devmichelcastilho Posted March 16, 2025 Posted March 16, 2025 (edited) Armbianmonitor: https://paste.armbian.com/xuzeyolapi So I'm trying to connect with a UART cable from my PC to the board (OPI3LTS). Here's what I did so far: In desperation, I double checked every connection, to no avail. My devices are powered separately, so only the RX and TX cable are connected, and they are crossed as they should. Set up permissions: sudo chmod 666 /dev/ttyUSB0 Add user to dialout: sudo adduser <user> dialout Install minicom: Set up minicom with the correct address: /dev/ttyUSB0 Set up the correct baud rate (115200 in this case) Turn off flow control Tried connecting via "screen", minicom and putty, all of them just show me a black CLI I can't write in. Help? 🥲 Edited March 16, 2025 by devmichelcastilho 0 Quote
devmichelcastilho Posted May 8, 2025 Author Posted May 8, 2025 Still no clue what's happening... 0 Quote
IBV Posted May 10, 2025 Posted May 10, 2025 Hi, are you using a usb to serial converter or the real serial com port? I did not see any ttyUSB0 listed in your boot log. In case of the real serial com port you should not be using /dev/ttyUSB0, but /dev/ttyS0. 0 Quote
Werner Posted May 11, 2025 Posted May 11, 2025 Using screen is sufficient. No settings besides baud rate (115200 for any Allwinner) need adjustments. As mentioned above make sure your serial device is correct. If you are unsure, simply - unplug - run sudo dmesg -ew - plug in and check output in the terminal with the command above. Also make sure wiring is correct. Ground to ground and rx/tx crossed. 0 Quote
devmichelcastilho Posted May 12, 2025 Author Posted May 12, 2025 Thank you so much for the responses, IBV and Werner! I'm connecting from the PC USB to the SBC serial com port, then attempting to run Screen from the PC. 0 Quote
IBV Posted May 12, 2025 Posted May 12, 2025 Did you also start screen or minicom on the SBC ? For example: screen /dev/ttyS0 115200 And on PC: screen /dev/ttyUSB0 115200 Make sure you use the same speed on both sides. 0 Quote
ag123 Posted July 14, 2025 Posted July 14, 2025 run dmesg, after you plug that uart into the port it should show the usb dongle connected and the port then a few more thiings, bad wires ensure that no matter what you do no data pass over the wires (I've seen this, especially those dupont pin connections) wrong connections ensure that no matter what you do no data pass over the wires. Are you sure you are talking to the correct *pins* and *port* on the host side? lousy dongles ensure that no matter what you do no data pass over the wires, get 'better' ones. oh well, this depends a little on luck, but I used ch340 usb-uart bridges, and they worked just well https://www.aliexpress.com/w/wholesale-ch340-uart.html searching usb uart normally returns a lot of entries https://www.aliexpress.com/w/wholesale-usb-uart.html if one doesn't work, try another oh then there is DTS overlay etc, sometimes that fix is needed bad / no drivers etc (dmesg should show it, on windows your mileage may vary) etc etc the rationale is, if you did it once successfully, either remember how you did it or document it sometimes, alternatives include, connect hdmi to monitor, usb keyboard and mouse and use as alternative console, mileage may vary. 0 Quote
devmichelcastilho Posted July 14, 2025 Author Posted July 14, 2025 I'll try those ag123, thanks! 0 Quote
