I would like to create Lab with PiRogue and add suricata custom rules for Pegasus attack preventions: https://pts-project.org/guides/g7/
I would like to use internal PiRogue_VPN_server and add additional 3x-ui or S-ui server with xray-vless-realty as second layer because mobile operators or internet providers from specific country like RU or CN may block simple wireguard proto, this will be looks like:
NanoPI_R4S with [ PiRogue(internal_wireuard) -> XRAY_server(xray-vless-realty) ] -> Android Phone with XRAY client(xray-vless-realty) and host level firewall that will be forward all mobile trafic to the VPN client
NanoPI + Arambian lasted with all updates
For PiRogue installation I use the instruction: https://pts-project.org/docs/pirogue/installation/
Step #1
sudo apt-get update
sudo apt-get dist-upgrade
Step #2
sudo apt-get install wget
sudo wget -O /etc/apt/sources.list.d/pirogue.list https://pts-project.org/debian-12/pirogue.list
sudo wget -O /etc/apt/trusted.gpg.d/pirogue.gpg   https://pts-project.org/debian-12/pirogue.gpg
sudo apt-get update
sudo apt-get install pirogue-base
I have PiRogue's after installation message:
Job for dnsmasq.service failed because the control process exited with error code.
See "systemctl status dnsmasq.service" and "journalctl -xeu dnsmasq.service" for details.
My currient problem is starting process of a dnsmasq.service on my NanoPI_R4S
Dears @Igor  @Werner could you pls help me or forward to nanopi r4s maintainer that may fix the prob
I alredy describe similar problems with "systemd-networkd-wait-online.service" in  my previos my topic, see link:
or
pirogue_log.txt
  • Solution
From logs I can only conclude that problems are at your side - wrong configuration. Anyone can help you - problem is almost certainly not Armbian specific.
May 10 21:05:09 pirogue systemd-helper[8502]: dnsmasq: unknown interface end0
May 10 21:05:09 pirogue dnsmasq[8502]: unknown interface end0
I am not an expert of application you try to install, in fact I never heard about until now.
Everything is good, thanks for the help and sorry for confusion, I only should to change PiRogue default interface after installation, this is PiRogue interface detection problem...
Edited by Superuser
