Posted (edited)
Hey everyone, for the past couple of days I've been looking into the Mesa-VPU script made by AmazingFate that's used to patch Mesa/VPU onto a custom build of Armbian.
https://github.com/armbian/build/blob/main/extensions/mesa-vpu.sh
I already have an install of Armbian (Debian XFCE 6.12.28-current-rockchip64 ) on my Rock5b and was looking into applying as much as I can without re-building an image or starting from scratch.
From my understanding, You'd need the vendor rk3588 kernel if you want the best possible compatibility with things like the VPU for multimedia acceleration (Someone please correct me if this is not the case lol)
What follows is what I was able to piece together after troubleshooting, reading the Mesa changelog & trying to apply as many packages as I can from AmazingFate's kernel extension script. I've also included some tweaks for XFCE to hopefully provide a smooth graphical experience.
Although my Rock5b is used as a headless server and doesnt have anything plugged into the HDMI port, I can say that the following changes have made a huge difference in graphical performance of VNC.
Please keep in mind that i'm not a developer for Armbian. I just wanted to share this as a guide i've put together to hopefully help someone else who's tried the same
(Please let me know your thoughts or if there was anything i've missed. Like I said, this is what has worked for me)
(Obviously the correct fix is to rebuild Armbian with Mesa-VPU. What follows was done as an experiment)
#################### GUIDE BELOW. THIS IS NOT A SHELL SCRIPT! PLEASE READ AND DO NOT COPY/PASTE ENTIRETY INTO TERMINAL!#############################
#### -- 01 Setup AmazingFate Panfork-Mesa repo for mali-g610-firmware 01 -- ####
## 1A: import gpg key and use it to sign repo ##
wget -qO - https://download.opensuse.org/repositories/home:/amazingfate:/panfork-mesa/Debian_12/Release.key | sudo gpg --dearmor -o /etc/apt/trusted.gpg.d/panfork-mesa.gpg
## 1B: Add Repo to apt sources & update ##
echo "deb https://download.opensuse.org/repositories/home:/amazingfate:/panfork-mesa/Debian_12/ /" | sudo tee /etc/apt/sources.list.d/panfork-mesa.list
sudo apt update
## 1C: Install firmware ##
sudo apt install mali-g610-firmware libmali-g610-x11
## 1D: **RECOMMENDED** : Remove panfork-mesa repo ##
sudo rm -rf /etc/apt/sources.list.d/panfork-mesa.list
sudo rm -rf /etc/apt/trusted.gpg.d/panfork-mesa.gpg
#### -- 02 Enable Debian Experimental Repo for recent Mesa Packages 02 -- ####
sudo nano /etc/apt/sources.list
## 2A: Add the following to the bottom of the document... ##
deb http://deb.debian.org/debian unstable main contrib non-free
deb http://deb.debian.org/debian experimental main
## 2B: Update and install Mesa Packages ##
sudo apt update
sudo apt install -t experimental mesa-vulkan-drivers mesa-utils libgl1-mesa-dri libglx-mesa0 mesa-vdpau-drivers mesa-va-drivers mesa-opencl-icd mesa-libgallium
## 2C: **RECOMMENDED** : Re-open apt sources and remove Experimental/Unstable repos... ##
#Remove the following and update apt...#
sudo apt update
#### -- 03 Add rockchip-multimedia Ubuntu Repo to Apt 03 -- ####
echo "deb [arch=arm64] https://ppa.launchpadcontent.net/liujianfeng1994/rockchip-multimedia/ubuntu jammy main" | sudo tee /etc/apt/sources.list.d/rockchip-multimedia.list
## 3A: Download Key and add convert to gpg ##
curl -o rockchip-multimedia.asc "https://keyserver.ubuntu.com/pks/lookup?op=get&search=0x8065BE1FC67AABDE"
gpg --dearmor rockchip-multimedia.asc
sudo mv rockchip-multimedia.asc.gpg /etc/apt/keyrings/rockchip-multimedia.gpg
## 3B: Add PPA Repo and update ##
echo "deb [arch=arm64 signed-by=/etc/apt/keyrings/rockchip-multimedia.gpg] https://ppa.launchpadcontent.net/liujianfeng1994/rockchip-multimedia/ubuntu jammy main" | sudo tee /etc/apt/sources.list.d/rockchip-multimedia.list
sudo apt update
## 3C: Install packages ##
sudo apt install libv4l-rkmpp chromium gstreamer1.0-rockchip1 rockchip-multimedia-config
## 3D: **OPTIONAL** : Disable rockchip-multimedia PPA repo ##
sudo mv /etc/apt/sources.list.d/rockchip-multimedia.list /etc/apt/sources.list.d/rockchip-multimedia.list.disabled
sudo apt update
#### -- 04 Optimize XFCE/Xorg and Reboot 04 -- ####
## 4A: Open default xorg config ##
sudo nano /etc/X11/xorg.conf.d/01-armbian-defaults.conf
#Add the following... #
Section "Device"
   Identifier "Mali-G610"
   Driver "modesetting"
   Option "DRI" "3"               # Required for Mali GPUs
   Option "GALLIUM_DRIVER" "panfrost"
   Option "PageFlip" "on"          # Reduces tearing
   Option "TearFree" "true"        # Xfce-specific anti-tearing
EndSection
## 4B: Add XFCE Specific tweaks ##
sudo nano /etc/X11/xorg.conf.d/20-xfce-tweaks.conf
Section "Extensions"
   Option "COMPOSITE" "Enable"
EndSection
Section "ServerFlags"
   Option "AutoAddGPU" "off"  # Prevents duplicate GPU detection
EndSection
## 4C: Reboot ##
sudo reboot now
Edited by Cesar R.
Once done, you should be able to login and run the following to see the Mali g610 recognized as a Vulkan device...
vulkaninfo --summary
I gave this a try but after creating the /etc/apt/sources.list, when running sudo apt update it returns this error
The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
Dont run the entire script at once. Run one section at a time for each step at a time and monitor the output.
Example: Run the lines under 1A and monitor the output, Proceed to 1B and monitor.
The only changes made to /etc/apt/sources.list are enabling the Debian unstable/experimental repos (which do not require public keys to be manually added.
Full disclaimer: This was something I did as an experiment. Full Vulkan support for the Mali g610 is still not officially supported in Debain stable.
To be completely honest, I personally rolled back this change by restoring a Timeshift backup taken before the changes.
The dependencies installed by Debain Experimental for the latest Mesa version will also break dependencies used by Armbian for firmware updates.
Please be smart and remember to make backups before making updates like this.
Personally, I'm fine with waiting a few years for Debian to eventually apply compatibility to the stable branch
Thanks for the reply.
I did run each element one at a time and watched to see when and if there were any that reported errors.
It's not a big deal though and always worth trying new things to try and get this SOC running as it should do.
@laibsch It would be good to get this solved as there are a lot of boards out there and they are expensive kit, also this effects both Armbian Ubuntu as well as Debian. I was hapilly running my own Ubuntu Plucky Armbian Unofficial and had desktop functioning fine on my BananaPi-M7 for several apt-get upgrades. I use ssh mainly as I run it as a server for development purposes, but like to use desktop for dev purposes too. Then suddenly the screen went blank and looked like it was continually trying to start up. On reinstalling Armbian Ubuntu Nobel, then Plucky again I worked out that Gnome had been running as v46, but at some point Ubuntu had reverted to v44.
I am not sure if this was the breaking change but it seems to at least be parallel. i.e. it was working and I can demonstrate it working and not working repeatedly.
Hi @Cesar R. I will run through your repo mods tomorrow and see if I can replicate.
It would be good to get this fixed for both Ubuntu and Debian on BananaPi-M7 and Radxa Rock 5B+ and the other boards for Armbian. As I say theres a lot of boards out there and they are expensive. Maybe some of the board manufacturers would pay towards the fix also ? I am just in it for the solution as I need the boards for dev work.
I cannot verify your claim that Ubuntu "reverted" to Gnome v44.  Noble has v44 indeed.  v46 is not anywhere in a Ubuntu release so my guess is you shot yourself in the foot with some random PPA or whatever repo out there.
https://launchpad.net/ubuntu/+source/meta-gnome3
There is no shortage of boards out in the wild, nobody would think that.  What there is, is a shortage of people willing to fund development, be it users or companies.  Big shout out to those who do and to our volunteer devs, thank you!
For some reason I have to delete some packages to install others... Both related an unrelated to this guide.
Trying to install packages from step 3C gives an error and can't get this dependency: libelf1. And if I install that package alone, it removes many others, including some from step 2B. Then, if I install again the packages from 2B, it will remove a few from 3C.
I'm using Armbian Bookworm Minimal on my Orange Pi 5 Pro, with just a handful of extra packages (including gnome-session, gnome-terminal and firefox-esr).
Also step 1A & 1B are kind of weird... Like updating won't recognize the gpg key. I still could bypass the error by adding
[trusted=true]
on step 1B between deb and the link (or use sudo nano /etc/apt/sources.list.d/panfork-mesa.list if the file was already created).
