This isn't specific to armbian, I guess.
I am not sure if the mainline linux kernel supports USB peripheral/OTG on Banana Pi M2.
Armbian doesn't list anything in
/sys/class/udc
, so I assume it isn't.
In the v3.3 kernel released by Sinovoip, there is a dedicated option in the menuconfig for sunxi_usb. I am not sure where to look in the mainline kernel.
Anybody has a better idea about this?
Thank you.
OTG was just introduced to 4.4 RC5 ... I just read about and was doing some tests but in host mode and on A20. No idea if this is operational within A31s / M2 too and how is with OTG mode.
If you want to try it, check my last kernel build:
http://mirror.igorpecovnik.com/test/Armbian_5.00_Bananapi_Debian_jessie_4.4.0-rc5.zip [tested]
http://mirror.igorpecovnik.com/test/h3/ [not tested yet]
OTG mode is default, for host you need to alter DTB.
Upps, I was too quick on posting this. :( That image is with a boot loader for normal Banana with A20 but the kernel which is inside is the correct one.
Use the image from download section (that one works!) and install a kernel and DTB pack from test/h3 directory. This is not from mainline but from other sources so I am not sure OTG is already in but worth trying.
I'll compile from mainline later when got back in office and put to /test dir.
In any case use image from download section and change kernel(s).
EDIT:
Use this kernel upgrade. You can install all debs since there is a u-boot for M2 too.
http://mirror.igorpecovnik.com/test/m2-debs.zip
Thanks for the M2 debs!
It is failing to boot though, and gets stuck when "starting kernel" (screenshot)
There was one error when installing the new DTB
dpkg: error processing archive linux-dtb-dev-sunxi_5.00_armhf.deb (--install):
 trying to overwrite '/boot/dtb/sun8i-a33-et-q8-v1.6.dtb', which is also in package linux-dtb-next-sunxi 4.5
I'll try the H3 debs now
Exact same story  :P
But there's some hope (just to keep myself happy) - I randomly came across phy-sun4i-usb.ko (assuming it is also applicable for sun6i) in the modules list
OK, I'll try it.
EDIT: I found two problems
U-boot seeks for:
sun6i-a31s-bananapi-m2.dtb
but we have
sun6i-a31s-sinovoip-bpi-m2.dtb
Filesystem was corrupted for no reason. Have to check build process.
Wow! That was quick!!
Surprisingly, both sun6i-a31s-bananapi-m2.dts and sun6i-a31s-sinovoip-bpi-m2.dts are in the tree!
Just curious - where do I look for the U-boot logs?
I made just a quick look, perhaps the problem is only broken file system within image.
On a serial console where I also monitored a kernel output ... I am more or less out for today, so fixing probably comes tomorrow.
Yup, dmesg says ttyS0 is the serial port.
I did some digging around to learn a little more about U-boot and DTBs
Here's the commit that adds sun6i-a31s-sinovoip-bpi-m2 to the Makefile, but I can't figure out why sun6i-a31s-bananapi-m2.dts is still in the tree and when/why it was removed from the Makefile.
While the BPI-Mainline-uboot Makefile contains only sun6i-a31s-bananapi-m2.dts
I tried rebuilding the debs after changing the defconfig in U-boot. But the kernel doesn't boot anyway.
How do I see the detailed logs? I did change the loglevel in boot.cmd to 8, but the verbosity remains the same.
Edited by deadmetaphor
I was able to boot with a 4.4-rc6 kernel, but USB peripheral drivers don't seem to be present (at least /sys/class/udc is empty)
Guess, only Android images have this working :rolleyes:
Thanks for update. Have you load an module ? "sunxi"
Android kernel is buggy and has other limitations  :P
Yup, the BPI-M2 Android kernel is too "limiting" too. Because my final aim is to experiment with configfs gadgets (which seems more full-featured in the mainline kernel), but for some reason, Android refuses to boot if I do not enable android_usb.
I didn't try to load any modules manually. I'll try that now.
Thanks!
I had CONFIG_USB_MUSB_DUAL_ROLE=y instead of CONFIG_USB_MUSB_HOST=y
Also, I had to enable usb_otg in the dtb for BPI M2
And, now musb is printing something to dmesg, although it's an error:
[   74.232805] musb-sunxi 1c19000.usb: Invalid or missing 'dr_mode' property
[   74.239659] musb-sunxi: probe of 1c19000.usb failed with error -22
You need kernel 4.4+ and you might be missing this in device tree:
&usb_otg {
dr_mode = "otg";
status = "okay";
Change dr_mode to host
... if OTG is not operational and you will have a normal USB port but you need a powered usb hub.
I am using the 4.4-rc6 kernel.
You were exactly right about device tree config!
Setting dr_mode to "otg" (and CONFIG_USB_MUSB_DUAL_ROLE=y) gets rid of the "Invalid or missing 'dr_mode' property" error, but then there nothing in dmesg about musb (and right now I don't have an OTG cable to test if the host mode is working)
Setting dr_mode to "host" (CONFIG_USB_MUSB_HOST=y) gave the following
# dmesg | grep musb
[  107.463859] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[  107.463903] musb-hdrc: MHDRC RTL version 0.0
[  107.463937] musb-hdrc: 11/11 max ep, 5184/8192 memory
[  107.464250] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[  107.464299] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[  107.465117] usb usb3: Manufacturer: Linux 4.4.0-rc6-sunxi musb-hcd
[  107.465135] usb usb3: SerialNumber: musb-hdrc.1.auto
So, I assume it is working (again, unable to test it at the moment).
Setting dr_mode to "otg" (and CONFIG_USB_MUSB_GADGET=y) always gives an error
From drivers\usb\musb\sunxi.c
	switch (usb_get_dr_mode(&pdev->dev)) {
#if defined CONFIG_USB_MUSB_DUAL_ROLE || defined CONFIG_USB_MUSB_HOST
	case USB_DR_MODE_HOST:
		pdata.mode = MUSB_PORT_MODE_HOST;
		break;
#endif
#ifdef CONFIG_USB_MUSB_DUAL_ROLE
	case USB_DR_MODE_OTG:
		glue->extcon = extcon_get_edev_by_phandle(&pdev->dev, 0);
		if (IS_ERR(glue->extcon)) {
			if (PTR_ERR(glue->extcon) == -EPROBE_DEFER)
				return -EPROBE_DEFER;
			dev_err(&pdev->dev, "Invalid or missing extcon\n");
			return PTR_ERR(glue->extcon);
		pdata.mode = MUSB_PORT_MODE_DUAL_ROLE;
		break;
#endif
	default:
		dev_err(&pdev->dev, "Invalid or missing 'dr_mode' property\n");
		return -EINVAL;
TL;DR:
  • OTG mode will work only if CONFIG_USB_MUSB_DUAL_ROLE is set
  • Host mode will work if either of CONFIG_USB_MUSB_DUAL_ROLE and CONFIG_USB_MUSB_HOST are set
Aha! No wonder CONFIG_USB_MUSB_GADGET=y always had that error...it's decided at compile time. Thanks!
I did find a lot of "gadget" related handling in musb, now I have to figure out if MUSB_PORT_MODE_DUAL_ROLE supports gadget mode. And, if I have the right .config to make it work (assuming it's expected to work on A31 based boards).
