Skallwar Posted May 28 Posted May 28 (edited) Hello, I tired to boot Armbian for my Rock5b but whatever image I choose to use, I'm never able to get past U-boot into linux when looking at the Uart output. Here are the log I get: ``` U-Boot SPL board init U-Boot SPL 2017.09-gd1cf49135ee-220414-dirty #stephen (May 23 2024 - 19:39:28) Trying to boot from MMC2 GUID Partition Table Entry Array CRC is wrong: 0x71678773 != 0xab54d286 part_get_info_efi: *** ERROR: Invalid GPT *** part_get_info_efi: *** Using Backup GPT *** spl: partition error Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(7612223b82...) + OK ## Checking uboot 0x00200000 ... sha256(b6f9939e11...) + OK ## Checking fdt 0x003200d8 ... sha256(e3b0c44298...) + OK fdt_record_loadable: FDT_ERR_BADMAGIC ## Checking atf-2 0xff100000 ... sha256(70505bb764...) + OK fdt_record_loadable: FDT_ERR_BADMAGIC ## Checking atf-3 0x000f0000 ... sha256(b2af21b504...) + OK fdt_record_loadable: FDT_ERR_BADMAGIC Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 729.286/924.898 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-868-g040d2de11:derrick.huang, fwver: v1.48 NOTICE: BL31: Built : 15:02:44, Dec 19 2024 INFO: spec: 0x1 INFO: code: 0x88 INFO: ext 32k is not valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: disable memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 ``` I tried to use multiple SDcard and different power supply (67W 5v phone charger and USB-PD bricks) but I never got any logs after `INFO: SPSR = 0x3c9`. I tried multiple Armbian images with vendor and current kernel, minimal ones and ubuntu gnome ones. I'm starting to wonder if my board is broken but I can boot the Android image that I found here https://forum.radxa.com/t/rom-rock5a-b-androidtv-12-by-mo123/15527 Edited May 28 by Skallwar Added link to the only image I'm able to boot 0 Quote
Skallwar Posted May 29 Author Posted May 29 Hi, thanks for the reply. I've tried this already following this guide https://docs.radxa.com/en/e/e24c/getting-started/install-os/nvme-system/spi-flash#flash-spi-boot-firmware. I tried to flash both the release and debug images I found here https://dl.radxa.com/rock5/sw/images/loader/rock-5b/ When you say wipe it, do you mean wipe it and don't flash something else? 0 Quote
Werner Posted May 29 Posted May 29 57 minutes ago, Skallwar said: When you say wipe it, do you mean wipe it and don't flash something else? correct. If the soc does not detect a valid boot loader on spi it will fall back to its hard coded boot order which is spi, emmc, microsd or something like this. 0 Quote
Skallwar Posted May 29 Author Posted May 29 Okay I will try that when I get back from work, thanks for your time 0 Quote
Skallwar Posted May 29 Author Posted May 29 Hi. I did a wipe of the SPI flahs using the method found in this guide https://docs.radxa.com/en/rock5/rock5b/low-level-dev/install-os/rkdevtool_spi#erase-spi-flash While I can see that the TF-A version is newer I still hand int the same fashion: ``` DDR b8ce94f14b cym 25/09/26-15:48.05,fwver: v1.20 ch0 ttot10 ch1 ttot10 ch2 ttot10 ch3 ttot10 ch0 ttot18 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB ch1 ttot18 channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB ch2 ttot16 channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB ch3 ttot18 channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB Manufacturer ID:0xff DQS rds:l0,h1 CH0 RX Vref:27.5%, TX Vref:21.8%,0.0% DQ rds:l0 h1 h1 h1 h4 h1 h3 h1, h1 h6 h4 h3 h4 h4 h7 h2 DQS rds:l0,h3 CH1 RX Vref:27.5%, TX Vref:20.8%,0.0% DQ rds:h1 h6 h1 h3 h3 h4 h3 h4, h5 h1 h4 h6 h5 h7 h1 h2 DQS rds:h1,h1 CH2 RX Vref:28.5%, TX Vref:20.8%,0.0% DQ rds:l0 h4 h2 l0 h6 h5 h4 h2, h3 h3 h2 h4 h5 h5 h7 h6 DQS rds:h1,h1 CH3 RX Vref:28.9%, TX Vref:21.8%,0.0% DQ rds:h2 h7 h7 h2 h6 h2 h7 h1, h5 l0 h5 l0 h1 h5 h1 h1 stride=0x2, ddr_config=0x0 hash ch_mask0-1 0x20 0x40, bank_mask0-3 0xa00 0x1400 0x2800 0x0, rank_mask0 0x0 change to F1: 528MHz ch0 ttot10 ch1 ttot10 ch2 ttot10 ch3 ttot10 change to F2: 1068MHz ch0 ttot14 ch1 ttot12 ch2 ttot12 ch3 ttot14 change to F3: 1560MHz ch0 ttot16 ch1 ttot16 ch2 ttot14 ch3 ttot16 change to F0: 2112MHz ch0 ttot18 ch1 ttot18 ch2 ttot18 ch3 ttot18 out INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-942-g98eaeb2f3:derrick.huang, fwver: v1.53 NOTICE: BL31: Built : 12:10:56, Aug 25 2025 INFO: spec: 0x1 INFO: code: 0x88 INFO: customer demand: 0x0 INFO: ext 32k is not valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: disable memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 ``` 0 Quote
Werner Posted May 29 Posted May 29 12 minutes ago, Skallwar said: INFO: SPSR = 0x3c9 Does it simply stop after that line or is the output incomplete? 0 Quote
Skallwar Posted May 29 Author Posted May 29 (edited) It just stops after that. No Linux UART logs, nothing via HDMI. I'm flashing this image: Armbian_26.2.1_Rock-5b_noble_vendor_6.1.115_gnome_desktop.img Edited May 29 by Skallwar 0 Quote
Werner Posted May 29 Posted May 29 Hm. Pure guess: https://github.com/armbian/build/commit/1bac6d977217039cae7193a1d6c19ae5b50c2c5f Try to build and boot an image with this reverted 0 Quote
Skallwar Posted May 29 Author Posted May 29 Ok I will try that. The `Armbian_26.2.1_Rock-5b_noble_vendor_6.1.115_gnome_desktop.img` image is from February so this commit shouldn't be there but I will try without this commit anyway. I also try the Ubuntu rolling release from May 24 that should include this commit but the behavior is the same 0 Quote
Skallwar Posted May 29 Author Posted May 29 So I cloned the repo, did a git revert on the commit you mentioned then ran `./compile.sh BOARD=rock-5b RELEASE=noble BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_ENVIRONMENT=gnome DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base KERNEL_CONFIGURE=no`, flashed the image in the output folder and I'm getting but I'm still getting the same output ``` INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-868-g040d2de11:derrick.huang, fwver: v1.48 NOTICE: BL31: Built : 15:02:44, Dec 19 2024 INFO: spec: 0x1 INFO: code: 0x88 INFO: ext 32k is not valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: disable memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 ``` I wonder if we are getting to the next step (U-boot, right?) and just not getting any logs 0 Quote
Werner Posted May 30 Posted May 30 Yes, the next step should be u-boot normally. @meco any clue? 0 Quote
eselarm Posted May 30 Posted May 30 On 5/28/2026 at 11:42 PM, Skallwar said: I tried to use multiple SDcard and different power supply (67W 5v phone charger and USB-PD bricks) but I never got any logs after `INFO: SPSR = 0x3c9`. My ROCK5B was ordered as a 'blue one' on Aliexpress a year ago; I got a 'green one' and as with included case the price was > 150 euro, it got stuck at customs for quite some time. It was with blank/empty SPI flash and endless boot-loop. That was already known by me, so I had fixed 12V soldered to a male USB-C connector. Same story for ROCK3A, although that one booted most of the time but then while running al sorts of strange errors and or crashes. So I think you have to assume USB-C PD negotiation is not working with the Armbian images you tested. Only the U-Boot starting at sector 64 does matter, rest (Linux) is don't care. If a stable U-Boot or UEFIv1.1 form SPI-flash or SD-card, you have already a very extensive commandline interface or text menu's in the EDK2. But lock up might simply happen because the PSU does not do 65W, instead max 15 W (only up to 3A) and the 5V might drop way too low, just very short dip that is not measurable without good oscilloscope or so. The Radxa image might have a bootloader variant that does do USB-C PD, although I haven't seen proof anywhere that it correctly handles and does operate the FUSB302, but that might simply be because my ROCK3A and ROCK5B came out of the box with empty SPI and for ROCK5B I have ignored Radxa images anyway after the big troubles with ROCK3A, so do not really know what happens with those. So I have no other advice then use fixed higher voltage, formally it is >= 9V according to Radxa wiki/docs AFAIR, but I remember the powertree design actually better than those quick facts and my conclusion was : forget about 5V, use 12V and it was easy decision for me as I use 12V UPS and 3.5inch HDD that also needs 12V anyway. 0 Quote
Skallwar Posted May 31 Author Posted May 31 > My ROCK5B was ordered as a 'blue one' on Aliexpress a year ago Mine has green PCB with some text: Rock 5B v1.42022.08.29 U-boot at sector 64 is SPL or standard U-boot? From what I've read online it looks like if it was a power supply issue I would get a boot loop but my board never reset... It looks like U-boot has support for fusb302. I will build a U-boot with more logs to see if there is any negotiation going on. I've built a Nixos Image. I'm able to go up to U-boot console, start linux via extconfig then get some Linux logs but at some point it just stops without errors on some random log. 0 Quote
eselarm Posted May 31 Posted May 31 1 hour ago, Skallwar said: then get some Linux logs but at some point it just stops without errors on some random log this I cannot remember I have experienced on my ROCK5B, it was indeed boot-loop when power 'was not good enough'; with fixed 12V power everything worked, even 3.5mm audio I remember. Now I have EDK2 UEFIv1.1 for the ROCK5B in the SPI-flash and it is like a PC, so even stores boot entries for several OSses (what is on the ESP). My ROCK3A showed similar behavior as your ROCK5B, that went away when fixed 12V power and Armbian legacy U-Boot and 6.1.115 (I use SATA overlay) At sector 64 the binary u-boot.bin is written, the terminology I am not sure of. You can look up all addresses the ROM uses at rock-chip.com or so. You might want to build/compile an as pure as possible and as latest as possible mainline U-Boot for ROCK5B, I saw kernel 6.17 or later should have fusb302 support, but it might be too late in the power-on process. EDK2 UEFIv1.1 has no fusb302 support. 0 Quote
meco Posted June 1 Posted June 1 The blue revision is not different in this case. I have it running here too. My recommendation would be to flash the u-boot spi bin inside the u-boot deb generated by armbian build. `dpkg -x xyz.deb ./output` and rkdeveloptool are the things to use here 0 Quote
Skallwar Posted June 2 Author Posted June 2 I will try to download and flash the armbian u-boot to SPI. The main issue is that I don't have a fixed USB-C 12V power supply In the meantime I instrumented the fusb302 driver in my Nixos U-boot (v2025.11) an I can see the negociation working and selecting 20v 3.25A with my Lenovo laptop charger. But Linux still stop sudently, but that's a nixos issue, not an armbian on I guess. 0 Quote
eselarm Posted June 3 Posted June 3 OK, good that you see the higher voltage selected. I have also seen it, but was on a NanoPi-R6C, although it did not work with RPi5 27W PSU, but OK with HP tablet 45W PSU. The rest is then a matter of kernel and DTB. My ROCK5B runs fine with rolling release/latest Linux kernels (Debian Sid, Opensuse Tumbleweed), currently 7.0.10 version. Don't know about NixOS (on aarch64), but maybe first get some basic stability with standard Armbian Trixie image (mainline based). It gets tricky when you mix vendor and mainline/distro based. Also vendor (6.1.115) can show various issues if you try/use various external HW. Like an mt9721u USB stick of mine causes a failure in paging on ROCK3A, so need reboot, then it works, but don't know for how long (weeks or months) 0 Quote
Michael Fischer Posted June 5 Posted June 5 I had same issue. i was able to boot using UEFI spi by flashing https://github.com/edk2-porting/edk2-rk3588/releases the rock5b image from this github link. i used this specific armbian image, although it may work with others https://dl.armbian.com/rock-5b/Noble_current_minimal 0 Quote
Skallwar Posted June 7 Author Posted June 7 I had once put EDK2 on the SPI flashed and it seems to run fine, I was able to enter the menu. > i used this specific armbian image But Armbian images use U-boot right? So if it boot from the SD-card EDK2 shouldn't launch right. Armbian images are UEFI compatible? 0 Quote
eselarm Posted June 7 Posted June 7 1 hour ago, Skallwar said: But Armbian images use U-boot right? So if it boot from the SD-card EDK2 shouldn't launch right. Armbian images are UEFI compatible? You will have to make a choice which bootloader firmware you use. And then also which boot method and/or bootmanager. Armbian images for Rockchip SBC's are as simple as possible, so only 1 OS, no ad-hoc kernel selection. That means 1 partition for rootfs, no others. Different methods have different advantages and disadvantages. If you want other boot method and/or bootmanager, you will need to add a boot partition yourself, usually FAT formatted and type 0xEF00 (called ESP). The Armbian rockchip64 supports it all, no problem. Especially the Rock5B, which is more or less the blue-print of high-end ARM64 SBC. But all this own custom action also make it not Armbian anymore, but just a generic UEFI ARM64 computer. Where you could also boot from a CD-ROM .iso image and run a traditional Linux distro installer like used on x86 PC's. 0 Quote
Michael Fischer Posted June 10 Posted June 10 i used grub at the end of the day and booted from nvme. 0 Quote
Skallwar Posted June 11 Author Posted June 11 Hi everyone, sorry for the delay @meco> My recommendation would be to flash the u-boot spi bin inside the u-boot deb generated by armbian build I tried using a u-boot I compiled via the Armbian build system. With this I'm able to go a little bit further, U-boot start try to load Linux and then nothing. I had once 4 lines of print from Linux but nothing more and it's not reproducible. With this setup it looks a lot like my Nixos build with Linux starting and stopping after a few logs lines. I tried with Armbian on a SD card and on a USB stick same behavior @Michael Fischer > i was able to boot using UEFI spi by flashing https://github.com/edk2-porting/edk2-rk3588/releases the rock5b image I tried that. When flashing the Armbian image on the SD card it booted via UBoot at got stuck at the same place than in the first post. I think it's because the rom code tries sd card first for the next stage bootloader. So I flashed the image on a USB stick but it didn't boot, I entered the bios via uart, selected the usb key in the "Boot manager menu" and pressed Enter but I kept going back to the BIOS. I'm not sure that Armbian images are UEFI compatible anyway. I'm starting to wonder if my board is just broken... But at the same time I have an SD card with Android that works perfectly fine 0 Quote
eselarm Posted June 11 Posted June 11 (edited) 1 hour ago, Skallwar said: So I flashed the image on a USB stick but it didn't boot, I entered the bios via uart, selected the usb key in the "Boot manager menu" and pressed Enter but I kept going back to the BIOS. I'm not sure that Armbian images are UEFI compatible anyway. The (standard) Armbian images for Rock5b use boot.scr, not efi/boot/bootaa64.efi from an extra FAT/ESP partition. So no surprise. If you use the EDK2 UEFIv1.1 in the SPI-flash, you should use a generic UEFI ARM64 image. 1 such is Armbian for UEFI ARM64, look at the download options. I don't know, but make sure it is one with latest mainline kernel 7.0.x. What I have used is a Debian Sid nocloud image just as a quick test (testing that image on a NanoPi-R6C, should also work on Rock5b, not the UEFI/bootloader behavior. See https://cloud.debian.org/images/cloud/sid/daily/latest/debian-sid-nocloud-arm64-daily.tar.xz As I mentoined earlier, I use fixed 12V for ROCK5B, else no success. For NanoPi-R6C it works with 5V 3A (27W RPI5 PSU). Edited June 11 by eselarm 0 Quote
Skallwar Posted June 11 Author Posted June 11 > As I mentoined earlier, I use fixed 12V for ROCK5B, else no success. For NanoPi-R6C it works with 5V 3A (27W RPI5 PSU). I ordered a USB-PD trigger board that does the negotiation before the board and output a constant voltage, I will see how it goes 0 Quote
eselarm Posted June 11 Posted June 11 20 minutes ago, Skallwar said: I ordered a USB-PD trigger board that does the negotiation before the board and output a constant voltage, I will see how it goes I have a few of those and when connected to RPi5 PSU and set to 12V, it can power my Rock5B with NVME SSD and some other peripherals as well. 0 Quote
Skallwar Posted June 27 Author Posted June 27 (edited) So I received my USB-PD trigger board, set it to 15V and it does nothing, the situation is still the same. I also ordered a USB tester to see the voltage and amperage, basically the board never draw more than 3 to 4W With Aarch64 UEFI image with EDK2 on the SPI flash, Linux starts to boot but then fails and I get a black screen Edited June 27 by Skallwar 0 Quote
