CDit Posted July 1 Posted July 1 (edited) I use a Raspberry Pi 5 and use I2C1 with external eeprom. With v25.5.1 up to kernel 6.6.63-current-bcm2711, /dev/i2c-1 is there (activated in /boot/firmware/config.txt with dtparam=i2c_arm=on) and communication with eeprom works fine. With newer kernel versions, communication works not, /dev/i2c-1 does not exist anymore in this case without changing any configuration, just selected newer kernel using armbian-config Any ideas why this happens? Edited July 1 by CDit 0 Quote
laibsch Posted July 1 Posted July 1 It appears that Heiko is the maintainer for RPi boards (all varieties?) in Armbian, but I believe @Igor also has the device and maybe he can repond. I suggest you try to talk to Heiko and see if he has something to say. I just perused the git sources and you might want to talk to Pander as well. 0 Quote
Igor Posted July 1 Posted July 1 14 hours ago, CDit said: Any ideas why this happens? Feature regressions are expected - Linux kernel is complicated machinery and without spending hours, a day or a week investigating, it's usually not possible to tell. We don't touch Rpi kernels much. We have our own kernel config, but we use official Rpi sources, so I guess 1st step would be looking if someone reported something similar https://github.com/raspberrypi/linux/issues 14 hours ago, CDit said: selected newer kernel By newer you mean 6.12.y, 6.16.y ... or 6.6.63 -> 0 Quote
Matthew White Posted July 5 Posted July 5 I hadn't done an upgrade but a fresh install; (v25.5.1 for Raspberry Pi 3 Model B running Armbian Linux 6.12.28-current-bcm2711) Realised that I had the same problem, only channel 2 was present; though I only realised something was missing when I'd tried RaspberryOS on a Pi Zero with the same i2c device. Adding to the /boot/config.txt didn't of itself solve the issue; adding the i2c1 to the armbian-config overlays also didn't see. However I did find the `/boot/firmware/config.txt` that has a lot more settings, and seems to be where armbian-config edits Note the `dtparam-i2c_arm=on` line... which was commented out. Adding that back and it works... (well after figuring out I needed to level shift the i2c device but that's another story) # For more options and information see # http://rptl.io/configtxt # Some settings may impact device functionality. See link above for details # Uncomment some or all of these to enable the optional hardware interfaces dtparam=i2c_arm=on #dtparam=i2s=on #dtparam=spi=on # .. dtoverlay=dwc2 i2c0 i2c1 i2c-gpio vc4-kms-v3d 0 Quote
CaWeissWz Posted July 14 Posted July 14 I encountered the same issue using a custom v25.08 "RPi4b" image with kernel 6.12.37-current-bcm2711. I found out, that adding the following line to /boot/firmware/config.txt brings back the missing i2c device: Zitat dtoverlay=i2c1-pi5 However, this used to happen automatically with the old "RPi5" images. 0 Quote
laibsch Posted July 18 Posted July 18 On 7/14/2025 at 5:06 PM, CaWeissWz said: Quote dtoverlay=i2c1-pi5 @Igor Is this something that Armbian can add automatically for a board? Maybe that it did in the past? 0 Quote
Igor Posted July 19 Posted July 19 18 hours ago, laibsch said: Is this something that Armbian can add automatically for a board? Maybe that it did in the past? In the past we had dedicated image for rpi5 ... It could be added here: https://github.com/armbian/build/blob/main/packages/bsp/common/usr/lib/armbian/armbian-firstrun#L112-L122 0 Quote
laibsch Posted July 20 Posted July 20 I don't have time to work on this right away, so to make sure this does not fall off the radar, I opened a ticket in the tracker. 1 Quote
laibsch Posted July 31 Posted July 31 resolution: https://github.com/armbian/build/issues/8400#issuecomment-3136454158 0 Quote
