Hi all,
seeking some assistance kinder stuck on this.
So i have managed to install it on Rocky Linux 9 ok with "dnf install wireguard-tools" configured it fine and upto nearly last step however stuck here trying to start with "systemctl start wg-quick@wg0"
getting this error:
[root@localhost ~]# sudo systemctl start wg-quick@wg0
Job for wg-quick@wg0.service failed because the control process exited with error code.
See "systemctl status wg-quick@wg0.service" and "journalctl -xeu wg-quick@wg0.service" for details.
When I check sudo journalctl -u wg-quick@wg0
I see this:
Starting WireGuard via wg-quick(8) for wg0...
Dec 08 00:52:40 localhost wg-quick[51890]: [#] ip link add wg0 type wireguard
Dec 08 00:52:40 localhost wg-quick[51890]: [#] wg setconf wg0 /dev/fd/63
Dec 08 00:52:40 localhost wg-quick[51890]: [#] ip -4 address add 10.0.0.4/24 dev wg0
Dec 08 00:52:40 localhost wg-quick[51890]: [#] ip link set mtu 1420 up dev wg0
Dec 08 00:52:40 localhost wg-quick[51913]: [#] resolvconf -a wg0 -m 0 -x
Dec 08 00:52:40 localhost wg-quick[51917]: mkdir: cannot create directory '/run/resolvconf': Permission denied
Dec 08 00:52:40 localhost wg-quick[51915]: Failed to create needed directory /run/resolvconf
Dec 08 00:52:40 localhost wg-quick[51890]: [#] ip link delete dev wg0
Dec 08 00:52:41 localhost systemd[1]: wg-quick@wg0.service: Main process exited, code=exited, status=1/FAILURE
Dec 08 00:52:41 localhost systemd[1]: wg-quick@wg0.service: Failed with result 'exit-code'.
Dec 08 00:52:41 localhost systemd[1]: Failed to start WireGuard via wg-quick(8) for wg0.
Now, I have already created folder /run/resolvconf with su permission still can get it to start..
Any guidance on this please ?
I am missing something... ?
many thanks
