zador.blood.stained Posted September 7, 2017 Posted September 7, 2017 On 9/7/2017 at 7:54 PM, jernej said: You don't have such problem? Expand I didn't test desktop images for a while. Which OS release did you use (jessie/xenial/stretch)?
jernej Posted September 7, 2017 Author Posted September 7, 2017 On 9/7/2017 at 7:56 PM, zador.blood.stained said: Which OS release did you use (jessie/xenial/stretch)? Expand Xenial
jernej Posted September 8, 2017 Author Posted September 8, 2017 On 9/7/2017 at 3:11 PM, Da Alchemist said: I have tested HDMI Audio on my Opi +2e, it is limited to 2 channels.(tested with speaker-test) Anyway it is good to know, that there is still developement on H5/H3 Boards. Expand Can you test this patch if it brings multichannel support? http://sprunge.us/YDAN Please note that I didn't do any test besides make sure it compiles. If it works, it is only starting point for implementing proper support since some hacks are made.
Da Alchemist Posted September 8, 2017 Posted September 8, 2017 I have started compiling, it will take some time on my old AMD. I ´ll report back!
zador.blood.stained Posted September 8, 2017 Posted September 8, 2017 On 9/8/2017 at 3:38 PM, jernej said: Can you test this patch if it brings multichannel support? http://sprunge.us/YDAN Expand For me it kills the audio completely: # speaker-test -c2 -D hw:0 Channels count (2) not available for playbacks: Invalid argument speaker-test 1.1.0 Playback device is hw:0 Stream parameters are 48000Hz, S16_LE, 2 channels Using 16 octaves of pink noise Setting of hwparams failed: Invalid argument But at least resolution switching, rotation and mirroring works for all available resolutions after the CMA memory increase. Edit: Forgot to check the dmesg, sorry, will try to repeat the test later. Edit 2: Should channels_min be set to 8? Typo? .stream_name = "Playback", - .channels_min = 2, - .channels_max = 2, + .channels_min = 8, + .channels_max = 8, .rates = SNDRV_PCM_RATE_8000_192000, .formats = SNDRV_PCM_FMTBIT_S16_LE,
jernej Posted September 8, 2017 Author Posted September 8, 2017 On 9/8/2017 at 4:31 PM, zador.blood.stained said: Typo? Expand Yes, please try with 2. Uh, another issue - it will work with only even channel count (2, 4, 6, 8). Currently I'm not at my computer, so it will have to wait. But you can find line with "int lines =..." and round it up instead of round down.
zador.blood.stained Posted September 8, 2017 Posted September 8, 2017 On 9/8/2017 at 4:40 PM, jernej said: Uh, another issue - it will work with only even channel count (2, 4, 6, 8). Currently I'm not at my computer, so it will have to wait. But you can find line with "int lines =..." and round it up instead of round down. Expand I don't think I have anything that can properly receive/decode multi-channel sound anyway. And is this unrelated to odd/even channel count? + switch (hparms->channels) { + case 2: + conf0 = HDMI_AUD_CONF0_I2S_2CHANNEL_ENABLE; + break; + case 4: + conf0 = HDMI_AUD_CONF0_I2S_4CHANNEL_ENABLE; + break; + case 6: + conf0 = HDMI_AUD_CONF0_I2S_6CHANNEL_ENABLE; + break; + case 8: + conf0 = HDMI_AUD_CONF0_I2S_8CHANNEL_ENABLE; + break; + default: + dev_err(dev, "unsupported channels [%d]\n", hparms->channels); + return -EINVAL; }
jernej Posted September 8, 2017 Author Posted September 8, 2017 On 9/8/2017 at 4:48 PM, zador.blood.stained said: And is this unrelated to odd/even channel count? Expand I really have no idea. It is the same issue as in I2S driver. However, that code is taken from Rockchip BSP driver, so it might be right. Did you retry with 2 channels now?
Da Alchemist Posted September 8, 2017 Posted September 8, 2017 Ok, something is happening: ek@orangepiplus2e:~$ speaker-test -D hw:0 -c8 speaker-test 1.1.0 Playback device is hw:0 Stream parameters are 48000Hz, S16_LE, 8 channels Using 16 octaves of pink noise Rate set to 48000Hz (requested 48000Hz) Buffer size range from 32 to 32768 Period size range from 16 to 4096 Using max buffer size 32768 Periods = 4 was set period_size = 4096 was set buffer_size = 32768 0 - Front Left 1 - Front Right 2 - Unknown 3 - Unknown 4 - Unknown 5 - Unknown 6 - Unknown 7 - Unknown Time per period = 23,245443 but: there is no sound on any Channel , just silence. I can here the relays clicking on my AVR and it shows me "Dolby Digital" instead of expected "Multichannel PCM" (that is what i get with my Hummingboard and Raspberry with modified Kernel) I will build a new Kernel with "channels_min = 2" to check if there is sound with only 2 channels.
zador.blood.stained Posted September 8, 2017 Posted September 8, 2017 On 9/8/2017 at 4:55 PM, jernej said: Did you retry with 2 channels now? Expand No errors, but also no sound (only silence and some clicks in one ear).
Da Alchemist Posted September 8, 2017 Posted September 8, 2017 The output of dmesg http://sprunge.us/JJBA
jernej Posted September 8, 2017 Author Posted September 8, 2017 @Da Alchemist I prepared a new patch here: http://sprunge.us/KGMT 2 channels work as before and although my monitor supports only 2 channels, speaker-test -c8 gives me some (white?) noise on channel 1 and channel 8... Please test.
Da Alchemist Posted September 8, 2017 Posted September 8, 2017 Compiling is running! speaker-test gives 2 channel output with 2, 4, 6, 8 channels testing. There is only noise coming from fronts, channel enumeration is different on -c8, active channels are 0 and 7. (possible wrong channel mapping) speaker-test is running without errors. My AVR only indicates the samplerate, no Dolby Digital anymore, but also no Multichannel PCM. On RK3328 (z28) i found something similar, speaker-test without errors, sound only on the fronts (mapping ok). Kwiboo thinks that there are multichannel patches missing on ayufans kernel.
jernej Posted September 9, 2017 Author Posted September 9, 2017 On 9/8/2017 at 7:57 PM, Da Alchemist said: On RK3328 (z28) i found something similar, speaker-test without errors, sound only on the fronts (mapping ok). Expand I took latest code from Rockchip BSP kernel (almost same HDMI controller), so similar result is not surprising. Can you post dmesg? I will take a look if something obvious is missing, but since I don't have soundbar or something similar, I can't promise anything.
Da Alchemist Posted September 9, 2017 Posted September 9, 2017 Here is the output of dmesg http://sprunge.us/KDCP
jernej Posted September 9, 2017 Author Posted September 9, 2017 @zador.blood.stained You follow IRC log closely :). Did you try it out? I don't have access to OrangePi over this weekend...
zador.blood.stained Posted September 9, 2017 Posted September 9, 2017 On 9/9/2017 at 4:33 PM, jernej said: @zador.blood.stained You follow IRC log closely :). Did you try it out? I don't have access to OrangePi over this weekend... Expand Trying to integrate the Mali kernel driver to build in-tree... For some reason it ignores MALI_PLATFORM define in the Makefile. so I'm trying to find a workaround without adding ugly hacks, or rather trying to make hacks less ugly.
jernej Posted September 9, 2017 Author Posted September 9, 2017 On 9/9/2017 at 4:43 PM, zador.blood.stained said: Trying to integrate the Mali kernel driver to build in-tree... Expand Maybe something like I had done for legacy kernel here https://github.com/jernejsk/linux/tree/master/drivers/gpu ?
zador.blood.stained Posted September 9, 2017 Posted September 9, 2017 On 9/9/2017 at 5:24 PM, jernej said: Maybe something like I had done for legacy kernel here https://github.com/jernejsk/linux/tree/master/drivers/gpu ? Expand I believe I've found the docs that state that if Kbuild and Makefile are both present in a directory, then Kbuild is used and Makefile is simply ignored, and my experimentation confirms that. So I just need to clean up the Makefile and source it from Kbuild.
zador.blood.stained Posted September 9, 2017 Posted September 9, 2017 I got it running (more or less), but not without issues - very low subjective performance and kernel driver issues Reveal hidden contents [ 279.692516] Unhandled fault: page domain fault (0x01b) at 0x01e0fa5c [ 279.698873] pgd = eb610000 [ 279.701577] [01e0fa5c] *pgd=befc0835 [ 279.705157] Internal error: : 1b [#1] SMP THUMB2 [ 279.709768] Modules linked in: fuse ir_lirc_codec snd_soc_simple_card snd_soc_simple_card_utils lirc_dev snd_soc_hdmi_codec sunxi_cir sun8i_codec_analog sun4i_codec sun4i_i2s snd_soc_core snd_pcm_dmaengine snd_pcm input_leds evdev snd_timer sun4i_gpadc_iio snd soundcore cpufreq_dt uio_pdrv_genirq uio dw_hdmi_i2s_audio hid_logitech_hidpp hid_logitech_dj sun8i_dw_hdmi dw_hdmi mali sun4i_tcon sun8i_mixer sun4i_drm realtek [ 279.746878] CPU: 2 PID: 3058 Comm: es2gears_x11 Not tainted 4.13.0-sunxi #1 [ 279.753827] Hardware name: Allwinner sun8i Family [ 279.758524] task: eb5a4380 task.stack: eb618000 [ 279.763177] PC is at mali_gp_job_create+0x103/0x4e0 [mali] [ 279.768699] LR is at mali_gp_job_create+0xee/0x4e0 [mali] [ 279.774090] pc : [<bf830178>] lr : [<bf830163>] psr: 40070033 [ 279.780346] sp : eb619ea8 ip : 00000010 fp : ed5d7700 [ 279.785563] r10: ec0101ac r9 : 00000004 r8 : 00000000 [ 279.790780] r7 : 01e0f9f8 r6 : ed710108 r5 : ed7100f8 r4 : ed710000 [ 279.797299] r3 : eb618000 r2 : eb5a4380 r1 : 00040000 r0 : 00000bf2 [ 279.803817] Flags: nZcv IRQs on FIQs on Mode SVC_32 ISA Thumb Segment none [ 279.811114] Control: 50c5387d Table: 6b61006a DAC: 00000051 [ 279.816852] Process es2gears_x11 (pid: 3058, stack limit = 0xeb618210) [ 279.823369] Stack: (0xeb619ea8 to 0xeb61a000) [ 279.827725] 9ea0: ed5d7700 bf83c3f8 00000051 ec010000 00000004 01e0ff20 [ 279.835894] 9ec0: ec1d15c0 00000051 00000004 ffffe000 ed5d7700 ec010000 00000000 01e0f9f8 [ 279.844062] 9ee0: 00000004 00000000 01e02a80 bf83199f 00000004 00000000 01e0f9f8 00000000 [ 279.852230] 9f00: 01e102f0 00000000 be9d40c0 c9e71268 c0188404 eb6a4900 be9d40c0 bf82ae25 [ 279.860399] 9f20: c0188404 c0227857 eb619f60 00000129 c0106424 c02303d7 be9d402c 00000000 [ 279.868567] 9f40: ebd28fc0 00000129 c0106424 c0706075 be9d402c c0706075 00000000 c02303d7 [ 279.876735] 9f60: 00000004 00000000 eb6a4901 00000000 eb6a4900 c0188404 be9d40c0 00000004 [ 279.884903] 9f80: 00000000 c0227ed7 00000000 00000004 00000000 01e102f0 00000036 c0106424 [ 279.893071] 9fa0: eb618000 c0106261 00000004 00000000 00000004 c0188404 be9d40c0 00000000 [ 279.901239] 9fc0: 00000004 00000000 01e102f0 00000036 00000000 00000000 06000003 01e02a80 [ 279.909407] 9fe0: b6fc00fc be9d40ac b6f2dfc3 b6cdada6 00070030 00000004 00000000 00000000 [ 279.917679] [<bf830178>] (mali_gp_job_create [mali]) from [<bf83199f>] (_mali_ukk_pp_and_gp_start_job+0x8e/0x194 [mali]) [ 279.928619] [<bf83199f>] (_mali_ukk_pp_and_gp_start_job [mali]) from [<bf82ae25>] (pp_and_gp_start_job_wrapper+0x14/0x28 [mali]) [ 279.940218] [<bf82ae25>] (pp_and_gp_start_job_wrapper [mali]) from [<c0227857>] (do_vfs_ioctl+0x7f/0x6b8) [ 279.949778] [<c0227857>] (do_vfs_ioctl) from [<c0227ed7>] (SyS_ioctl+0x47/0x50) [ 279.957084] [<c0227ed7>] (SyS_ioctl) from [<c0106261>] (ret_fast_syscall+0x1/0x4c) [ 279.964648] Code: f8c4 6108 f8c4 610c (6e79) b9d1 [ 279.969435] ---[ end trace c5c28b0ee20139fa ]--- Edit: actually es2info crashes and es2gears is stuck not displaying anything, so "working" is relative. I wonder if this issue (or at least one of possible issues) is similar to previous issue on 2GB boards (I'm testing on OPI+2E) Edit 2: same issue on OPi PC, so it's probably not related.
jernej Posted September 9, 2017 Author Posted September 9, 2017 On 9/9/2017 at 6:40 PM, zador.blood.stained said: [ 279.692516] Unhandled fault: page domain fault (0x01b) at 0x01e0fa5c Expand What about this patch: https://github.com/Icenowy/sunxi-mali/blob/master/patches/0009-mali-Fix-user-memory-domain-fault.patch ?
zador.blood.stained Posted September 9, 2017 Posted September 9, 2017 On 9/9/2017 at 7:17 PM, jernej said: What about this patch: https://github.com/Icenowy/sunxi-mali/blob/master/patches/0009-mali-Fix-user-memory-domain-fault.patch ? Expand I thought that Icenowy's mali driver was ready to use out of the box... Guess I should add this patch and try again tomorrow, but I doubt it will fix the performance issues.
jernej Posted September 10, 2017 Author Posted September 10, 2017 @Da Alchemist here is another try: http://sprunge.us/bNaO If it doesn't work, I still have 2 ideas. There is very little difference now with BSP driver, which should support multichannel HDMI audio.
zador.blood.stained Posted September 10, 2017 Posted September 10, 2017 On 9/9/2017 at 7:17 PM, jernej said: What about this patch: https://github.com/Icenowy/sunxi-mali/blob/master/patches/0009-mali-Fix-user-memory-domain-fault.patch ? Expand This doesn't apply cleanly (there is no "deferred_mem_list" - but there is a similar "varying_alloc_list"), and after manual patching it still crashes in mali_gp_job_create
jernej Posted September 10, 2017 Author Posted September 10, 2017 On 9/10/2017 at 9:50 AM, zador.blood.stained said: it still crashes in mali_gp_job_create Expand I will take a look. Can you commit your patches so I can do few tests? Is performance any better?
zador.blood.stained Posted September 10, 2017 Posted September 10, 2017 On 9/10/2017 at 9:55 AM, jernej said: Is performance any better? Expand No. I tried playing with some armsoc settings (like disabling UMP_LOCK) and it still +/- the same, but since CPU DVFS is currently missing performance may be mostly CPU bound. On 9/10/2017 at 9:55 AM, jernej said: Can you commit your patches so I can do few tests? Expand Only Mali kernel driver patch was not pushed (I didn't make a package for libmali yet and copied and symlinked it by hand), and wouldn't it be easier to build it out of tree instead of rebuilding the whole kernel? I think about adding a lot of printk() in mali_gp_job_create to find at least where exactly it crashes, and I probably will be building it out of tree now too.
zador.blood.stained Posted September 10, 2017 Posted September 10, 2017 Also es2_info crashes without producing any kernel messages. Reveal hidden contents root@orangepiplus2e:~# DISPLAY=:0 es2_info EGL_VERSION: 1.4 Linux-r6p0-01rel0 EGL_VENDOR: ARM EGL_EXTENSIONS: EGL_KHR_image, EGL_KHR_image_base, EGL_KHR_image_pixmap, EGL_EXT_image_dma_buf_import, EGL_KHR_gl_texture_2D_image, EGL_KHR_gl_texture_cubemap_image, EGL_KHR_gl_renderbuffer_image, EGL_KHR_reusable_sync, EGL_KHR_fence_sync, EGL_KHR_swap_buffers_with_damage, EGL_EXT_swap_buffers_with_damage, EGL_KHR_lock_surface, EGL_KHR_lock_surface2, EGL_EXT_create_context_robustness, EGL_ANDROID_blob_cache, EGL_KHR_create_context, EGL_KHR_partial_update EGL_CLIENT_APIS: OpenGL_ES GL_VERSION: OpenGL ES 2.0 GL_RENDERER: Mali-400 MP GL_EXTENSIONS: GL_OES_texture_npot, GL_OES_vertex_array_object, GL_OES_compressed_ETC1_RGB8_texture, GL_EXT_compressed_ETC1_RGB8_sub_texture, GL_OES_standard_derivatives, GL_OES_EGL_image, GL_OES_depth24, GL_ARM_rgba8, GL_ARM_mali_shader_binary, GL_OES_depth_texture, GL_OES_packed_depth_stencil, GL_EXT_texture_format_BGRA8888, GL_OES_vertex_half_float, GL_EXT_blend_minmax, GL_OES_EGL_image_external, GL_OES_EGL_sync, GL_OES_rgb8_rgba8, GL_EXT_multisampled_render_to_texture, GL_EXT_discard_framebuffer, GL_OES_get_program_binary, GL_ARM_mali_program_binary, GL_EXT_shader_texture_lod, GL_EXT_robustness, GL_OES_depth_texture_cube_map, GL_KHR_debug, GL_ARM_shader_framebuffer_fetch, GL_ARM_shader_framebuffer_fetch_depth_stencil, GL_OES_mapbuffer [xcb] Unknown request in queue while appending request [xcb] Most likely this is a multi-threaded client and XInitThreads has not been called [xcb] Aborting, sorry about that. *** Error in `es2_info': malloc(): memory corruption: 0x01d3000c *** Aborted root@orangepiplus2e:~#
jernej Posted September 10, 2017 Author Posted September 10, 2017 On 9/10/2017 at 10:04 AM, zador.blood.stained said: wouldn't it be easier to build it out of tree instead of rebuilding the whole kernel? Expand That's true. On 9/10/2017 at 10:04 AM, zador.blood.stained said: (like disabling UMP_LOCK) Expand That userspace driver doesn't support ump. Did you disabled support for it while building? It is dma-buf version.
jernej Posted September 10, 2017 Author Posted September 10, 2017 On 9/10/2017 at 9:50 AM, zador.blood.stained said: and after manual patching it still crashes in mali_gp_job_create Expand I think you must go trough all uargs->... references and replace it to job->uargs->... except for https://github.com/Icenowy/sunxi-mali/blob/master/r6p0/src/devicedrv/mali/common/mali_gp_job.c#L93, obviously. 1
zador.blood.stained Posted September 10, 2017 Posted September 10, 2017 On 9/10/2017 at 10:16 AM, jernej said: That userspace driver doesn't support ump. Expand I know But I saw UMP related entries in Xorg.0.log and misread that it was enabled by default (now that I checked the man page again it is disabled by default) On 9/10/2017 at 10:16 AM, jernej said: Did you disabled support for it while building? Expand Kernel driver? It is disabled by default
