Fredrik Posted Monday at 01:33 AM Posted Monday at 01:33 AM (edited) Hello! I'm trying to look around in the Armbian build/config scripts to see how I can enable a mainline v6.15-rc3 kernel to be built. I did try to make a build/userpatches/lib.config file with the contents, KERNELBRANCH="tag:v6.15-rc3" But that's not working. Would anyone be able to tell me the file I need to edit for an OrangePi 5? Update: I actually seem to have it try by editing config/sources/families/rockchip-rk3588.conf changing the version tag. But I get a bunch of red errors complaining about SHA1. Quote Failed to fetch SHA1 of 'tag' 'refs/heads/v6.15-rc3^{}' [ https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git ] hmm...an 'rc3' is probably not to be found in a tree with 'stable' in it. Cheers! Fred Edited Monday at 01:49 AM by Fredrik 0 Quote
Solution Werner Posted Monday at 05:19 AM Solution Posted Monday at 05:19 AM 4 hours ago, Fredrik said: But I get a bunch of red errors complaining about SHA1. That's normal services usually need a few hours to catch up with stuff once a new tag is released. Try tomorrow. 3 hours ago, Fredrik said: But I get a bunch of red errors complaining about SHA1. Deprecated. Check docs again. 0 Quote
Fredrik Posted 15 hours ago Author Posted 15 hours ago (edited) Yes you were right it found those sha files when I tried yesterday! I didn't even realize I was trying that close to the release. Build has worked! Thank you! And can confirm that HDMI audio out with Ubuntu+Gnome works! Edited 2 hours ago by Fredrik 0 Quote
