nobitakun Posted February 26, 2025 Posted February 26, 2025 Hello, I am trying to install Armbian UEFI-x86 into this very small mini PC, but with secure boot enabled it only shows this screen: Disabling the secure boot isn't an option, because every time I turn it off and then turn it on the next morning, the BIOS settings are being reset, then the secure boot is enabled once again (I believe it is intentional, because the CMOS battery only keeps the clock & date). Moreover, I want to use it as a headless computer, so no keyboard will be attached. Is this fixable or Armbian isn't compatible with secure boot? Thanks in advance. 0 Quote
Werner Posted February 26, 2025 Posted February 26, 2025 31 minutes ago, nobitakun said: Is this fixable or Armbian isn't compatible with secure boot? Latter. 0 Quote
nobitakun Posted February 26, 2025 Author Posted February 26, 2025 Ok, thank you for the answer. I will have to use a headless distro compatible with secure boot then. Cheers! 0 Quote
