blood Posted 6 hours ago Posted 6 hours ago I don't use my Clearfog Base as a filer or anything, but I much prefer to have some snappy storage on systems that I access frequently - and since this system is my firewall, I end up working on it often enough. When I'm not at home it's often where I push files - so running off an SD card is right out. For years now I've been using an m.2 SATA drive which has been fine, but it's got a minipcie slot just sitting there that I've never used... it's not particularly fast (PCIe gen 1 x1) but with one of these and an m.2 NVMe drive (the older the better...), you can get much better perf than SATA. You can't boot off it (at least I don't know how to make that happen) but it's easy enough to do that via an SD card or SATA and use one of these for the root filesystem or /home, etc. 0 Quote
