sakittelsen Posted 7 hours ago Posted 7 hours ago I normally like building server images because they are small and fast to compile. An then I can add the wanted desktop by "sudo apt install gnome" or other desktop later. But, sometimes I wonder if the desktop images have more features, like hardware drivers, than a server image with an added desktop afterwards. Can this be the case? Or does server images contain the same drivers and hardware support as a image built with a destop included? 0 Quote
Werner Posted 4 hours ago Posted 4 hours ago Desktop images have some standard adjustments, like other wallpaper or certain extensions enabled. Driver, or kernel-wise, they are, depending on things mentioned earlier, identical to server images. You can check the build framework on Github for all the code. 0 Quote
laibsch Posted 4 hours ago Posted 4 hours ago 15 minutes ago, Werner said: You can check the build framework on Github for all the code. That is true but almost impossible to understand for an outsider. 0 Quote
