Greetings,
    I've built a custom image for the BPI M4 Zero and have been using a wired USB cable for my config and development work,    It's final destination will require wireless. So I started to configure that today and discovered that it does not find any wireless access points.
The device exists.
3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
    link/ether ac:6a:a3:3f:9c:65 brd ff:ff:ff:ff:ff:ff
There is an overlay loaded (I did not add it, it was part of the image build)
overlays=bananapi-m4-sdio-wifi-bt usbhost bananapi-m4-pi-5-6-i2c0 bananapi-m4-pi-7-8-i2c1
I do not see any errors from dmesg, but only these:
[    8.484857] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    8.851537] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
[    8.852261] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Aug 29 2023 01:47:08 version 7.45.265 (28bca26 CY) FWID 01-b677b91b
I am not sure where to begin diagnosing this. I almost never use wireless on Linux so I could be overlooking something basic.
# iwlist wlan0 scanning
wlan0     No scan results
# uname -a
Linux bananapim4zero 6.13.11-edge-sunxi64 #5 SMP PREEMPT_RT Thu Apr 10 12:42:07 UTC 2025 aarch64 GNU/Linux
Remind me. Does WiFi works in image from download section? https://www.armbian.com/download/?device_support=Standard support
This (EDGE kernels) raises support costs into the sky and since from open source developers position 99.5% costs are not yours ... use current kernel. Its a huge difference between those two, one has been stabilized, the other not, probably next year, most likely never and will be replaced with next EDGE, 6.14.y with stabilization attempt in more then one year from now. Also legacy 6.6.y would be better for this job. Higher number doesn't mean better functionality and less bugs, often right the opposite.
Try this way:
sudo ip link set wlan0 up
sudo iw dev wlan0 scan
Thank you for your response.   I pulled down one of the "Standard Support" images.
I enabled the overlay, and brought the interface up, but scanning does not return anything:
root@bananapim4zero:~# iw dev wlan0 scan
Quote
I wanted a 6.12 kernel that had real time extensions built in.  I didn't realize 'current' would handle that.  I will end up replacing this with a current kernel.  I can't remember how anything < 6.12 handles real time patches. Maybe Armbian does it automatically as part of its patch set.
23 часа назад, jgauthier сказал:
# uname -a
What is the purpose of using this core?
Several people have already tried to build a real-time kernel here on the forum.
They all face some challenges.
Perhaps, if the tasks that such a core should perform are of a general nature, we can provide a configuration for its assembly.
You built it yourself.
Can you provide a difference in the configuration file for the same kernel version?
As diff -u command.
Posted (edited)
@going I can, yes.  But at the moment I don't want to distract from the wifi issue I am trying to solve.
I am building a test application that must perform real time operations. I have previously done this with other ARM boards/distributions, but for this small project I am trying to go with "simplicity" (nothing is ever simple)
I can provide the 'duff -u' for your interest, but I don't know what you want me to compare it against.   i have linux-sunxi64-edge.config in my userpatches/ folder.
It's generated from make menuconfig, and then I removed 'CGROUP_SCHED' from armbian-kernel.sh.
Real-time applications work fine now. (They do not with group scheduling)
root:~/# ./cyclictest --mlockall --smp --priority=80 --interval=200 --distance=0
# /dev/cpu_dma_latency set to 0us
policy: fifo: loadavg: 0.30 0.37 0.17 2/200 1471
T: 0 ( 1468) P:80 I:200 C: 379209 Min:      7 Act:   18 Avg:   10 Max:      83
T: 1 ( 1469) P:80 I:200 C: 379008 Min:      6 Act:   19 Avg:   10 Max:      68
T: 2 ( 1470) P:80 I:200 C: 378802 Min:      7 Act:   19 Avg:   10 Max:      79
T: 3 ( 1471) P:80 I:200 C: 378595 Min:      7 Act:   20 Avg:   10 Max:      75
Edited by jgauthier
1 час назад, jgauthier сказал:
1) Play (decode) video audio
2) Read the status of multiple sensors at regular intervals
3) Generate pulses on GPIO
4) Transmit the packet at the right time over Ethernet, UART ...
5) .......?
2 часа назад, jgauthier сказал:
diff -u config/kernel/linux-sunxi64-edge.config userpatches/linux-sunxi64-edge.config
5) Control a flight vehicle with real time input and outputs.
[jgauthier@gamma build]$ diff -u config/kernel/linux-sunxi64-edge.config userpatches/linux-sunxi64-edge.config
I'm not sure why it's expected that those would be different.
I made the configuration with 'make menuconfig' and then copied to to userpatches.  I did this because, at the time, I thought it was being overwritten.
It was, but that was due to armbian-kernel.sh.
  • Solution
I wanted to come around to this. Wireless works fine.  The problem is the guy between the chair and the keyboard.
In the past I've been able to at least scan wifi networks without an antenna.  I cannot on this board. I attached the antenna and I was able to see all the networks.
oof
Thank you for coming back and sharing your "solution".  It is always good to hear when things work out in the end, no matter the reason.
