Rodolphe Posted June 3, 2015 Share Posted June 3, 2015 Hello, I'm a newbie an Linux and bananaPI. Actually, i uses an debian wheezy image of Igor's (Bananapi_Debian_2.8_wheezy_3.4.107) with openmediavault and one sata drive. I would like add an sata multiplier on my BananaPI. I find this tuto : http://www.htpcguides.com/rebuild-bananian-kernel-with-sata-port-multiplier-support/ I don't know if this procedure works an the debian image of Igor's ? please confirme me I think the line " git clone https://github.com/Bananian/linux-bananapi.git--depth 1 " isn't good ? Link to comment Share on other sites More sharing options...
blindpet Posted June 3, 2015 Share Posted June 3, 2015 Hello, I'm a neewbee an Linux and bananaPI. Actually, i uses an debian wheezy image of Igor's (Bananapi_Debian_2.8_wheezy_3.4.107) with openmediavault and one sata drive. I would like add an sata multiplier on my BananaPI. I find this tuto : http://www.htpcguides.com/rebuild-bananian-kernel-with-sata-port-multiplier-support/ I don't know if this procedure works an the debian image of Igor's ? please confirme me I think the line " git clone https://github.com/Bananian/linux-bananapi.git--depth 1 " isn't good ? For modular PMP support you need to use mainline 3.19.7 (4.0 may work but I haven't tested) Link to comment Share on other sites More sharing options...
Rodolphe Posted June 4, 2015 Author Share Posted June 4, 2015 Ok thank Blindpet, now the better solution is - Downgrade the Kernel 3.4.107 to 3.19.7 (I don't know if it's possible) - Download the Bananapi_Debian_2.8_wheezy_3.19.7 (From Igor's) and apply the modification : http://www.htpcguides.com/rebuild-bananian-kernel-with-sata-port-multiplier-support/ But i think isn't a good way because the github link is Kernel 3.4.104 version Or (better solution I think) - Build a new image with dirrectly the modification : http://www.htpcguides.com/build-debian-image-for-banana-pi-pro-sata-port-multiplier/ but an the file "build.sh" i don't find the line KERNELTAG="v3.19.7" Link to comment Share on other sites More sharing options...
Rodolphe Posted June 5, 2015 Author Share Posted June 5, 2015 Ok I try this solution : - Download the Bananapi_Debian_2.8_wheezy_3.19.7 (From Igor's) and apply the modification : http://www.htpcguide...iplier-support/ And It's works , i see the 2 hard drives in openmediavault. But I have a new problem. I create a new EXT4 partition on one disk, and when I clic on mount i have an error : Failed to mount .. mount: wrong fs type, bad optionoption, bad superblock.. Link to comment Share on other sites More sharing options...
Igor Posted June 5, 2015 Share Posted June 5, 2015 Did you format the partition? mkfs.ext4 /dev/your-device Link to comment Share on other sites More sharing options...
Rodolphe Posted June 5, 2015 Author Share Posted June 5, 2015 I will try this command and all done. I return on openmediavault, i see the partition file EXT4. It's always impossible to mount but little different error message. At the end it's write ( try dmesg |tail). I will try and the result is SDA: unknown partition table Link to comment Share on other sites More sharing options...
Rodolphe Posted June 5, 2015 Author Share Posted June 5, 2015 I have find a solution, but it's not beautiful. I have created a partition ext2 with mke2fs. And after it's possible to mount this partition on openmediavault. Link to comment Share on other sites More sharing options...
