WiFi driver extension radxa-aic8800.sh breaks Rock 5C vendor kernel boot.
Go to solution Solved by schwar3kat,
I compiled Armbian Rock-5c bookworm vendor 6.1.99 minimal.
WiFi driver extension radxa-aic8800.sh breaks Rock 5C vendor (kernel 6.1.99) boot.
I compiled without the extension to confirm.
The radxa-aic8800 driver has recently been modified in the download source.
I modified radxa-aic8800.sh to download the previous driver version "3.0+git20240327.3561b08f-2" and this does not fix the issue.
Ref: Jira AR-2603
Logs attached.
Any fix or insight would be good.
@amazingfate  is this something that you might have ideas about?
armbian-hardware-monitor.log rock5c-debug.log
Quote
How does this relate to Armbian build for vendor kernel?  Does it need to be patched or will move by some workflow?
This commit should be in the source tree if you are using the latest code. I have no idea why the issue happens again. I will check it later.
I am using the latest code.  Thanks for your response and for checking later.
