GURBANOV Posted 9 hours ago Posted 9 hours ago I need your help, I'm not an expert in this, so I'll ask you to explain in as much detail as possible ☺️ as I understand it, I have version q2, which supports gigabit LAN. I want to install lxqt de, but I couldn't find such an assembly. What version exactly do I need to download? I tried to install this version, downloaded it from github: (Armbian_25.05.0_amlogic_s905x3_noble_6.12.21_server_2025.04.01.img) installed it, through armbian-config I installed xfce de, but for some reason I logged into the system as root. and that's why i couldn't do anything with the sudo command. I created a second user, installed lightdm, but when I logged out of the system, everything just froze, and I couldn't select the second user. and also, as I noticed, for some reason my Bluetooth didn't work, as I understand it could you tell me which version should I download and if possible give me a link 0 Quote
SteeMan Posted 3 hours ago Posted 3 hours ago 6 hours ago, GURBANOV said: Armbian_25.05.0_amlogic_s905x3_noble_6.12.21_server_2025.04.01.img) That is not an Armbian image, you are not using an Armbian build. You should ask for help where you downloaded your fake forked image from. 0 Quote
GURBANOV Posted 3 hours ago Author Posted 3 hours ago https://github.com/ophub/amlogic-s9xxx-armbian/releases I downloaded it from here. Could you send me the link where I need to download it from? It's not so important for me that it's the original Armbian, I just want to have Linux with LXQT on my TV box. and if that fork is enough for what I want to get, then that's great 0 Quote
Werner Posted 3 hours ago Posted 3 hours ago This is not Armbian. This fork is using the name Armbian without permission nor do they contribute to the core development process. Ask at their repo for help. We cannot and will not support any forks whatsoever. 0 Quote
