Hello,
With kernel 6.6.56-current-rockchip64 the audio works correctly:
cat /proc/asound/cards
 0 [RK809          ]: simple-card - Analog RK809
                      Analog RK809
 1 [HDMI           ]: simple-card - HDMI
                      HDMI
With kernel 6.12.30-current-rockchip64 the RK809 card is not available:
 0 [HDMI           ]: simple-card - HDMI
                      HDMI
How can this be solved ?
Thank you so much !
I'd probably start with comparion the device trees of both images and check for altered/removed nodes related to audio.
I tried the image from "armbian.atomonetworks.com" and the exact same thing happens.
Thanks, I'll compare the images.
hi, not sure for the sbc, but on uefi-x86, alsa has hdmi audio, but its not loaded for pulseaudio ... ??
here I managed to load it and unmute SPDIF in alsamixer
(I still dont understand how devicetree powered SBCs differ against uefi-x86 system ... excuse me)
crucial help from Lyra 🙂 ... unmuting SPDIF did the thing, probably also loading the sink also, ufff
https://chatgpt.com/share/68836e5f-9e4c-8000-8874-46ea35a07331
