388] systemd[1]: Mounting /tmp...
[    9.940776] systemd[1]: Starting udev Kernel Device Manager...
[    9.960225] systemd[1]: Reached target Swap.
[   10.035552] systemd[1]: Mounted /tmp.
[   10.170780] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   10.190811] systemd[1]: Reached target Local File Systems.
[   10.300772] systemd[1]: Starting Set console font and keymap...
[   10.480661] systemd[1]: Starting Raise network interfaces...
[   10.525270] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x77)
[   10.525313] bmp085: probe of 0-0077 failed with error -70
[   10.546033] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x48)
[   10.546250] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x48)
[   10.570890] systemd[1]: Starting Armbian enhanced Log2Ram...
[   10.620856] systemd[1]: Started udev Kernel Device Manager.
[   10.643852] vmouse_input_dev_open
[   10.720159] vmouse_input_dev_close
[   11.149952] systemd[1]: Found device /dev/ttyS0.
[   11.286690] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   11.303263] rtl8192cu: Chip version 0x11
[   11.310606] systemd[1]: Reached target Sound Card.
[   11.406659] rtl8192cu: MAC address: 30:b5:c2:12:ac:59
[   11.406684] rtl8192cu: Board Type 0
[   11.406896] rtlwifi: rx_max_size 15360, rx_urb_num 8, in_ep 1
[   11.407029] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw.bin
[   11.407566] usbcore: registered new interface driver rtl8192cu
[   11.440860] systemd[1]: Started ifup for eth0.
[   11.587659] Error: Driver 'rtl8192cu' is already registered, aborting...
[   11.620385] systemd[1]: Started Set console font and keymap.
[   11.642502] systemd[1]: Found device /sys/subsystem/net/devices/eth0.
[   11.661206] systemd[1]: Created slice system-getty.slice.
[   11.770161] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[   11.777200] rtlwifi: wireless switch is on
[   11.871036] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   12.060285] systemd[1]: Started Armbian enhanced Log2Ram.
[   12.161092] systemd[1]: Starting Journal Service...
[   12.232894] systemd[1]: Started Load/Save RF Kill Switch Status.
[   12.300483] systemd[1]: Started Journal Service.
[   12.368442] gmac0: probed
[   12.368793] gmac0 gmac0: eth0: eth0: PHY ID 00441400 at 0 IRQ poll (gmac0-0:00)
[   12.530793] systemd-journald[460]: Received request to flush runtime journal from PID 1
[   15.360287] PHY: gmac0-0:00 - Link is Up - 100/Full
[   21.169259] rtl8192cu: MAC auto ON okay!
[   21.201949] rtl8192cu: Tx queue select: 0x05
[   21.621366] ADDRCONF(NETDEV_UP): wlx30b5c212ac59: link is not ready
[   22.400666] [DISP] disp_ioctl,line:1584:para err in disp_ioctl, cmd = 0x0,screen id = 65536
[   22.639514] [drm] Initialized drm 1.1.0 20060810
[   22.667294] Mali DRM initialize, driver name: mali_drm, version 2.1
[   22.669836] [drm] Initialized mali_drm 2.1.1 20101111 on minor 0
[   22.670558] Mali DRM initialize, driver name: mali_drm, version 2.1
[   22.677620] [drm] Initialized mali_drm 2.1.1 20101111 on minor 1
[   25.385660] vmouse_input_dev_open
[   61.946358] Error: Driver 'rtl8192cu' is already registered, aborting...
[   73.558023] Error: Driver 'rtl8192cu' is already registered, aborting...
stefano@orangepipc:~$ lsusb
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 002: ID 0bda:8178 Realtek Semiconductor Corp. RTL8192CU 802.11n WLAN Adapter
Bus 003 Device 005: ID 0451:8142 Texas Instruments, Inc. TUSB8041 4-Port Hub
Bus 003 Device 004: ID 046d:c51b Logitech, Inc. V220 Cordless Optical Mouse for Notebooks
Bus 003 Device 003: ID 046e:55a5 Behavior Tech. Computer Corp.
Bus 003 Device 002: ID 0451:8142 Texas Instruments, Inc. TUSB8041 4-Port Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
1 hour ago, Sterium said:
Make command show lot of error...
You have to show us errors, that we are able to help you.
