Need Kernel source for linux-image-current-sunxi64 6.12.20
Go to solution Solved by ovacikar,
Hi, I need linux kernel source to compile a custom module. The one I downloaded from kernel.org did not work, got module format error, indicating the kernel is different.
i did not have this problem compiling the same module for Armbian lepotato (amlogic)
Where do I get the kernel source for my Orangepi Zero 2?
Linux orangepizero2 6.12.20-current-sunxi64 #1 SMP Sat Mar 22 19:54:28 UTC 2025 aarch64 GNU/Linux
linux-headers-current-sunxi64/bookworm,now 25.2.3 arm64 [installed]
  Armbian Linux current headers 6.12.20-current-sunxi64
linux-image-current-sunxi64/bookworm,now 25.2.3 arm64 [installed]
  Armbian Linux current kernel image 6.12.20-current-sunxi64
We just figured out we have dropped packing kernel sources at some point. Until we figure out how to re-enable that or if this makes sense, use build framework to add a custom module. It has the ability to do that.
Allwinner kernel is heavily patched, version is not necessarily latest, quite distanced from mainline, while Amlogic, on the other hand, is closer, changed less.
I set the version in userpatches/lib.config , then executed this:
./compile.sh BOARD=orangepizero2 BRANCH=current kernel-config KERNEL_BTF=no KERNEL_GIT=full
and when the kernel menu came up, just exited to shell.  Is this the kernel source directory I can point the compiler script of the module ?
/build/cache/sources/linux-kernel-worktree/6.12__sunxi64__arm64$ ls
arch   COPYING  defconfig      fs       io_uring  Kconfig  LICENSES     mm      rust     security  usr
block  CREDITS  Documentation  include  ipc       kernel   MAINTAINERS  net     samples  sound     virt
certs  crypto   drivers        init     Kbuild    lib      Makefile     README  scripts  tools
Edited by ovacikar
14 часов назад, ovacikar сказал:
The kernel headers that you have installed are quite enough to build the kernel module, the source codes of which you have.
If the source codes are already in the kernel, then you just need to configure the kernel before compiling.
launch:
2 часа назад, ovacikar сказал:
After you finish the configuration, the build system saves your configuration file (it will tell you where it did it).
Save it under the name ./config/kernel/linux-sunxi64-current.config
It is assumed that you are in the armbian/build directory.
launch:
This 3rd party module needs both kernel headers and kernel source. The Makefile bundled with the code applies patches to an existing  kernel module source code and compiles it.
I ran the build script on a separate debian vm and created a tarball of the source tree. i will try to transfer it to the opi later today.
I still get the format error with the compile.sh generated kernel source , along with this dmesg error:
modprobe: ERROR: could not insert 'module': Exec format error
.gnu.linkonce.this_module section size must match the kernel's built struct module size at run time
  • Solution
I tried with the orangepi's own debian  bookworm server image , and the module installed fine with the kernel.org source code and linux-headers deb package they included in /opt folder
Edited by ovacikar
@ovacikar
Did you manage to get this fully working? What does this kernel bring?
I saw recently hw acc is now working, did you manage to get this working?
Im asking because this weekend im going to try to get mine all up to date and see if i can get it be a simple media player
