Slamtilt Posted December 6, 2015 Posted December 6, 2015 Hi, I installed latest Jessie desktop version on Cubox i4Pro but audio via HDMI still does not work... Any solution? Thanks
Igor Posted December 6, 2015 Posted December 6, 2015 I think that default audio is SPDIF. Have you switched alsa output to HDMI?
Da Alchemist Posted December 9, 2015 Posted December 9, 2015 HDMI is hw:1 I have an aother Issue with sound via HDMI .I am using Armbian_4.5_Cubox-i_Debian_wheezy_3.14.54 on a Hummingboard. Sound with MPD crashes after 30 Minutes "Uptime", i can not even run speaker-test after the crash. Regards
Igor Posted December 10, 2015 Posted December 10, 2015 HDMI sound crash ... That "sounds" strange. The kernel I am using is more or less stock + upgrades to .54 which should not have affect on this. I'll double check. Please address this issue to Solidrun if they have any clue about it.
Da Alchemist Posted December 10, 2015 Posted December 10, 2015 I will do some further tests today, to check if this issue has nothing to do with my AVR.
Da Alchemist Posted December 10, 2015 Posted December 10, 2015 I think i have got it. I usually use SSH to control the machine. After 30 minutes of inactivity on the "real Machine" the Monitor is going to sleep, that means cutting of the HDMI Signal. Today I have plugged in a Keyboard and did some Inputs, Music is playing for over 1 hour now. Is there some trick to avoid the Monitor from going to sleep? Edit: In /etc/kbd/keyboard i found the entry POWERDOWN_TIME=30 . I will test other values.
Igor Posted December 10, 2015 Posted December 10, 2015 Also the consoleblank=0 could / should do the job if you are using CLI console. For X is another story.
Da Alchemist Posted December 10, 2015 Posted December 10, 2015 I have set POWER_DOWN_TIME=3000 and uptime is 4:30 h at the moment; i think my problem is solved. 1
