lyh Posted March 12, 2025 Posted March 12, 2025 The code being compiled is the latest mainline. My compile command: ./compile.sh build BOARD=rock-5b BRANCH=vendor BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_APPGROUPS_SELECTED= DESKTOP_ENVIRONMENT=gnome DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base KERNEL_CONFIGURE=no RELEASE=noble ENABLE_EXTENSIONS=mesa-vpu It has not been compiled successfully and is stuck here. I am in China and have used a VPN. Sometimes it compiles successfully, but after installation, the 3D acceleration feature is not detected. In the GNOME settings, it shows as LLVM software rendering. Installing 3D extension packages [ mesa-vpu ] [🚸] WARNING: SDCARD /var/cache/apt dir is not empty [ before 'apt-get --no-install-recommends install libgl1-mesa-dri libglx-mesa0 mesa-utils mesa-utils-extra glmark2 glmark2-wayland glmark2-es2-wayland glmark2-es2 glmark2-x11 glmark2-es2-x11 chromium rockchip-multimedia-config chromium libv4l-rkmpp gstreamer1.0-rockchip libwidevinecdm0' :: /home/qqq/lyh/v24_11_build/.tmp/rootfs-1777ddf6-77e5-4225-bf2d-2f8abff527ae/var/cache/apt (2 files) ] [🔨] /home/qqq/lyh/v24_11_build/.tmp/rootfs-1777ddf6-77e5-4225-bf2d-2f8abff527ae/var/cache/apt: [🔨] total 3.9M [🔨] drwxrwxr-x 2 root root 4.0K Mar 12 18:57 . [🔨] -rw-r--r-- 1 root root 2.3M Mar 12 18:57 pkgcache.bin [🔨] -rw-r--r-- 1 root root 1.6M Mar 12 18:57 srcpkgcache.bin [🔨] drwxr-xr-x 13 root root 4.0K Mar 12 18:37 .. [🔨] E: Unable to correct problems, you have held broken packages. [🚸] Command failed, retrying in 5s [ chroot_sdcard_apt_get_install libgl1-mesa-dri libglx-mesa0 mesa-utils mesa-utils-extra glmark2 glmark2-wayland glmark2-es2-wayland glmark2-es2 glmark2-x11 glmark2-es2-x11 chromium rockchip-multimedia-config chromium libv4l-rkmpp gstreamer1.0-rockchip libwidevinecdm0 ] [🚸] WARNING: SDCARD /var/cache/apt dir is not empty [ before 'apt-get --no-install-recommends install libgl1-mesa-dri libglx-mesa0 mesa-utils mesa-utils-extra glmark2 glmark2-wayland glmark2-es2-wayland glmark2-es2 glmark2-x11 glmark2-es2-x11 chromium rockchip-multimedia-config chromium libv4l-rkmpp gstreamer1.0-rockchip libwidevinecdm0' :: /home/qqq/lyh/v24_11_build/.tmp/rootfs-1777ddf6-77e5-4225-bf2d-2f8abff527ae/var/cache/apt (2 files) ] [🔨] /home/qqq/lyh/v24_11_build/.tmp/rootfs-1777ddf6-77e5-4225-bf2d-2f8abff527ae/var/cache/apt: [🔨] total 3.9M [🔨] drwxrwxr-x 2 root root 4.0K Mar 12 18:57 . [🔨] -rw-r--r-- 1 root root 2.3M Mar 12 18:57 pkgcache.bin [🔨] -rw-r--r-- 1 root root 1.6M Mar 12 18:57 srcpkgcache.bin [🔨] drwxr-xr-x 13 root root 4.0K Mar 12 18:37 .. [🔨] E: Unable to correct problems, you have held broken packages. [🚸] Command failed, retrying in 5s [ chroot_sdcard_apt_get_install libgl1-mesa-dri libglx-mesa0 mesa-utils mesa-utils-extra glmark2 glmark2-wayland glmark2-es2-wayland glmark2-es2 glmark2-x11 glmark2-es2-x11 chromium rockchip-multimedia-config chromium libv4l-rkmpp gstreamer1.0-rockchip libwidevinecdm0 ] [🚸] WARNING: SDCARD /var/cache/apt dir is not empty [ before 'apt-get --no-install-recommends install libgl1-mesa-dri libglx-mesa0 mesa-utils mesa-utils-extra glmark2 glmark2-wayland glmark2-es2-wayland glmark2-es2 glmark2-x11 glmark2-es2-x11 chromium rockchip-multimedia-config chromium libv4l-rkmpp gstreamer1.0-rockchip libwidevinecdm0' :: /home/qqq/lyh/v24_11_build/.tmp/rootfs-1777ddf6-77e5-4225-bf2d-2f8abff527ae/var/cache/apt (2 files) ] [🔨] /home/qqq/lyh/v24_11_build/.tmp/rootfs-1777ddf6-77e5-4225-bf2d-2f8abff527ae/var/cache/apt: [🔨] total 3.9M [🔨] drwxrwxr-x 2 root root 4.0K Mar 12 18:57 . [🔨] -rw-r--r-- 1 root root 2.3M Mar 12 18:57 pkgcache.bin [🔨] -rw-r--r-- 1 root root 1.6M Mar 12 18:57 srcpkgcache.bin [🔨] drwxr-xr-x 13 root root 4.0K Mar 12 18:37 .. [🔨] E: Unable to correct problems, you have held broken packages. [🚸] Command failed, retrying in 5s [ chroot_sdcard_apt_get_install libgl1-mesa-dri libglx-mesa0 mesa-utils mesa-utils-extra glmark2 glmark2-wayland glmark2-es2-wayland glmark2-es2 glmark2-x11 glmark2-es2-x11 chromium rockchip-multimedia-config chromium libv4l-rkmpp gstreamer1.0-rockchip libwidevinecdm0 ] [🚸] Command failed 3 times, giving up [ chroot_sdcard_apt_get_install libgl1-mesa-dri libglx-mesa0 mesa-utils mesa-utils-extra glmark2 glmark2-wayland glmark2-es2-wayland glmark2-es2 glmark2-x11 glmark2-es2-x11 chromium rockchip-multimedia-config chromium libv4l-rkmpp gstreamer1.0-rockchip libwidevinecdm0 ] [💥] Error 1 occurred in main shell [ at /home/qqq/lyh/v24_11_build/extensions/mesa-vpu.sh:160 post_install_kernel_debs__3d() --> extensions/mesa-vpu.sh:160 post_install_kernel_debs() --> <extension_magic>:222 call_extension_method() --> lib/functions/general/extensions.sh:57 install_distribution_agnostic() --> lib/functions/rootfs/distro-agnostic.sh:309 do_with_logging() --> lib/functions/logging/section-logging.sh:81 build_rootfs_and_image() --> lib/functions/main/rootfs-image.sh:28 full_build_packages_rootfs_and_image() --> lib/functions/main/default-build.sh:36 do_with_default_build() --> lib/functions/main/default-build.sh:42 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:25 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176 main() --> compile.sh:50 ] [💥] Cleaning up [ please wait for cleanups to finish ] [🌿] Unmounting recursively [ SDCARD - be patient ] [🌱] Unmounted OK after 2 attempt(s) [ SDCARD ] [🌿] Unmounting recursively [ MOUNT - be patient ] [🌿] ANSI log file built; inspect it by running: [ less -RS output/logs/log-build-1777ddf6-77e5-4225-bf2d-2f8abff527ae.log.ans ] [🌿] Share log manually (or SHARE_LOG=yes): [ curl --data-binary @output/logs/log-build-1777ddf6-77e5-4225-bf2d-2f8abff527ae.log.ans https://paste.armbian.com/log ] 0 Quote
Werner Posted March 12, 2025 Posted March 12, 2025 Please provide proper logs with the command suggested at the end of the process. 0 Quote
lyh Posted March 13, 2025 Author Posted March 13, 2025 Every time the compilation stops at mesa-vpu.sh during the build process. Attached is the log of the compilation process. Thank you. rk3588.log 0 Quote
Werner Posted March 13, 2025 Posted March 13, 2025 19 hours ago, lyh said: [🌿] Share log manually (or SHARE_LOG=yes): [ curl --data-binary @output/logs/log-build-1777ddf6-77e5-4225-bf2d-2f8abff527ae.log.ans https://paste.armbian.com/log ] This is how to properly provide logs. Cannot reproduce the issue. Build works just fine: https://paste.armbian.de/otajagegij https://fi.mirror.armbian.de/.testing/Armbian-unofficial_25.05.0-trunk_Rock-5b_noble_vendor_6.1.99_gnome_desktop.img.xz My best guess is there is some issue reaching the repository due to firewall/vpn. 0 Quote
lyh Posted March 13, 2025 Author Posted March 13, 2025 I have tried compiling on both a new system with Ubuntu 22.04 (x64) and Ubuntu 24.04 (arm64), but it keeps getting stuck at the mesa-vpu stage. I am located in China. Is there a better way to successfully compile it? I was able to compile it normally a few months ago, but now it’s not working. log-build-5775b9ef-6d5d-4d23-90d7-18deff3e5ae2.log.ans 0 Quote
lyh Posted March 13, 2025 Author Posted March 13, 2025 E: Packages were downgraded and -y was used without --allow-downgrades. 0 Quote
Solution lyh Posted March 14, 2025 Author Solution Posted March 14, 2025 It should be due to my network restrictions. The image compiled using the official Raspberry Pi 5 system is normal. Thank you. 0 Quote
RND Posted March 19, 2025 Posted March 19, 2025 Hey Mesa Repository is currently migrated. Freedesktops Gitlab setup is moving to a new DC, git checkout of Mesa sourcecode will most likley fail. (happend this week to me a bunch of times) "Currently planned outage: 2025-03-16 -> 2025-03-22" Migration Status -> https://maintenance.gitlab.freedesktop.org/ should be fixed next week. Kudos RND 0 Quote
