dwarfman78 Posted February 21 Posted February 21 Hi, I'm trying to get h264 encoding working but VAINFO keeps searching for rockchip_drv_video.so which is nowhere to be found on my system. Is there a way to get h264 encoding working with armbian OR do I have to use radxa oses (or the ubuntu version provided by Joshua Riek) ? Thanks. 0 Quote
Werner Posted February 21 Posted February 21 Try building an image with vendor kernel and mesa-vpu extension enabled. Not sure if a pre-built one is available. 0 Quote
eselarm Posted February 21 Posted February 21 On 2/21/2025 at 11:34 AM, dwarfman78 said: Is there a way to get h264 encoding working with armbian Expand What I did for both NanoPi-R6C and Rock3A is install linux-image-vendor-rk35xx and jellyfin-ffmpeg7 The Zero 3W is rk3566 and should have upto 1080p60 H264 real-time encoding speed if you use h264_rkmpp as output codec. Note that this is only CLI and file and/or stream based transcoding. I have no clue if it works in a webbrowser with camera and/or videoconferencing. 0 Quote
dwarfman78 Posted February 25 Author Posted February 25 On 2/21/2025 at 12:35 PM, Werner said: Try building an image with vendor kernel and mesa-vpu extension enabled. Not sure if a pre-built one is available. Expand Thanks, I am already using the latest vendor kernel, is there a way to enable mesa-vpu extension afterward or do I have to recompile the kernel entirely ? 0 Quote
dwarfman78 Posted February 25 Author Posted February 25 (edited) vainfo --display drm --device /dev/dri/renderD128 | grep -E "((VAProfileH264High|VAProfileHEVCMain|VAProfileHEVCMain10).*VAEntrypointEncSlice)|Driver version" libva info: VA-API version 1.20.0 libva info: Trying to open /usr/lib/aarch64-linux-gnu/dri/rockchip_drv_video.so libva info: va_openDriver() returns -1 vaInitialize failed with error code -1 (unknown libva error),exit vainfo --display drm --device /dev/dri/renderD129 | grep -E "((VAProfileH264High|VAProfileHEVCMain|VAProfileHEVCMain10).*VAEntrypointEncSlice)|Driver version" libva info: VA-API version 1.20.0 libva info: Trying to open /usr/lib/aarch64-linux-gnu/dri/panfrost_drv_video.so libva info: va_openDriver() returns -1 vaInitialize failed with error code -1 (unknown libva error),exit Those files are not found : sudo find / -name "*_drv_video.so" /usr/lib/aarch64-linux-gnu/dri/radeonsi_drv_video.so /usr/lib/aarch64-linux-gnu/dri/d3d12_drv_video.so /usr/lib/aarch64-linux-gnu/dri/nouveau_drv_video.so /usr/lib/aarch64-linux-gnu/dri/virtio_gpu_drv_video.so /usr/lib/aarch64-linux-gnu/dri/r600_drv_video.so Edited February 25 by dwarfman78 0 Quote
Werner Posted February 26 Posted February 26 On 2/25/2025 at 7:21 PM, dwarfman78 said: is there a way to enable mesa-vpu extension afterward or do I have to recompile the kernel entirely ? Expand Unfortunately no. But this is basically what happens while building when this extension is enabled: https://github.com/armbian/build/blob/main/extensions/mesa-vpu.sh 0 Quote
maka Posted February 26 Posted February 26 There is rockchip-vdec2 in edge images that gives you support for h264. 0 Quote
dwarfman78 Posted February 26 Author Posted February 26 I've found this repository which provides the VAAPI driver : https://github.com/qqdasb/libva-rkmpp vainfo --display drm --device /dev/dri/renderD128 | grep -E "((VAProfileH264High|VAProfileHEVCMain|VAProfileHEVCMain10).*VAEntrypointEncSlice)|Driver version" libva info: VA-API version 1.20.0 libva info: Trying to open /usr/lib/aarch64-linux-gnu/dri/rockchip_drv_video.so libva info: Found init function __vaDriverInit_1_20 libva info: va_openDriver() returns 0 vainfo: Driver version: Rockchip Driver 1.0 However I have a new error : libva info: VA-API version 1.20.0 libva info: Trying to open /usr/lib/aarch64-linux-gnu/dri/rockchip_drv_video.so libva info: Found init function __vaDriverInit_1_20 libva info: va_openDriver() returns 0 [2025-02-26 23:58:44.486]: Info: vaapi vendor: Rockchip Driver 1.0 [2025-02-26 23:58:44.487]: Error: [AVHWFramesContext @ 0xaaaae273d480] Failed to create surface: 10 (attribute not supported). [2025-02-26 23:58:44.487]: Error: [AVHWFramesContext @ 0xaaaae273d480] Unable to allocate a surface from internal buffer pool. [2025-02-26 23:58:44.492]: Info: Encoder [vaapi] failed 0 Quote
eselarm Posted February 27 Posted February 27 (edited) On 2/26/2025 at 10:59 PM, dwarfman78 said: [2025-02-26 23:58:44.487]: Error: [AVHWFramesContext @ 0xaaaae273d480] Failed to create surface: 10 (attribute not supported). Expand Can you maybe tell us what your (end-user) use case is? It might be simply that some feature in HW codec is not supported. What do you feed the encoder and how? And what is your base working method if SW encoding ? Maybe that must be done non-real-time and is that the reason you want HW? How can others reproduce? Also that github is 9 years old. I see some V4L2, but the whole issue is that Rockchip is not V4L2. They have their own rkmpp standard. Same but worse and/or un-usable stuff from Allwinner. Amlogic I don't know. Qualcomm and RPi are V4L2 and also new Radxa Orion O6 SoC AFAIK. Edited February 27 by eselarm 0 Quote
dwarfman78 Posted February 27 Author Posted February 27 On 2/27/2025 at 1:07 PM, eselarm said: Can you maybe tell us what your (end-user) use case is? It might be simply that some feature in HW codec is not supported. What do you feed the encoder and how? Expand I am trying to stream my display with sunshine (https://app.lizardbyte.dev/Sunshine/) which supports only nvenc,amd vce or vaapi. With software encoding there's only 8 frames per second output and 50% CPU usage. 0 Quote
eselarm Posted February 27 Posted February 27 On https://docs.lizardbyte.dev/projects/sunshine/latest/ I see: Quote with support for AMD, Intel, and Nvidia GPUs for hardware encoding Expand so there is no Rockchip rkmpp, not even ARM. As I indicated, jellyfin has ffmpeg binaries that can use HW encoders in Rockchips https://jellyfin.org/docs/general/administration/hardware-acceleration/rockchip https://repo.jellyfin.org/?path=/ffmpeg/debian/latest-7.x/arm64 Those provide you a core method to grab screen as input and encoded h264 wih e certain container protocol as output. I think output is mostly FLV, RTMP for gaming. I use it for RPi cameras and/with NGINX. Screen/display as input, see ffmpeg docs or see OBS as example. I have no clue what protocol etc sunshine uses. Maybe you configure software encoding but with a script hook somehow with ffmpeg. See how that can be done with MediaMTX for example. 0 Quote
dwarfman78 Posted February 28 Author Posted February 28 That's interesting, I have already successfully compiled ffmpeg with mpp support, I know I can handle inputs with swayvnc and I will look into mediamtx, however I am a bit worried about latency which is critical for my use case. I'll keep you posted. Thanks. 0 Quote
dwarfman78 Posted March 5 Author Posted March 5 (edited) On 2/27/2025 at 9:40 PM, eselarm said: Those provide you a core method to grab screen as input and encoded h264 wih e certain container protocol as output. I think output is mostly FLV, RTMP for gaming. I use it for RPi cameras and/with NGINX. Expand Hi again, somehow I am making progress, I was able to start a headless sway compositor then start recording the screen with wf-recorder which relies on ffmpeg, however, the video file generated has a very low framerate, something like 2 fps. Can you help me ? EDIT : I have plugged the hdmi output to a real display and the overall fps are very low when wf-recorder is running (not only in test.mp4 but also on the real screen), when not recording the framerate is at about 60 fps. here is my sway.cfg : Quote exec WAYLAND_DISPLAY=wayland-1 exec swaymsg create_output HEADLESS-1 exec wf-recorder -y -f test.mp4 -c h264_rkmpp Expand Edited March 5 by dwarfman78 0 Quote
eselarm Posted March 6 Posted March 6 (edited) I can post some piece of test shell script that I used to test live-transcoding DVB-T2, ran on rk3568 and rk3588s with vendor kernel 6.1.x. The input in my case is TVheadend, is a sort of generic HTTP streaming Quote transcode_rkmpp) MEDIAURL=http://vserv.home/npo1 /usr/share/jellyfin-ffmpeg/ffmpeg -y -loglevel info -nostdin\ -t $NUMSECONDS\ -c:v hevc_rkmpp\ -i $MEDIAURL\ -map v\ -c:v h264_rkmpp\ -b:v 8000k\ -c:a aac\ -b:a 128k\ -t $NUMSECONDS\ -f mpegts\ ./npo1.h264.ts Expand Have a good look at ffmpeg comandline options (on ffmpeg docs website ) I would say, it is overwhelming, but take your time to tune and understand it. ffmpeg chooses mpegts as container format if the output file extension is .ts, but I added it now explicitly for you. If you want a RTMP server as output ( e.g. NGINX rtmp://vserv ... ) , use -f flv Note that all containers have options, advantages, restrictions. For this test example, 2x HW coding is used, that was my goal, so up to 60fps 1080p works fine on rk3568 and way more/higher on rk3588s. The CPU has almost nothing to do, only the audio is done in CPU. So you first need to make sure HW codec, not CPU, is used by ffmpeg. Then it still might be that the grabbing of screen is a bottleneck. I have no experiene with sway, wayland doing that on low-end ARM soc. Works OK on fast Intel PC X11 some years ago I used that. Edited March 6 by eselarm 0 Quote
dwarfman78 Posted March 17 Author Posted March 17 Some news about this topic, I have dropped wayland and went back to X11 with Xvfb+ffmpeg with x11grab and h264_rkmpp codec into Janus WebRTC through a RTP output. Let's say it works, it is really slowing down the computer but I manage to stream at 30 fps, I continue my investigations to improve performances. 0 Quote
Solution dwarfman78 Posted March 18 Author Solution Posted March 18 (edited) Ok so here is the definitive solution : You need panfrost so use the correct armbian version with vendor kernel, then you are going to need to compile ffmpeg for rockchip, just follow those instructions : https://github.com/nyanmisaka/ffmpeg-rockchip/wiki/Compilation Once it is done, you might have some performance issues when capturing the screen with either x11 or Wayland, BUT ffmpeg allows you to capture directly from the device through kmsgrab sudo setcap cap_sys_admin+ep /usr/bin/ffmpeg sudo ffmpeg -device /dev/dri/card0 -f kmsgrab -i - -r 60 -vcodec h264_rkmpp -f rtp rtp://localhost:8004 There I am streaming to a rtp server but you can write into a file. Do not forget to use the -vcodec h264_rkmpp which will use hardware encoding through VPU. Edited March 18 by dwarfman78 0 Quote
eselarm Posted March 19 Posted March 19 OK, this is great, sounds logical that KMS somehow needs to be used but I did not realize. A quick test on my NanoPi-R6C dumping to a .ts file (format mpegts) with ffmpeg from the jellyfin ffmpeg7 Debian package works fine, that is: I use multi-user.target, so CLI only, therefore only clear screen with Armbian bash login prompt with blinking cursor. CPU load is almost 0, CPU clock 408Mhz. The Armbian installation is Bookworm with beta repo enabled, and I know it runs KDE Plasma as well since some months (with both latest vendor and latest mainline kernels). I have not looked at panfrost, I probably did half a year ago, but will need to look at my notes. So it is mainly an out-of-the-box action, except the installation of external jellyfin ffmpeg7 which has rkmpp included. There might indeed be performance issues, but that is not really a surprise to me; An RK3566 is a cost-cut, lowest cost RK35xx, only (lower clocked) 4x Cortex-A55, you cannot expect too much of it compared to 4x Cortex-A55 + 4x Cortex-A76 + faster DRAM, etc found in RK3588. It all depends on what else it running, e.g. libreoffice slideshow or a heavy game. 0 Quote
