after installing armbian on my odroid-xu4-box and about one hour later the screen was going black. But I was not able to get back the running X-Session. So I rebootet as first and as next step I disabled the xdg-screensaver to off, but with no succes - the screen goes black again and neither a moving of the mouse nor a touch the keyboard brings the screan back to activity.
So - now what can I do here ?
The same behavior appears, if I switch off the screen, if I wanna make a pause for some times.
After controlling the xdg-screensaver status I get "off". So it seems, that no screensver is active and running. Which process produces this behavior ? Hope anyone does have an idea ?
Thanks in advance
bye silverplate
We are not clairvoyant or mind readers :P Please describe your setup as best as possible so we know what your operating environment is like.
1. Logs, when you can boot the board: armbianmonitor -u (paste URL to your forum post)
2. If your board does not boot, provide a log from serial console or at least make and attach a picture, where it stops.
3. Describe the problem the best you can and provide all necessary info that we can reproduce the problem.
3 hours ago, RagnerBG said:
But isn't it was turned off by default in xorg.conf?
Not if you install desktop on your own which is most likely the case here.
