Guest Posted May 13, 2025 Posted May 13, 2025 Does running ambian-upgrade do the exact same thing as running apt update and apt upgrade? 0 Quote
Solution Igor Posted May 13, 2025 Solution Posted May 13, 2025 You can check this way: type armbian-upgrade armbian-upgrade is /usr/bin/armbian-upgrade cat /usr/bin/armbian-upgrade #!/bin/bash trap "exit" INT TERM [[ $EUID != 0 ]] && exec sudo "$0" "$@" apt update apt -y upgrade apt clean apt -y autoremove exit 0 0 Quote
ErinBong Posted 1 hour ago Posted 1 hour ago I usually make a quick backup before running bigger updates, especially on systems that are already working well. It also helps to reboot after the update and check armbianmonitor -u if anything seems off afterward. That can provide useful information if you need to troubleshoot. 0 Quote
