Crossplatform Vlad Posted April 14, 2025 Posted April 14, 2025 Build logs: https://paste.armbian.com/ivisomijaq Please take a look on CPU usage precision on the new kernel for x64 and arm64. It is 1 milliseconds. But kernel 6.13 on armv7 still provides 4 milliseconds of precision. How do I tune CPU usage precision on image build? 0 Quote
Crossplatform Vlad Posted May 24, 2025 Author Posted May 24, 2025 Seems Ubuntu from Canonical uses a customized kernel where CPU usage precision is improved. But Debian and Armbian use previous CPU usage precision settings? 0 Quote
laibsch Posted May 26, 2025 Posted May 26, 2025 Can you point to a patch or some code from Ubuntu how they achieve that? 0 Quote
Igor Posted May 26, 2025 Posted May 26, 2025 On 5/25/2025 at 1:16 AM, Crossplatform Vlad said: But Debian and Armbian use previous CPU usage precision settings? Did you compare those things on the same hardware (architecture)? 0 Quote
hexdump Posted May 26, 2025 Posted May 26, 2025 maybe its related to the kernel config parameter CONFIG_HZ_xyz - depending on which of them is set for the different kernels? 0 Quote
Crossplatform Vlad Posted May 30, 2025 Author Posted May 30, 2025 On 5/26/2025 at 10:26 PM, Igor said: Did you compare those things on the same hardware (architecture)? Good question. I did compared predefined default kernels from canonical (6.8) and debian (6.10) on the same hardware twice: 1) qemu arm64 emulator on x86_64 host with the same parameters. lines 6 and 7 on the screenshot 2) qemu x86_64 emulator on x86_64 host with the same parameters. lines 4 and 5 on the screenshot 0 Quote
Crossplatform Vlad Posted May 30, 2025 Author Posted May 30, 2025 (edited) On 5/26/2025 at 10:38 PM, hexdump said: maybe its related to the kernel config parameter CONFIG_HZ_xyz - depending on which of them is set for the different kernels? Seems it is an option for timer resolution in the measurement of duration. But the topic is about CPU usage precision returned by getrusage function. it is hardcoded interval of time when kernel updates CPU usage of particular thread/process. Edited May 30, 2025 by Crossplatform Vlad 0 Quote
