Chris007 Posted 7 hours ago Posted 7 hours ago Hi, yesterday i see a "armbian-update" message after login per ssh. I run this command and than my banana pi M1 won't boot. How can i repair it without formatting the SSD? Regards Christian 0 Quote
eselarm Posted 3 hours ago Posted 3 hours ago Somehow the SD-card contents and SSD contents could be mixed-up or partly double. I do not know what armbian-update does, but what is your plan or what do you want? Should Armbian run from SD-card or SSD? 0 Quote
Igor Posted 31 minutes ago Posted 31 minutes ago 3 hours ago, eselarm said: I do not know what armbian-update does From the picture - I can only guess that kernel package was somehow not upgraded properly as kernel image files are missing. Perhaps they were removed by accident or there was some disk / file system troubles involved. @Chris007 Try hints from here: https://docs.armbian.com/User-Guide_Troubleshooting/ 0 Quote
