I have a new Orange Pi 5 plus 16GB. Seems a pretty cool board and I want to replace my old Rpi 4 for Media center and Home assistant.
I tried several distribution but can't get all my stuff working.
The OPI5+ is attached to an onkio 5.1 receiver and the receiver go to a FHD TV.
What is want to achieve is
in Kodi
1. play video with GPU
2. libCec in Kodi to control Onkio volume
3. Passthrough audio
Is there a working solution?
Thank you
I don't think there is an oob solution.
Though using an Armbian image with mesa-vpu extension should give a solid base for video hw acceleration.
thanks guys
I am trying
Armbian_24.11.2_Orangepi5-plus_noble_vendor_6.1.75_kde-neon-kisak_desktop
kde is running with wayland
glmark2 is using panfrost driver
kodi worked with HW accell after installing mesa vulkan driver and enabling DRM Prime
I must run kodi with
KODI_AE_SINK=ALSA kodi
otherwise I don't have hdmi0 output. And kodi is running from kde with "-fs" flag
With alsamixer I changed the channel PATHs because channels are incorrent, my setup for 5.1 is PATH2-PATH0-PATH1 (I think PATH3 is not used, maybe it's for 7.1)
Now I am missing CEC connection. Maybe I can try with another kernel or some overlay?
How can I change only the kernel? maybe with the suggested 6.1.84?
To ease dependency maintenance, I've used the flatpak kodi on a different rk3588 SBC - works well, but surround sound is not something i've spent time on (i'm happy with stereo)
The only gotcha, is migrating your kodi settings to the flatpak storage location, which is a bit funky
~/.var/app/tv.kodi.Kodi/
See https://flathub.org/apps/tv.kodi.Kodi for install details
this results in the attached kodi startup log which you can inspect for the current configured capabilities:
kodi.log
I am using Kodi since years with armbian on orange pi 5 and also orange pi 5 plus. I followed instruction, installed armbian of august I think with the vendor kernel and the Wayland version. The Install come with all hardware video acceleration installed. Then simply install Kodi and configured it.
It is working great.
I also rebuilt kernel in order to have my satellite tuners working.
Great platform not too many issues.
Hi Tony3.
Could you please give me a link of the image?
My other attempt was with kernel 6.12, video is accelerated but I am missing hdmi0 audio output.
Gave a try to collab kernel -board freeze- and edge, same with current
thank you
ok. My first working kodi configuration is with
Armbian_24.8.1_Orangepi5-plus_noble_vendor_6.1.75_gnome-kisak_desktop
any kernel above have a problem with HW rendering or audio output (alsa doesn't show hdmi output).
I managed to have a working HDMI CEC in kodi upgrading the package to libcec6_6.0.2-5_arm64 downloaded from bookworm.
Currently I'm happy with kodi but I have no audio from normal desktop, will give a try disabling pulseaudio.
2 часа назад, Dome сказал:
I'm very curious how you managed to make it work. With Armbian_24.11.2_Orangepi5-plus_noble_vendor_6.1.75_gnome-kisak_desktop, hardware video acceleration works fine for me, but HDMI audio doesn't work, and with Armbian_24.8.1_Orangepi5-plus_noble_vendor_6.1.75_gnome-kisak_desktop, Kodi only shows a black screen instead of the main menu and spams error <general>: CDRMAtomic::DrmAtomicCommit - atomic commit failed: Invalid argument in the logs.
Hi Werner.
Using the kernel in your image I have a problem with Hardware rendering: I can select DRM Prime but when I play h264 videos I got artifacts and the player doesn't go in foreground.
So Andrey, did you use the image provided by Werner? with HDMI audio 5.1 from Kodi?
Yes, I used the image, provided by Werner. I don't have 5.1 speakers, only 2.1, so I can't check, but H.264 video plays well and shows rkmpp decoder in info. I installed mesa-vulkan-drivers, configured alsa and startup as described in the guide , set KODI_AE_SINK=ALSA in the .desktop file, also installed vop.dts from royk's post. In Kodi settings I set "Allow using DRM PRIME decoder", "Allow hardware acceleration with DRM PRIME" and "Direct To Plane" as per guide.
04.01.2025 в 18:02, Dome сказал:
Can you tell me if you did any additional steps to get CEC working? I installed the package you specified, Kodi detects CEC, but the remote doesn't work.
You can enable and configure cec in Settings - System - Input - Peripherals.
And you must enable cec on the device you want to control, in my case the 5.1 system. The name in device menu depends on manufacturer. My Onkyo has HDMI Control. Aquos link on old Sharp. Anynet+ for Samsung
I can control volume with + and - keys
04.02.2025 в 03:06, Dome сказал:
Yes, I did that, but only changing the HDMI port helped. Now I can control Kodi with my TV remote via CEC.
