Jorge Cury Posted February 12, 2025 Posted February 12, 2025 Hi everybody, I installed Deb 12 Cinnamon Armbian flavor on an Orange PI 5 and Orange PI 5 Plus. This: dl.armbian.com/orangepi5-plus/Bookworm_current_cinnamon-backported-mesa I want to test 'virt-manager' but qemu is not available for installation. Error on console: packages are updated me@orangepi5-plus:~$ sudo apt install qemu [sudo] senha me: Lendo listas de pacotes... Pronto Construindo árvore de dependências... Pronto Lendo informação de estado... Pronto package qemu is not available, mas é referenciado por outro pacote. Isto pode significar que o pacote está faltando, ficou obsoleto ou está disponível somente a partir de outra fonte E: O pacote 'qemu' não tem candidato para instalação Is there a chance to have qemu available. armbianmonitor -u https://paste.next.armbian.com/egexohofom Thanks, Cury 0 Quote
Werner Posted February 12, 2025 Posted February 12, 2025 There is no package simply called qemu: https://packages.debian.org/search?keywords=qemu&searchon=names&suite=bookworm§ion=all 0 Quote
eselarm Posted February 12, 2025 Posted February 12, 2025 12 hours ago, Jorge Cury said: me@orangepi5-plus:~$ sudo apt install qemu you need to do: sudo apt install virt-manager Then it should also have installed qemu-system-arm package which contains the core virtualization program for 32-bit and 64-bit Virtual machines that you can create and run with/via virt-manager GUI. Note tha you run vendor 6.1.x kernel on big-LITTLE rk3588 SoC, it will fail/crash any VM if more than 1 core allocated or not fixed the CPU types in the VM (xml code). So best to just use 1 core. Otherwhise switch to mainline/current 6.12+ kernel, there the bug/problem is fixed. 0 Quote
