awef Posted May 13, 2025 Posted May 13, 2025 Does anyone know if it's possible to use the docker-shell to patch linux and compile, but NOT make the .img file? Maybe something like ./compile.sh unpack-linux ./compile.sh apply-patches ALL=THE_SETTINGS ./compile.sh build-kernel but not make .img I'm trying to change some network driver settings and want to just copy the new kernel module to my target board instead of flashing the entire SD card. 0 Quote
SteeMan Posted May 13, 2025 Posted May 13, 2025 https://docs.armbian.com/Developer-Guide_Build-Commands If I read your post correctly, I think you want ./compile.sh kernel ... which will build the kernel debs but not the full image 1 Quote
Werner Posted May 14, 2025 Posted May 14, 2025 The correct way to modify a kernel with patches is to use - ./compile kernel-patch BOARD=... BRANCH=... - review your patches and if you are satisfied move them to patch/ or the equivalent directory under userpatches/ - ./compile.sh kernel BOARD=... BRANCH=... 2 Quote
awef Posted May 14, 2025 Author Posted May 14, 2025 Thank you SteeMan and Werner. I will try out your recommendations. 0 Quote
