Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable - Kernel 6.6.60-current-odroidxu4
I used the Armbian 24.11.1 Bookworm Minimal / IOT  Image from https://www.armbian.com/odroid-xu4/.
When i checked the boot messages with journalctl -b, then i can see the message -> "system vulnerable"
Later i can read the message "Spectre BHB: enabling loop workaround for all CPUs".
Is this a fix for the first warning message, or is my system vulnerable?
Dec 16 20:32:58 odroidxu4 kernel: smp: Bringing up secondary CPUs ...
Dec 16 20:32:58 odroidxu4 kernel: CPU1: thread -1, cpu 1, socket 1, mpidr 80000101
Dec 16 20:32:58 odroidxu4 kernel: CPU2: thread -1, cpu 2, socket 1, mpidr 80000102
Dec 16 20:32:58 odroidxu4 kernel: CPU3: thread -1, cpu 3, socket 1, mpidr 80000103
Dec 16 20:32:58 odroidxu4 kernel: CPU4: thread -1, cpu 0, socket 0, mpidr 80000000
Dec 16 20:32:58 odroidxu4 kernel: CPU4: detected I-Cache line size mismatch, workaround enabled
Dec 16 20:32:58 odroidxu4 kernel: CPU4: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
Dec 16 20:32:58 odroidxu4 kernel: CPU4: Spectre BHB: enabling loop workaround for all CPUs
Dec 16 20:32:58 odroidxu4 kernel: CPU5: thread -1, cpu 1, socket 0, mpidr 80000001
Dec 16 20:32:58 odroidxu4 kernel: CPU5: detected I-Cache line size mismatch, workaround enabled
Dec 16 20:32:58 odroidxu4 kernel: CPU5: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
Dec 16 20:32:58 odroidxu4 kernel: CPU6: thread -1, cpu 2, socket 0, mpidr 80000002
Dec 16 20:32:58 odroidxu4 kernel: CPU6: detected I-Cache line size mismatch, workaround enabled
Dec 16 20:32:58 odroidxu4 kernel: CPU6: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
Dec 16 20:32:58 odroidxu4 kernel: CPU7: thread -1, cpu 3, socket 0, mpidr 80000003
Dec 16 20:32:58 odroidxu4 kernel: CPU7: detected I-Cache line size mismatch, workaround enabled
Dec 16 20:32:58 odroidxu4 kernel: CPU7: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
Dec 16 20:32:58 odroidxu4 kernel: smp: Brought up 1 node, 8 CPUs
Dec 16 20:32:58 odroidxu4 kernel: SMP: Total of 8 processors activated (384.00 BogoMIPS).
Dec 16 20:32:58 odroidxu4 kernel: CPU: All CPU(s) started in HYP mode.
Dec 16 20:32:58 odroidxu4 kernel: CPU: Virtualization extensions available.
Thank you for the tip and the link.
Unfortunately, the test shows that I cannot operate the hardware safely with the current Armbian software 😞
The second link with the reference to a new kernel 6.14 or 6.15 refers to arm64. I can't really make the connection either, it sounds really complicated to me and not like a simple solution.
Is there any hope that next year the kernel version will be so far along at Armbian that I can simply leave the hardware unused in storage for the time being?
Does anyone have any other practical ideas on how I can operate the hardware safely?
./spectre-meltdown-checker.sh
Spectre and Meltdown mitigation detection tool v0.46+
Checking for vulnerabilities on current system
Kernel is Linux 6.6.60-current-odroidxu4 #1 SMP PREEMPT Wed Nov 13 22:00:09 UTC 2024 armv7l
CPU is ARM v7 model 0xc07
Hardware check
* CPU vulnerability to the speculative execution attack variants
  * Affected by CVE-2017-5753 (Spectre Variant 1, bounds check bypass):  YES
  * Affected by CVE-2017-5715 (Spectre Variant 2, branch target injection):  YES
  * Affected by CVE-2017-5754 (Variant 3, Meltdown, rogue data cache load):  NO
  * Affected by CVE-2018-3640 (Variant 3a, rogue system register read):  YES
  * Affected by CVE-2018-3639 (Variant 4, speculative store bypass):  NO
  * Affected by CVE-2018-3615 (Foreshadow (SGX), L1 terminal fault):  NO
  * Affected by CVE-2018-3620 (Foreshadow-NG (OS), L1 terminal fault):  NO
  * Affected by CVE-2018-3646 (Foreshadow-NG (VMM), L1 terminal fault):  NO
  * Affected by CVE-2018-12126 (Fallout, microarchitectural store buffer data sampling (MSBDS)):  NO
  * Affected by CVE-2018-12130 (ZombieLoad, microarchitectural fill buffer data sampling (MFBDS)):  NO
  * Affected by CVE-2018-12127 (RIDL, microarchitectural load port data sampling (MLPDS)):  NO
  * Affected by CVE-2019-11091 (RIDL, microarchitectural data sampling uncacheable memory (MDSUM)):  NO
  * Affected by CVE-2019-11135 (ZombieLoad V2, TSX Asynchronous Abort (TAA)):  NO
  * Affected by CVE-2018-12207 (No eXcuses, iTLB Multihit, machine check exception on page size changes (MCEPSC)):  NO
  * Affected by CVE-2020-0543 (Special Register Buffer Data Sampling (SRBDS)):  NO
  * Affected by CVE-2023-20593 (Zenbleed, cross-process information leak):  NO
  * Affected by CVE-2022-40982 (Downfall, gather data sampling (GDS)):  NO
  * Affected by CVE-2023-20569 (Inception, return address security (RAS)):  NO
  * Affected by CVE-2023-23583 (Reptar, redundant prefix issue):  NO
CVE-2017-5753 aka 'Spectre Variant 1, bounds check bypass'
* Mitigated according to the /sys interface:  YES  (Mitigation: __user pointer sanitization)
* Kernel has array_index_mask_nospec:  YES  (112 occurrence(s) found of arm 32 bits array_index_mask_nospec())
* Kernel has the Red Hat/Ubuntu patch:  NO
* Kernel has mask_nospec64 (arm64):  NO
* Kernel has array_index_nospec (arm64):  NO
> STATUS:  NOT VULNERABLE  (Mitigation: __user pointer sanitization)
CVE-2017-5715 aka 'Spectre Variant 2, branch target injection'
* Mitigated according to the /sys interface:  NO  (Vulnerable: Unprivileged eBPF enabled)
* Mitigation 1
  * Kernel is compiled with IBRS support:  YES
    * IBRS enabled and active:  NO
  * Kernel is compiled with IBPB support:  NO
    * IBPB enabled and active:  NO
* Mitigation 2
  * Kernel has branch predictor hardening (arm):  YES
  * Kernel compiled with retpoline option:  NO
> STATUS:  NOT VULNERABLE  (Branch predictor hardening mitigates the vulnerability)
CVE-2017-5754 aka 'Variant 3, Meltdown, rogue data cache load'
* Mitigated according to the /sys interface:  YES  (Not affected)
* Kernel supports Page Table Isolation (PTI):  NO
  * PTI enabled and active:  NO
  * Reduced performance impact of PTI:  NO  (PCID/INVPCID not supported, performance impact of PTI will be significant)
* Running as a Xen PV DomU:  NO
> STATUS:  NOT VULNERABLE  (your CPU vendor reported your CPU model as not affected)
CVE-2018-3640 aka 'Variant 3a, rogue system register read'
* CPU microcode mitigates the vulnerability:  NO
> STATUS:  VULNERABLE  (an up-to-date CPU microcode is needed to mitigate this vulnerability)
CVE-2018-3639 aka 'Variant 4, speculative store bypass'
* Kernel supports disabling speculative store bypass (SSB):  YES  (found in /proc/self/status)
* SSB mitigation is enabled and active:  NO
CVE-2018-3615 aka 'Foreshadow (SGX), L1 terminal fault'
* CPU microcode mitigates the vulnerability:  N/A
CVE-2018-3620 aka 'Foreshadow-NG (OS), L1 terminal fault'
* Kernel supports PTE inversion:  NO
* PTE inversion enabled and active:  NO
CVE-2018-3646 aka 'Foreshadow-NG (VMM), L1 terminal fault'
* Information from the /sys interface: Not affected
* This system is a host running a hypervisor:  NO
* Mitigation 1 (KVM)
  * EPT is disabled:  N/A  (the kvm_intel module is not loaded)
* Mitigation 2
  * L1D flush is supported by kernel:  NO
  * L1D flush enabled:  NO
  * Hardware-backed L1D flush supported:  NO  (flush will be done in software, this is slower)
  * Hyper-Threading (SMT) is enabled:  UNKNOWN
CVE-2018-12126 aka 'Fallout, microarchitectural store buffer data sampling (MSBDS)'
* Kernel supports using MD_CLEAR mitigation:  NO
* Kernel mitigation is enabled and active:  NO
* SMT is either mitigated or disabled:  NO
CVE-2018-12130 aka 'ZombieLoad, microarchitectural fill buffer data sampling (MFBDS)'
CVE-2018-12127 aka 'RIDL, microarchitectural load port data sampling (MLPDS)'
CVE-2019-11091 aka 'RIDL, microarchitectural data sampling uncacheable memory (MDSUM)'
CVE-2019-11135 aka 'ZombieLoad V2, TSX Asynchronous Abort (TAA)'
* TAA mitigation is supported by kernel:  YES  (found tsx_async_abort in kernel image)
* TAA mitigation enabled and active:  NO
CVE-2018-12207 aka 'No eXcuses, iTLB Multihit, machine check exception on page size changes (MCEPSC)'
* iTLB Multihit mitigation is supported by kernel:  YES  (found itlb_multihit in kernel image)
* iTLB Multihit mitigation enabled and active:  NO
CVE-2020-0543 aka 'Special Register Buffer Data Sampling (SRBDS)'
* SRBDS mitigation control is supported by the kernel:  NO
* SRBDS mitigation control is enabled and active:  NO
CVE-2023-20593 aka 'Zenbleed, cross-process information leak'
* Zenbleed mitigation is supported by kernel:  NO
* Zenbleed kernel mitigation enabled and active:  N/A  (CPU is incompatible)
* Zenbleed mitigation is supported by CPU microcode:  NO
CVE-2022-40982 aka 'Downfall, gather data sampling (GDS)'
* GDS is mitigated by microcode:  NO
* Kernel supports software mitigation by disabling AVX:  YES  (found gather_data_sampling in kernel image)
* Kernel has disabled AVX as a mitigation:  UNKNOWN  (No sign of mitigation in dmesg and couldn't read cpuid info)
CVE-2023-20569 aka 'Inception, return address security (RAS)'
* Kernel supports mitigation:  YES  (found spec_rstack_overflow in kernel image)
* Kernel compiled with SRSO support:  NO  (required for safe RET and ibpb_on_vmexit mitigations)
* Kernel compiled with IBPB_ENTRY support:  NO
CVE-2023-23583 aka 'Reptar, redundant prefix issue'
> SUMMARY: CVE-2017-5753:OK CVE-2017-5715:OK CVE-2017-5754:OK CVE-2018-3640:KO CVE-2018-3639:OK CVE-2018-3615:OK CVE-2018-3620:OK CVE-2018-3646:OK CVE-2018-12126:OK CVE-2018-12130:OK CVE-2018-12127:OK CVE-2019-11091:OK CVE-2019-11135:OK CVE-2018-12207:OK CVE-2020-0543:OK CVE-2023-20593:OK CVE-2022-40982:OK CVE-2023-20569:OK CVE-2023-23583:OK
https://developer.arm.com/Arm Security Center/Speculative Processor Vulnerability
In general, it is not believed that software mitigations for this issue are necessary. However, an update for the latest release of the Cortex-A72 does include a hardware mitigation for this issue.
On the bottom line there is nothing we can do about this. If mitigation is upstreamed to ATF, Kernel or wherever needed/possible Armbian will adapt it most likely automatically.
Dug a bit deeper
https://developer.arm.com/-/media/Arm Developer Community/PDF/Security update 21 May 18/Software_Overview_for_Arm_Cores_PUBLIC v1.2.pdf?revision=7bb9a901-9a1d-4975-b460-743f5da90502&hash=14B19D60AC5650AF05225AEECC5E3D816E08B47B
In Linux this is mitigated by KPTI[...]
https://cateee.net/lkddb/web-lkddb/MITIGATION_PAGE_TABLE_ISOLATION.html
Though this seems to be a software mitigation for x86 only. No clue if there is further development ongoing.
