Michel Catudal Posted May 27, 2025 Posted May 27, 2025 I ran compile.sh and got an error message which looked weird It couldn't find the directory .tmp/work-3efc55a6-9478-4508-91c4-5637c4b1e593 and would stop all work I created the directory and then it worked What the heck is that about? My linux x86 system is gentoo and not debian. I do have debian in vmware fusion on my mac. I use it to chroot my gentoo arm systems since it is much faster than cross compiling. For fun I tried again on a different directory and got a new error message This time it is .tmp/work-032fc96c-9055-4b10-86a8-b46b65980a11 The board I try to work with is YY3568 The problem doesn't seem to appear if I don't ask to let me change the kernel configuration 0 Quote
laibsch Posted May 29, 2025 Posted May 29, 2025 To be honest, I'm confused. You reference three different systems and it is unclear to me which one it is that FTBFS for you. Let's take a step back. Do you have the latest git tree of armbian/build? Do you have any local changes? What is the exact command you for compile.sh? I will try to reproduce the problem here. 0 Quote
