TRay Posted January 15, 2025 Posted January 15, 2025 Look at the description https://docs.armbian.com/User-Guide_Armbian_overlays/ when I set UART I2C in armbianEnv.txt it should be overlay_prefix=sun50i-h616 overlays=i2c3-ph uart5-ph as described on the given page But when I use armbian-config and go to Manage Overlays my settings are not seen and I have to set them but the names of all overlays are preceded by the prefix. After selecting and saving the settings in armbinEnv.txt it is overlay_prefix=sun50i-h616 overlays=sun50i-h616-i2c3-ph sun50i-h616-uart5-ph as a result the defined overlays are not loaded Is it supposed to be like this? I use OrangePi Zero 3 with updated system Welcome to Armbian_community 25.2.0-trunk.331 Bookworm Kernel Linux 6.6.70-current-sunxi64 0 Quote
Werner Posted January 15, 2025 Posted January 15, 2025 duplicate of https://github.com/armbian/configng/issues/360 ? 0 Quote
TRay Posted January 15, 2025 Author Posted January 15, 2025 Hi Werner, I don't know, this problem has been reported on github but I'm writing on the forum because more people read it and maybe have a similar problem I understand that on github the only solution to this problem is ? The fix currently (as I put in the forum post) is to edit the overlay names in armbianEnv.txt, removing the prefix. 0 Quote
