robertoj Posted July 8, 2025 Posted July 8, 2025 (edited) I am using my orange pi zero 3 with an SPI 4.0" LCD, with driver panel-mipi-dbi-spi. It works great with Linux 6.13.7 (started with a self built image with edge, minimal, Bookworm) and older, but I am having troubles with 6.14.8. Result from armbianmonitor -u after upgrading to linux 6.14.8: sudo apt install linux-image-edge-sunxi64=25.5.1 I reboot and the SPI LCD starts the text mode console, then turns black instead of starting lightdm https://paste.armbian.com/ucoxuwetiq Also xorg log after "sudo startx" fails to start. Spoiler roberto@orangepizero3:~$ tail -n300 /var/log/Xorg.0.log [ 234.918] X.Org X Server 1.21.1.7 X Protocol Version 11, Revision 0 [ 234.918] Current Operating System: Linux orangepizero3 6.14.8-edge-sunxi64 #1 SMP Thu May 22 12:31:58 UTC 2025 aarch64 [ 234.918] Kernel command line: root=UUID=405815fa-b5a7-4731-8675-6d56d040972c rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 console=tty1 consoleblank=0 loglevel=1 ubootpart=a66e3381-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=memory [ 234.918] xorg-server 2:21.1.7-3+deb12u10 (https://www.debian.org/support) [ 234.918] Current version of pixman: 0.42.2 [ 234.918] Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. [ 234.918] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. [ 234.918] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Jul 8 06:04:03 2025 [ 234.919] (==) Using config directory: "/etc/X11/xorg.conf.d" [ 234.919] (==) Using system config directory "/usr/share/X11/xorg.conf.d" [ 234.919] (==) No Layout section. Using the first Screen section. [ 234.919] (==) No screen section available. Using defaults. [ 234.919] (**) |-->Screen "Default Screen Section" (0) [ 234.920] (**) | |-->Monitor "<default monitor>" [ 234.920] (==) No device specified for screen "Default Screen Section". Using the first device section listed. [ 234.920] (**) | |-->Device "myfb" [ 234.920] (==) No monitor specified for screen "Default Screen Section". Using a default monitor configuration. [ 234.920] (==) Automatically adding devices [ 234.920] (==) Automatically enabling devices [ 234.920] (==) Automatically adding GPU devices [ 234.920] (==) Automatically binding GPU devices [ 234.920] (==) Max clients allowed: 256, resource mask: 0x1fffff [ 234.920] (WW) The directory "/usr/share/fonts/X11/misc" does not exist. [ 234.920] Entry deleted from font path. [ 234.920] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist. [ 234.920] Entry deleted from font path. [ 234.920] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist. [ 234.920] Entry deleted from font path. [ 234.920] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist. [ 234.920] Entry deleted from font path. [ 234.921] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist. [ 234.921] Entry deleted from font path. [ 234.921] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist. [ 234.921] Entry deleted from font path. [ 234.921] (==) FontPath set to: /usr/share/fonts/X11/Type1, built-ins [ 234.921] (==) ModulePath set to "/usr/lib/xorg/modules" [ 234.921] (II) The server relies on udev to provide the list of input devices. If no devices become available, reconfigure udev or disable AutoAddDevices. [ 234.921] (II) Loader magic: 0xaaaac7840f00 [ 234.921] (II) Module ABI versions: [ 234.921] X.Org ANSI C Emulation: 0.4 [ 234.921] X.Org Video Driver: 25.2 [ 234.921] X.Org XInput driver : 24.4 [ 234.921] X.Org Server Extension : 10.0 [ 234.922] (--) using VT number 2 [ 234.922] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration [ 234.926] (II) xfree86: Adding drm device (/dev/dri/card0) [ 234.926] (II) Platform probe for /sys/devices/platform/display-engine/drm/card0 [ 234.926] (II) xfree86: Adding drm device (/dev/dri/card2) [ 234.926] (II) Platform probe for /sys/devices/platform/soc/1800000.gpu/drm/card2 [ 234.927] (II) xfree86: Adding drm device (/dev/dri/card1) [ 234.927] (II) Platform probe for /sys/devices/platform/soc/5011000.spi/spi_master/spi1/spi1.0/drm/card1 [ 235.025] (II) no primary bus or device found [ 235.025] falling back to /sys/devices/platform/display-engine/drm/card0 [ 235.026] (II) LoadModule: "glx" [ 235.026] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so [ 235.029] (II) Module glx: vendor="X.Org Foundation" [ 235.030] compiled for 1.21.1.7, module version = 1.0.0 [ 235.030] ABI class: X.Org Server Extension, version 10.0 [ 235.030] (II) LoadModule: "fbdev" [ 235.030] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so [ 235.030] (II) Module fbdev: vendor="X.Org Foundation" [ 235.030] compiled for 1.21.1.3, module version = 0.5.0 [ 235.030] Module class: X.Org Video Driver [ 235.030] ABI class: X.Org Video Driver, version 25.2 [ 235.030] (II) FBDEV: driver for framebuffer: fbdev [ 235.131] (WW) Falling back to old probe method for fbdev [ 235.131] (II) Loading sub module "fbdevhw" [ 235.131] (II) LoadModule: "fbdevhw" [ 235.132] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so [ 235.132] (II) Module fbdevhw: vendor="X.Org Foundation" [ 235.133] compiled for 1.21.1.7, module version = 0.0.2 [ 235.133] ABI class: X.Org Video Driver, version 25.2 [ 235.133] (II) FBDEV(0): using /dev/fb0 [ 235.133] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support [ 235.133] (II) FBDEV(0): Creating default Display subsection in Screen section "Default Screen Section" for depth/fbbpp 24/32 [ 235.133] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32 [ 235.133] (==) FBDEV(0): RGB weight 888 [ 235.133] (==) FBDEV(0): Default visual is TrueColor [ 235.133] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0) [ 235.133] (II) FBDEV(0): hardware: panel-mipi-dbid (video memory: 452kB) [ 235.133] (DB) xf86MergeOutputClassOptions unsupported bus type 0 [ 235.133] (**) FBDEV(0): Option "fbdev" "/dev/fb0" [ 235.133] (II) FBDEV(0): checking modes against framebuffer device... [ 235.133] (II) FBDEV(0): checking modes against monitor... [ 235.133] (II) FBDEV(0): Virtual size is 480x320 (pitch 480) [ 235.133] (**) FBDEV(0): Built-in mode "current" [ 235.133] (==) FBDEV(0): DPI set to (96, 96) [ 235.133] (II) Loading sub module "fb" [ 235.133] (II) LoadModule: "fb" [ 235.133] (II) Module "fb" already built-in [ 235.133] (**) FBDEV(0): using shadow framebuffer [ 235.133] (II) Loading sub module "shadow" [ 235.133] (II) LoadModule: "shadow" [ 235.133] (II) Loading /usr/lib/xorg/modules/libshadow.so [ 235.134] (II) Module shadow: vendor="X.Org Foundation" [ 235.134] compiled for 1.21.1.7, module version = 1.1.0 [ 235.134] ABI class: X.Org ANSI C Emulation, version 0.4 [ 235.134] (EE) FBDEV(0): FBIOPUT_VSCREENINFO: Invalid argument [ 235.134] (EE) FBDEV(0): mode initialization failed [ 235.134] (EE) Fatal server error: [ 235.134] (EE) AddScreen/ScreenInit failed for driver 0 [ 235.134] (EE) [ 235.134] (EE) Please consult the The X.Org Foundation support at http://wiki.x.org for help. [ 235.134] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information. [ 235.134] (EE) [ 235.634] (EE) Server terminated with error (1). Closing log file. When I start the opiz3 with an HDMI screen connected (appears as /dev/fb0), startx and lightdm start normally, but NOT displaying anything in the small LCD Then, I downgrade to linux 6.13.7, sudo apt install linux-image-edge-sunxi64=25.2.3 I reboot and lightdm starts normally in the 4.0 LCD https://paste.armbian.com/uqafuxexiv Stopping lightdm and trying x11 to see the log sudo startx ... starts xorg normally Spoiler roberto@orangepizero3:~$ tail -n600 /var/log/Xorg.0.log [ 191.489] X.Org X Server 1.21.1.7 X Protocol Version 11, Revision 0 [ 191.490] Current Operating System: Linux orangepizero3 6.13.7-edge-sunxi64 #2 SMP Thu Mar 13 12:08:08 UTC 2025 aarch64 [ 191.490] Kernel command line: root=UUID=405815fa-b5a7-4731-8675-6d56d040972c rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 console=tty1 consoleblank=0 loglevel=1 ubootpart=a66e3381-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=memory [ 191.490] xorg-server 2:21.1.7-3+deb12u10 (https://www.debian.org/support) [ 191.490] Current version of pixman: 0.42.2 [ 191.490] Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. [ 191.490] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. [ 191.490] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Jul 8 06:36:59 2025 [ 191.491] (==) Using config directory: "/etc/X11/xorg.conf.d" [ 191.491] (==) Using system config directory "/usr/share/X11/xorg.conf.d" [ 191.492] (==) No Layout section. Using the first Screen section. [ 191.492] (==) No screen section available. Using defaults. [ 191.492] (**) |-->Screen "Default Screen Section" (0) [ 191.492] (**) | |-->Monitor "<default monitor>" [ 191.494] (==) No device specified for screen "Default Screen Section". Using the first device section listed. [ 191.494] (**) | |-->Device "myfb" [ 191.494] (==) No monitor specified for screen "Default Screen Section". Using a default monitor configuration. [ 191.494] (==) Automatically adding devices [ 191.494] (==) Automatically enabling devices [ 191.494] (==) Automatically adding GPU devices [ 191.494] (==) Automatically binding GPU devices [ 191.494] (==) Max clients allowed: 256, resource mask: 0x1fffff [ 191.494] (WW) The directory "/usr/share/fonts/X11/misc" does not exist. [ 191.494] Entry deleted from font path. [ 191.494] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist. [ 191.494] Entry deleted from font path. [ 191.494] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist. [ 191.494] Entry deleted from font path. [ 191.494] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist. [ 191.494] Entry deleted from font path. [ 191.494] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist. [ 191.494] Entry deleted from font path. [ 191.494] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist. [ 191.494] Entry deleted from font path. [ 191.494] (==) FontPath set to: /usr/share/fonts/X11/Type1, built-ins [ 191.494] (==) ModulePath set to "/usr/lib/xorg/modules" [ 191.494] (II) The server relies on udev to provide the list of input devices. If no devices become available, reconfigure udev or disable AutoAddDevices. [ 191.494] (II) Loader magic: 0xaaaabd9a0f00 [ 191.495] (II) Module ABI versions: [ 191.495] X.Org ANSI C Emulation: 0.4 [ 191.495] X.Org Video Driver: 25.2 [ 191.495] X.Org XInput driver : 24.4 [ 191.495] X.Org Server Extension : 10.0 [ 191.498] (--) using VT number 2 [ 191.498] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration [ 191.504] (II) xfree86: Adding drm device (/dev/dri/card0) [ 191.504] (II) Platform probe for /sys/devices/platform/display-engine/drm/card0 [ 191.505] (II) xfree86: Adding drm device (/dev/dri/card2) [ 191.505] (II) Platform probe for /sys/devices/platform/soc/1800000.gpu/drm/card2 [ 191.506] (II) xfree86: Adding drm device (/dev/dri/card1) [ 191.506] (II) Platform probe for /sys/devices/platform/soc/5011000.spi/spi_master/spi1/spi1.0/drm/card1 [ 191.609] (II) no primary bus or device found [ 191.609] falling back to /sys/devices/platform/display-engine/drm/card0 [ 191.609] (II) LoadModule: "glx" [ 191.609] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so [ 191.613] (II) Module glx: vendor="X.Org Foundation" [ 191.613] compiled for 1.21.1.7, module version = 1.0.0 [ 191.613] ABI class: X.Org Server Extension, version 10.0 [ 191.613] (II) LoadModule: "fbdev" [ 191.613] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so [ 191.614] (II) Module fbdev: vendor="X.Org Foundation" [ 191.614] compiled for 1.21.1.3, module version = 0.5.0 [ 191.614] Module class: X.Org Video Driver [ 191.614] ABI class: X.Org Video Driver, version 25.2 [ 191.614] (II) FBDEV: driver for framebuffer: fbdev [ 191.716] (WW) Falling back to old probe method for fbdev [ 191.716] (II) Loading sub module "fbdevhw" [ 191.716] (II) LoadModule: "fbdevhw" [ 191.716] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so [ 191.717] (II) Module fbdevhw: vendor="X.Org Foundation" [ 191.717] compiled for 1.21.1.7, module version = 0.0.2 [ 191.717] ABI class: X.Org Video Driver, version 25.2 [ 191.717] (II) FBDEV(0): using /dev/fb0 [ 191.717] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support [ 191.717] (II) FBDEV(0): Creating default Display subsection in Screen section "Default Screen Section" for depth/fbbpp 24/32 [ 191.717] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32 [ 191.717] (==) FBDEV(0): RGB weight 888 [ 191.717] (==) FBDEV(0): Default visual is TrueColor [ 191.717] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0) [ 191.717] (II) FBDEV(0): hardware: panel-mipi-dbid (video memory: 600kB) [ 191.717] (DB) xf86MergeOutputClassOptions unsupported bus type 0 [ 191.717] (**) FBDEV(0): Option "fbdev" "/dev/fb0" [ 191.717] (II) FBDEV(0): checking modes against framebuffer device... [ 191.717] (II) FBDEV(0): checking modes against monitor... [ 191.717] (II) FBDEV(0): Virtual size is 480x320 (pitch 480) [ 191.717] (**) FBDEV(0): Built-in mode "current" [ 191.717] (==) FBDEV(0): DPI set to (96, 96) [ 191.717] (II) Loading sub module "fb" [ 191.717] (II) LoadModule: "fb" [ 191.717] (II) Module "fb" already built-in [ 191.717] (**) FBDEV(0): using shadow framebuffer [ 191.717] (II) Loading sub module "shadow" [ 191.717] (II) LoadModule: "shadow" [ 191.718] (II) Loading /usr/lib/xorg/modules/libshadow.so [ 191.718] (II) Module shadow: vendor="X.Org Foundation" [ 191.718] compiled for 1.21.1.7, module version = 1.1.0 [ 191.718] ABI class: X.Org ANSI C Emulation, version 0.4 [ 192.532] (==) FBDEV(0): Backing store enabled [ 192.533] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument [ 192.533] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument [ 192.533] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument [ 192.533] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument Error...repeated 200 times, but X11 starts normally [ 192.536] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument [ 192.536] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument [ 192.536] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument [ 192.536] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument [ 192.537] (==) FBDEV(0): DPMS enabled [ 192.537] (II) Initializing extension Generic Event Extension [ 192.537] (II) Initializing extension SHAPE [ 192.538] (II) Initializing extension MIT-SHM [ 192.538] (II) Initializing extension XInputExtension [ 192.539] (II) Initializing extension XTEST [ 192.539] (II) Initializing extension BIG-REQUESTS [ 192.540] (II) Initializing extension SYNC [ 192.540] (II) Initializing extension XKEYBOARD [ 192.541] (II) Initializing extension XC-MISC [ 192.541] (II) Initializing extension SECURITY [ 192.542] (II) Initializing extension XFIXES [ 192.542] (II) Initializing extension RENDER [ 192.542] (II) Initializing extension RANDR [ 192.543] (II) Initializing extension COMPOSITE [ 192.544] (II) Initializing extension DAMAGE [ 192.544] (II) Initializing extension MIT-SCREEN-SAVER [ 192.545] (II) Initializing extension DOUBLE-BUFFER [ 192.545] (II) Initializing extension RECORD [ 192.546] (II) Initializing extension DPMS [ 192.546] (II) Initializing extension Present [ 192.547] (II) Initializing extension DRI3 [ 192.547] (II) Initializing extension X-Resource [ 192.547] (II) Initializing extension XVideo [ 192.548] (II) Initializing extension XVideo-MotionCompensation [ 192.548] (II) Initializing extension SELinux [ 192.548] (II) SELinux: Disabled on system [ 192.548] (II) Initializing extension GLX [ 192.548] (II) AIGLX: Screen 0 is not DRI2 capable [ 192.677] (II) IGLX: Loaded and initialized swrast [ 192.678] (II) GLX: Initialized DRISWRAST GL provider for screen 0 [ 192.678] (II) Initializing extension XFree86-VidModeExtension [ 192.678] (II) Initializing extension XFree86-DGA [ 192.679] (II) Initializing extension XFree86-DRI [ 192.679] (II) Initializing extension DRI2 [ 192.798] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/input/event4) [ 192.798] (**) ADS7846 Touchscreen: Applying InputClass "evdev touchscreen catchall" [ 192.798] (**) ADS7846 Touchscreen: Applying InputClass "evdev touchscreen catchall" [ 192.798] (**) ADS7846 Touchscreen: Applying InputClass "calibration" [ 192.798] (II) LoadModule: "evdev" [ 192.798] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so [ 192.800] (II) Module evdev: vendor="X.Org Foundation" [ 192.800] compiled for 1.21.1.3, module version = 2.10.6 [ 192.800] Module class: X.Org XInput Driver [ 192.800] ABI class: X.Org XInput driver, version 24.4 [ 192.800] (II) Using input driver 'evdev' for 'ADS7846 Touchscreen' [ 192.800] (**) ADS7846 Touchscreen: always reports core events [ 192.800] (**) evdev: ADS7846 Touchscreen: Device: "/dev/input/event4" [ 192.800] (--) evdev: ADS7846 Touchscreen: Vendor 0 Product 0x1ea6 [ 192.800] (--) evdev: ADS7846 Touchscreen: Found absolute axes [ 192.800] (--) evdev: ADS7846 Touchscreen: Found x and y absolute axes [ 192.800] (--) evdev: ADS7846 Touchscreen: Found absolute touchscreen [ 192.800] (**) Option "SwapAxes" "0" [ 192.800] (II) evdev: ADS7846 Touchscreen: Configuring as touchscreen [ 192.800] (**) evdev: ADS7846 Touchscreen: YAxisMapping: buttons 4 and 5 [ 192.800] (**) evdev: ADS7846 Touchscreen: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200 [ 192.800] (**) Option "config_info" "udev:/sys/devices/platform/soc/5011000.spi/spi_master/spi1/spi1.1/input/input4/event4" [ 192.801] (II) XINPUT: Adding extended input device "ADS7846 Touchscreen" (type: TOUCHSCREEN, id 6) [ 192.801] (II) evdev: ADS7846 Touchscreen: initialized for absolute axes. [ 192.801] (**) ADS7846 Touchscreen: (accel) keeping acceleration scheme 1 [ 192.801] (**) ADS7846 Touchscreen: (accel) acceleration profile 0 [ 192.801] (**) ADS7846 Touchscreen: (accel) acceleration factor: 2.000 [ 192.801] (**) ADS7846 Touchscreen: (accel) acceleration threshold: 4 [ 192.803] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/input/mouse1) [ 192.803] (**) ADS7846 Touchscreen: Applying InputClass "calibration" [ 192.803] (II) No input driver specified, ignoring this device. [ 192.803] (II) This device may have been added with another device file. [ 192.805] (II) config/udev: Adding input device Mitsumi Electric Apple Extended USB Keyboard (/dev/input/event0) [ 192.805] (**) Mitsumi Electric Apple Extended USB Keyboard: Applying InputClass "evdev keyboard catchall" [ 192.805] (**) Mitsumi Electric Apple Extended USB Keyboard: Applying InputClass "evdev keyboard catchall" [ 192.805] (II) Using input driver 'evdev' for 'Mitsumi Electric Apple Extended USB Keyboard' [ 192.805] (**) Mitsumi Electric Apple Extended USB Keyboard: always reports core events [ 192.805] (**) evdev: Mitsumi Electric Apple Extended USB Keyboard: Device: "/dev/input/event0" [ 192.806] (--) evdev: Mitsumi Electric Apple Extended USB Keyboard: Vendor 0x5ac Product 0x204 [ 192.806] (--) evdev: Mitsumi Electric Apple Extended USB Keyboard: Found keys [ 192.806] (II) evdev: Mitsumi Electric Apple Extended USB Keyboard: Configuring as keyboard [ 192.806] (**) Option "config_info" "udev:/sys/devices/platform/soc/5311400.usb/usb6/6-1/6-1.1/6-1.1:1.0/0003:05AC:0204.0001/input/input0/event0" [ 192.806] (II) XINPUT: Adding extended input device "Mitsumi Electric Apple Extended USB Keyboard" (type: KEYBOARD, id 7) [ 192.806] (**) Option "xkb_rules" "evdev" [ 192.806] (**) Option "xkb_model" "pc105" [ 192.806] (**) Option "xkb_layout" "us" [ 192.809] (II) config/udev: Adding input device Mitsumi Electric Apple Extended USB Keyboard System Control (/dev/input/event1) [ 192.809] (**) Mitsumi Electric Apple Extended USB Keyboard System Control: Applying InputClass "evdev keyboard catchall" [ 192.809] (**) Mitsumi Electric Apple Extended USB Keyboard System Control: Applying InputClass "evdev keyboard catchall" [ 192.809] (II) Using input driver 'evdev' for 'Mitsumi Electric Apple Extended USB Keyboard System Control' [ 192.809] (**) Mitsumi Electric Apple Extended USB Keyboard System Control: always reports core events [ 192.809] (**) evdev: Mitsumi Electric Apple Extended USB Keyboard System Control: Device: "/dev/input/event1" [ 192.809] (--) evdev: Mitsumi Electric Apple Extended USB Keyboard System Control: Vendor 0x5ac Product 0x204 [ 192.809] (--) evdev: Mitsumi Electric Apple Extended USB Keyboard System Control: Found keys [ 192.809] (II) evdev: Mitsumi Electric Apple Extended USB Keyboard System Control: Configuring as keyboard [ 192.809] (**) Option "config_info" "udev:/sys/devices/platform/soc/5311400.usb/usb6/6-1/6-1.1/6-1.1:1.1/0003:05AC:0204.0002/input/input1/event1" [ 192.809] (II) XINPUT: Adding extended input device "Mitsumi Electric Apple Extended USB Keyboard System Control" (type: KEYBOARD, id 😎 [ 192.809] (**) Option "xkb_rules" "evdev" [ 192.809] (**) Option "xkb_model" "pc105" [ 192.809] (**) Option "xkb_layout" "us" [ 192.812] (II) config/udev: Adding input device Mitsumi Electric Apple Extended USB Keyboard Consumer Control (/dev/input/event2) [ 192.812] (**) Mitsumi Electric Apple Extended USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall" [ 192.813] (**) Mitsumi Electric Apple Extended USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall" [ 192.813] (II) Using input driver 'evdev' for 'Mitsumi Electric Apple Extended USB Keyboard Consumer Control' [ 192.813] (**) Mitsumi Electric Apple Extended USB Keyboard Consumer Control: always reports core events [ 192.813] (**) evdev: Mitsumi Electric Apple Extended USB Keyboard Consumer Control: Device: "/dev/input/event2" [ 192.813] (--) evdev: Mitsumi Electric Apple Extended USB Keyboard Consumer Control: Vendor 0x5ac Product 0x204 [ 192.813] (--) evdev: Mitsumi Electric Apple Extended USB Keyboard Consumer Control: Found keys [ 192.813] (II) evdev: Mitsumi Electric Apple Extended USB Keyboard Consumer Control: Configuring as keyboard [ 192.813] (**) Option "config_info" "udev:/sys/devices/platform/soc/5311400.usb/usb6/6-1/6-1.1/6-1.1:1.1/0003:05AC:0204.0002/input/input2/event2" [ 192.813] (II) XINPUT: Adding extended input device "Mitsumi Electric Apple Extended USB Keyboard Consumer Control" (type: KEYBOARD, id 9) [ 192.813] (**) Option "xkb_rules" "evdev" [ 192.813] (**) Option "xkb_model" "pc105" [ 192.813] (**) Option "xkb_layout" "us" [ 192.816] (II) config/udev: Adding input device PixArt USB Optical Mouse (/dev/input/event3) [ 192.816] (**) PixArt USB Optical Mouse: Applying InputClass "evdev pointer catchall" [ 192.816] (**) PixArt USB Optical Mouse: Applying InputClass "evdev pointer catchall" [ 192.816] (II) Using input driver 'evdev' for 'PixArt USB Optical Mouse' [ 192.816] (**) PixArt USB Optical Mouse: always reports core events [ 192.816] (**) evdev: PixArt USB Optical Mouse: Device: "/dev/input/event3" [ 192.816] (--) evdev: PixArt USB Optical Mouse: Vendor 0x93a Product 0x2510 [ 192.816] (--) evdev: PixArt USB Optical Mouse: Found 3 mouse buttons [ 192.816] (--) evdev: PixArt USB Optical Mouse: Found scroll wheel(s) [ 192.816] (--) evdev: PixArt USB Optical Mouse: Found relative axes [ 192.816] (--) evdev: PixArt USB Optical Mouse: Found x and y relative axes [ 192.816] (II) evdev: PixArt USB Optical Mouse: Configuring as mouse [ 192.816] (II) evdev: PixArt USB Optical Mouse: Adding scrollwheel support [ 192.816] (**) evdev: PixArt USB Optical Mouse: YAxisMapping: buttons 4 and 5 [ 192.816] (**) evdev: PixArt USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200 [ 192.816] (**) Option "config_info" "udev:/sys/devices/platform/soc/5311400.usb/usb6/6-1/6-1.2/6-1.2:1.0/0003:093A:2510.0003/input/input3/event3" [ 192.816] (II) XINPUT: Adding extended input device "PixArt USB Optical Mouse" (type: MOUSE, id 10) [ 192.817] (II) evdev: PixArt USB Optical Mouse: initialized for relative axes. [ 192.817] (**) PixArt USB Optical Mouse: (accel) keeping acceleration scheme 1 [ 192.817] (**) PixArt USB Optical Mouse: (accel) acceleration profile 0 [ 192.817] (**) PixArt USB Optical Mouse: (accel) acceleration factor: 2.000 [ 192.817] (**) PixArt USB Optical Mouse: (accel) acceleration threshold: 4 [ 192.819] (II) config/udev: Adding input device PixArt USB Optical Mouse (/dev/input/mouse0) [ 192.819] (II) No input driver specified, ignoring this device. [ 192.819] (II) This device may have been added with another device file. [ 232.119] (II) evdev: PixArt USB Optical Mouse: Close [ 232.119] (II) UnloadModule: "evdev" [ 232.119] (II) evdev: Mitsumi Electric Apple Extended USB Keyboard Consumer Control: Close [ 232.119] (II) UnloadModule: "evdev" [ 232.120] (II) evdev: Mitsumi Electric Apple Extended USB Keyboard System Control: Close [ 232.120] (II) UnloadModule: "evdev" [ 232.120] (II) evdev: Mitsumi Electric Apple Extended USB Keyboard: Close [ 232.120] (II) UnloadModule: "evdev" [ 232.120] (II) evdev: ADS7846 Touchscreen: Close [ 232.120] (II) UnloadModule: "evdev" [ 232.565] (II) Server terminated successfully (0). Closing log file. roberto@orangepizero3:~$ Just downgrading to Linux 6.13.7 allows the 4.0" SPI LCD to work again. Dowgrading the linux package did not cause a downgrade of X11 (version 1.21.1.7). The small LCD always works ok in text mode. The driver is DRM but it is using the X11 fbdev submodule The fbdev.conf file: Spoiler roberto@orangepizero3:~$ cat /etc/X11/xorg.conf.d/99-fbdev.conf Section "Device" Identifier "myfb" Driver "fbdev" Option "fbdev" "/dev/fb0" EndSection Using an HDMI screen is not affected When I disable the fbdev conf file sudo mv 99-fbdev.conf 99-fbdev.conf.disabled Then x11 fails in another way: Spoiler roberto@orangepizero3:/etc/X11/xorg.conf.d$ sudo startx X.Org X Server 1.21.1.7 X Protocol Version 11, Revision 0 Current Operating System: Linux orangepizero3 6.13.7-edge-sunxi64 #2 SMP Thu Mar 13 12:08:08 UTC 2025 aarch64 Kernel command line: root=UUID=405815fa-b5a7-4731-8675-6d56d040972c rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 console=tty1 consoleblank=0 loglevel=1 ubootpart=a66e3381-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=memory xorg-server 2:21.1.7-3+deb12u10 (https://www.debian.org/support) Current version of pixman: 0.42.2 Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (==) Log file: "/var/log/Xorg.0.log", Time: Tue Jul 8 06:53:10 2025 (==) Using config directory: "/etc/X11/xorg.conf.d" (==) Using system config directory "/usr/share/X11/xorg.conf.d" MESA-LOADER: failed to open panel-mipi-dbi: /usr/lib/dri/panel-mipi-dbi_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/aarch64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) failed to load driver: panel-mipi-dbi ^Cxinit: connection to X server lost waiting for X server to shut down .(II) Server terminated successfully (0). Closing log file. xinit: unexpected signal 2 roberto@orangepizero3:/etc/X11/xorg.conf.d$ The xorg log doesn't show any error: Spoiler roberto@orangepizero3:/etc/X11/xorg.conf.d$ tail -n500 /var/log/Xorg.0.log [ 1161.992] X.Org X Server 1.21.1.7 X Protocol Version 11, Revision 0 [ 1161.992] Current Operating System: Linux orangepizero3 6.13.7-edge-sunxi64 #2 SMP Thu Mar 13 12:08:08 UTC 2025 aarch64 [ 1161.992] Kernel command line: root=UUID=405815fa-b5a7-4731-8675-6d56d040972c rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 console=tty1 consoleblank=0 loglevel=1 ubootpart=a66e3381-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=memory [ 1161.993] xorg-server 2:21.1.7-3+deb12u10 (https://www.debian.org/support) [ 1161.993] Current version of pixman: 0.42.2 [ 1161.993] Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. [ 1161.993] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. [ 1161.993] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Jul 8 06:53:10 2025 [ 1161.993] (==) Using config directory: "/etc/X11/xorg.conf.d" [ 1161.993] (==) Using system config directory "/usr/share/X11/xorg.conf.d" [ 1161.994] (==) No Layout section. Using the first Screen section. [ 1161.994] (==) No screen section available. Using defaults. [ 1161.994] (**) |-->Screen "Default Screen Section" (0) [ 1161.994] (**) | |-->Monitor "<default monitor>" [ 1161.995] (==) No monitor specified for screen "Default Screen Section". Using a default monitor configuration. [ 1161.995] (==) Automatically adding devices [ 1161.995] (==) Automatically enabling devices [ 1161.995] (==) Automatically adding GPU devices [ 1161.995] (==) Automatically binding GPU devices [ 1161.995] (==) Max clients allowed: 256, resource mask: 0x1fffff [ 1161.995] (WW) The directory "/usr/share/fonts/X11/misc" does not exist. [ 1161.995] Entry deleted from font path. [ 1161.995] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist. [ 1161.995] Entry deleted from font path. [ 1161.995] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist. [ 1161.995] Entry deleted from font path. [ 1161.995] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist. [ 1161.995] Entry deleted from font path. [ 1161.995] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist. [ 1161.995] Entry deleted from font path. [ 1161.995] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist. [ 1161.995] Entry deleted from font path. [ 1161.995] (==) FontPath set to: /usr/share/fonts/X11/Type1, built-ins [ 1161.995] (==) ModulePath set to "/usr/lib/xorg/modules" [ 1161.995] (II) The server relies on udev to provide the list of input devices. If no devices become available, reconfigure udev or disable AutoAddDevices. [ 1161.995] (II) Loader magic: 0xaaaaab5a0f00 [ 1161.995] (II) Module ABI versions: [ 1161.995] X.Org ANSI C Emulation: 0.4 [ 1161.995] X.Org Video Driver: 25.2 [ 1161.995] X.Org XInput driver : 24.4 [ 1161.995] X.Org Server Extension : 10.0 [ 1161.997] (--) using VT number 2 [ 1161.997] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration [ 1162.000] (II) xfree86: Adding drm device (/dev/dri/card0) [ 1162.000] (II) Platform probe for /sys/devices/platform/display-engine/drm/card0 [ 1162.000] (II) xfree86: Adding drm device (/dev/dri/card2) [ 1162.001] (II) Platform probe for /sys/devices/platform/soc/1800000.gpu/drm/card2 [ 1162.001] (II) xfree86: Adding drm device (/dev/dri/card1) [ 1162.001] (II) Platform probe for /sys/devices/platform/soc/5011000.spi/spi_master/spi1/spi1.0/drm/card1 [ 1162.102] (II) no primary bus or device found [ 1162.102] falling back to /sys/devices/platform/display-engine/drm/card0 [ 1162.102] (II) LoadModule: "glx" [ 1162.103] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so [ 1162.106] (II) Module glx: vendor="X.Org Foundation" [ 1162.106] compiled for 1.21.1.7, module version = 1.0.0 [ 1162.106] ABI class: X.Org Server Extension, version 10.0 [ 1162.106] (==) Matched modesetting as autoconfigured driver 0 [ 1162.106] (==) Matched fbdev as autoconfigured driver 1 [ 1162.106] (==) Assigned the driver to the xf86ConfigLayout [ 1162.106] (II) LoadModule: "modesetting" [ 1162.107] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so [ 1162.107] (II) Module modesetting: vendor="X.Org Foundation" [ 1162.107] compiled for 1.21.1.7, module version = 1.21.1 [ 1162.107] Module class: X.Org Video Driver [ 1162.107] ABI class: X.Org Video Driver, version 25.2 [ 1162.107] (II) LoadModule: "fbdev" [ 1162.107] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so [ 1162.107] (II) Module fbdev: vendor="X.Org Foundation" [ 1162.107] compiled for 1.21.1.3, module version = 0.5.0 [ 1162.108] Module class: X.Org Video Driver [ 1162.108] ABI class: X.Org Video Driver, version 25.2 [ 1162.108] (II) modesetting: Driver for Modesetting Kernel Drivers: kms [ 1162.108] (II) FBDEV: driver for framebuffer: fbdev [ 1162.210] (II) modeset(0): using drv /dev/dri/card0 [ 1162.210] (WW) Falling back to old probe method for fbdev [ 1162.210] (II) Loading sub module "fbdevhw" [ 1162.210] (II) LoadModule: "fbdevhw" [ 1162.210] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so [ 1162.211] (II) Module fbdevhw: vendor="X.Org Foundation" [ 1162.211] compiled for 1.21.1.7, module version = 0.0.2 [ 1162.211] ABI class: X.Org Video Driver, version 25.2 [ 1162.411] (II) modeset(G0): using drv /dev/dri/card1 [ 1162.411] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support [ 1162.411] (II) modeset(0): Creating default Display subsection in Screen section "Default Screen Section" for depth/fbbpp 24/32 [ 1162.411] (==) modeset(0): Depth 24, (==) framebuffer bpp 32 [ 1162.411] (==) modeset(0): RGB weight 888 [ 1162.411] (==) modeset(0): Default visual is TrueColor [ 1162.411] (II) Loading sub module "glamoregl" [ 1162.411] (II) LoadModule: "glamoregl" [ 1162.412] (II) Loading /usr/lib/xorg/modules/libglamoregl.so [ 1162.428] (II) Module glamoregl: vendor="X.Org Foundation" [ 1162.428] compiled for 1.21.1.7, module version = 1.0.1 [ 1162.428] ABI class: X.Org ANSI C Emulation, version 0.4 [ 1162.810] (II) modeset(0): glamor X acceleration enabled on Mali-G31 (Panfrost) [ 1162.810] (II) modeset(0): glamor initialized [ 1162.810] (==) modeset(0): VariableRefresh: disabled [ 1162.810] (==) modeset(0): AsyncFlipSecondaries: disabled [ 1162.810] (II) modeset(0): Output HDMI-1 has no monitor section [ 1162.810] (II) modeset(0): EDID for output HDMI-1 [ 1162.811] (II) modeset(0): Output HDMI-1 disconnected [ 1162.811] (WW) modeset(0): No outputs definitely connected, trying again... [ 1162.811] (II) modeset(0): Output HDMI-1 disconnected [ 1162.811] (WW) modeset(0): Unable to find connected outputs - setting 1024x768 initial framebuffer [ 1162.811] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0) [ 1162.811] (==) modeset(0): DPI set to (96, 96) [ 1162.811] (II) Loading sub module "fb" [ 1162.811] (II) LoadModule: "fb" [ 1162.811] (II) Module "fb" already built-in [ 1162.813] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32 [ 1162.813] (==) modeset(G0): RGB weight 888 [ 1162.813] (==) modeset(G0): Default visual is TrueColor [ 1162.813] (II) Loading sub module "glamoregl" [ 1162.813] (II) LoadModule: "glamoregl" [ 1162.814] (II) Loading /usr/lib/xorg/modules/libglamoregl.so [ 1162.814] (II) Module glamoregl: vendor="X.Org Foundation" [ 1162.814] compiled for 1.21.1.7, module version = 1.0.1 [ 1162.814] ABI class: X.Org ANSI C Emulation, version 0.4 [ 1163.053] (II) modeset(G0): glamor X acceleration enabled on Mali-G31 (Panfrost) [ 1163.053] (II) modeset(G0): glamor initialized [ 1163.053] (II) modeset(G0): Output Unknown19-1 has no monitor section [ 1163.053] (II) modeset(G0): EDID for output Unknown19-1 [ 1163.053] (II) modeset(G0): Printing probed modes for output Unknown19-1 [ 1163.053] (II) modeset(G0): Modeline "480x320"x60.0 9.22 480 480 480 480 320 320 320 320 (19.2 kHz eP) [ 1163.053] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0) [ 1163.053] (==) modeset(G0): DPI set to (96, 96) [ 1163.053] (II) Loading sub module "fb" [ 1163.053] (II) LoadModule: "fb" [ 1163.053] (II) Module "fb" already built-in [ 1163.053] (II) UnloadModule: "fbdev" [ 1163.053] (II) Unloading fbdev [ 1163.054] (II) UnloadSubModule: "fbdevhw" [ 1163.054] (II) Unloading fbdevhw [ 1163.102] (==) modeset(0): Backing store enabled [ 1163.102] (==) modeset(0): Silken mouse enabled [ 1163.103] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc. [ 1163.103] (==) modeset(0): DPMS enabled [ 1163.103] (II) modeset(0): [DRI2] Setup complete [ 1163.103] (II) modeset(0): [DRI2] DRI driver: sun4i-drm [ 1163.103] (II) modeset(0): [DRI2] VDPAU driver: sun4i-drm [ 1163.124] (==) modeset(G0): Backing store enabled [ 1163.124] (==) modeset(G0): Silken mouse enabled [ 1163.225] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc. [ 1163.225] (==) modeset(G0): DPMS enabled [ 1163.225] (II) modeset(G0): [DRI2] Setup complete [ 1163.225] (II) modeset(G0): [DRI2] DRI driver: zink [ 1163.225] (II) modeset(G0): [DRI2] VDPAU driver: zink [ 1163.225] (II) Initializing extension Generic Event Extension [ 1163.226] (II) Initializing extension SHAPE [ 1163.226] (II) Initializing extension MIT-SHM [ 1163.227] (II) Initializing extension XInputExtension [ 1163.227] (II) Initializing extension XTEST [ 1163.228] (II) Initializing extension BIG-REQUESTS [ 1163.228] (II) Initializing extension SYNC [ 1163.229] (II) Initializing extension XKEYBOARD [ 1163.229] (II) Initializing extension XC-MISC [ 1163.230] (II) Initializing extension SECURITY [ 1163.230] (II) Initializing extension XFIXES [ 1163.231] (II) Initializing extension RENDER [ 1163.231] (II) Initializing extension RANDR [ 1163.232] (II) Initializing extension COMPOSITE [ 1163.233] (II) Initializing extension DAMAGE [ 1163.233] (II) Initializing extension MIT-SCREEN-SAVER [ 1163.234] (II) Initializing extension DOUBLE-BUFFER [ 1163.234] (II) Initializing extension RECORD [ 1163.235] (II) Initializing extension DPMS [ 1163.235] (II) Initializing extension Present [ 1163.236] (II) Initializing extension DRI3 [ 1163.236] (II) Initializing extension X-Resource [ 1163.237] (II) Initializing extension XVideo [ 1163.237] (II) Initializing extension XVideo-MotionCompensation [ 1163.237] (II) Initializing extension SELinux [ 1163.237] (II) SELinux: Disabled on system [ 1163.237] (II) Initializing extension GLX [ 1163.475] (II) AIGLX: Loaded and initialized sun4i-drm [ 1163.476] (II) GLX: Initialized DRI2 GL provider for screen 0 [ 1163.476] (II) Initializing extension XFree86-VidModeExtension [ 1163.476] (II) Initializing extension XFree86-DGA [ 1163.477] (II) Initializing extension XFree86-DRI [ 1163.477] (II) Initializing extension DRI2 [ 1163.540] (II) modeset(G0): Damage tracking initialized [ 1163.541] (II) modeset(0): Damage tracking initialized [ 1163.673] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/input/event4) [ 1163.673] (**) ADS7846 Touchscreen: Applying InputClass "evdev touchscreen catchall" [ 1163.673] (**) ADS7846 Touchscreen: Applying InputClass "evdev touchscreen catchall" [ 1163.673] (**) ADS7846 Touchscreen: Applying InputClass "calibration" [ 1163.673] (II) LoadModule: "evdev" [ 1163.673] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so [ 1163.675] (II) Module evdev: vendor="X.Org Foundation" [ 1163.675] compiled for 1.21.1.3, module version = 2.10.6 [ 1163.675] Module class: X.Org XInput Driver [ 1163.675] ABI class: X.Org XInput driver, version 24.4 [ 1163.675] (II) Using input driver 'evdev' for 'ADS7846 Touchscreen' [ 1163.675] (**) ADS7846 Touchscreen: always reports core events [ 1163.675] (**) evdev: ADS7846 Touchscreen: Device: "/dev/input/event4" [ 1163.675] (--) evdev: ADS7846 Touchscreen: Vendor 0 Product 0x1ea6 [ 1163.675] (--) evdev: ADS7846 Touchscreen: Found absolute axes [ 1163.675] (--) evdev: ADS7846 Touchscreen: Found x and y absolute axes [ 1163.675] (--) evdev: ADS7846 Touchscreen: Found absolute touchscreen [ 1163.675] (**) Option "SwapAxes" "0" [ 1163.675] (II) evdev: ADS7846 Touchscreen: Configuring as touchscreen [ 1163.675] (**) evdev: ADS7846 Touchscreen: YAxisMapping: buttons 4 and 5 [ 1163.675] (**) evdev: ADS7846 Touchscreen: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200 [ 1163.675] (**) Option "config_info" "udev:/sys/devices/platform/soc/5011000.spi/spi_master/spi1/spi1.1/input/input4/event4" [ 1163.675] (II) XINPUT: Adding extended input device "ADS7846 Touchscreen" (type: TOUCHSCREEN, id 6) [ 1163.676] (II) evdev: ADS7846 Touchscreen: initialized for absolute axes. [ 1163.676] (**) ADS7846 Touchscreen: (accel) keeping acceleration scheme 1 [ 1163.676] (**) ADS7846 Touchscreen: (accel) acceleration profile 0 [ 1163.676] (**) ADS7846 Touchscreen: (accel) acceleration factor: 2.000 [ 1163.676] (**) ADS7846 Touchscreen: (accel) acceleration threshold: 4 [ 1163.678] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/input/mouse1) [ 1163.678] (**) ADS7846 Touchscreen: Applying InputClass "calibration" [ 1163.678] (II) No input driver specified, ignoring this device. [ 1163.678] (II) This device may have been added with another device file. [ 1163.680] (II) config/udev: Adding input device Mitsumi Electric Apple Extended USB Keyboard (/dev/input/event0) [ 1163.680] (**) Mitsumi Electric Apple Extended USB Keyboard: Applying InputClass "evdev keyboard catchall" [ 1163.681] (**) Mitsumi Electric Apple Extended USB Keyboard: Applying InputClass "evdev keyboard catchall" [ 1163.681] (II) Using input driver 'evdev' for 'Mitsumi Electric Apple Extended USB Keyboard' [ 1163.681] (**) Mitsumi Electric Apple Extended USB Keyboard: always reports core events [ 1163.681] (**) evdev: Mitsumi Electric Apple Extended USB Keyboard: Device: "/dev/input/event0" [ 1163.681] (--) evdev: Mitsumi Electric Apple Extended USB Keyboard: Vendor 0x5ac Product 0x204 [ 1163.681] (--) evdev: Mitsumi Electric Apple Extended USB Keyboard: Found keys [ 1163.681] (II) evdev: Mitsumi Electric Apple Extended USB Keyboard: Configuring as keyboard [ 1163.681] (**) Option "config_info" "udev:/sys/devices/platform/soc/5311400.usb/usb6/6-1/6-1.1/6-1.1:1.0/0003:05AC:0204.0001/input/input0/event0" [ 1163.681] (II) XINPUT: Adding extended input device "Mitsumi Electric Apple Extended USB Keyboard" (type: KEYBOARD, id 7) [ 1163.681] (**) Option "xkb_rules" "evdev" [ 1163.681] (**) Option "xkb_model" "pc105" [ 1163.681] (**) Option "xkb_layout" "us" [ 1163.684] (II) config/udev: Adding input device Mitsumi Electric Apple Extended USB Keyboard System Control (/dev/input/event1) [ 1163.684] (**) Mitsumi Electric Apple Extended USB Keyboard System Control: Applying InputClass "evdev keyboard catchall" [ 1163.684] (**) Mitsumi Electric Apple Extended USB Keyboard System Control: Applying InputClass "evdev keyboard catchall" [ 1163.684] (II) Using input driver 'evdev' for 'Mitsumi Electric Apple Extended USB Keyboard System Control' [ 1163.684] (**) Mitsumi Electric Apple Extended USB Keyboard System Control: always reports core events [ 1163.684] (**) evdev: Mitsumi Electric Apple Extended USB Keyboard System Control: Device: "/dev/input/event1" [ 1163.684] (--) evdev: Mitsumi Electric Apple Extended USB Keyboard System Control: Vendor 0x5ac Product 0x204 [ 1163.684] (--) evdev: Mitsumi Electric Apple Extended USB Keyboard System Control: Found keys [ 1163.684] (II) evdev: Mitsumi Electric Apple Extended USB Keyboard System Control: Configuring as keyboard [ 1163.685] (**) Option "config_info" "udev:/sys/devices/platform/soc/5311400.usb/usb6/6-1/6-1.1/6-1.1:1.1/0003:05AC:0204.0002/input/input1/event1" [ 1163.685] (II) XINPUT: Adding extended input device "Mitsumi Electric Apple Extended USB Keyboard System Control" (type: KEYBOARD, id 😎 [ 1163.685] (**) Option "xkb_rules" "evdev" [ 1163.685] (**) Option "xkb_model" "pc105" [ 1163.685] (**) Option "xkb_layout" "us" [ 1163.688] (II) config/udev: Adding input device Mitsumi Electric Apple Extended USB Keyboard Consumer Control (/dev/input/event2) [ 1163.688] (**) Mitsumi Electric Apple Extended USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall" [ 1163.688] (**) Mitsumi Electric Apple Extended USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall" [ 1163.688] (II) Using input driver 'evdev' for 'Mitsumi Electric Apple Extended USB Keyboard Consumer Control' [ 1163.688] (**) Mitsumi Electric Apple Extended USB Keyboard Consumer Control: always reports core events [ 1163.688] (**) evdev: Mitsumi Electric Apple Extended USB Keyboard Consumer Control: Device: "/dev/input/event2" [ 1163.688] (--) evdev: Mitsumi Electric Apple Extended USB Keyboard Consumer Control: Vendor 0x5ac Product 0x204 [ 1163.688] (--) evdev: Mitsumi Electric Apple Extended USB Keyboard Consumer Control: Found keys [ 1163.688] (II) evdev: Mitsumi Electric Apple Extended USB Keyboard Consumer Control: Configuring as keyboard [ 1163.688] (**) Option "config_info" "udev:/sys/devices/platform/soc/5311400.usb/usb6/6-1/6-1.1/6-1.1:1.1/0003:05AC:0204.0002/input/input2/event2" [ 1163.688] (II) XINPUT: Adding extended input device "Mitsumi Electric Apple Extended USB Keyboard Consumer Control" (type: KEYBOARD, id 9) [ 1163.688] (**) Option "xkb_rules" "evdev" [ 1163.688] (**) Option "xkb_model" "pc105" [ 1163.688] (**) Option "xkb_layout" "us" [ 1163.691] (II) config/udev: Adding input device PixArt USB Optical Mouse (/dev/input/event3) [ 1163.691] (**) PixArt USB Optical Mouse: Applying InputClass "evdev pointer catchall" [ 1163.691] (**) PixArt USB Optical Mouse: Applying InputClass "evdev pointer catchall" [ 1163.692] (II) Using input driver 'evdev' for 'PixArt USB Optical Mouse' [ 1163.692] (**) PixArt USB Optical Mouse: always reports core events [ 1163.692] (**) evdev: PixArt USB Optical Mouse: Device: "/dev/input/event3" [ 1163.692] (--) evdev: PixArt USB Optical Mouse: Vendor 0x93a Product 0x2510 [ 1163.692] (--) evdev: PixArt USB Optical Mouse: Found 3 mouse buttons [ 1163.692] (--) evdev: PixArt USB Optical Mouse: Found scroll wheel(s) [ 1163.692] (--) evdev: PixArt USB Optical Mouse: Found relative axes [ 1163.692] (--) evdev: PixArt USB Optical Mouse: Found x and y relative axes [ 1163.692] (II) evdev: PixArt USB Optical Mouse: Configuring as mouse [ 1163.692] (II) evdev: PixArt USB Optical Mouse: Adding scrollwheel support [ 1163.692] (**) evdev: PixArt USB Optical Mouse: YAxisMapping: buttons 4 and 5 [ 1163.692] (**) evdev: PixArt USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200 [ 1163.692] (**) Option "config_info" "udev:/sys/devices/platform/soc/5311400.usb/usb6/6-1/6-1.2/6-1.2:1.0/0003:093A:2510.0003/input/input3/event3" [ 1163.692] (II) XINPUT: Adding extended input device "PixArt USB Optical Mouse" (type: MOUSE, id 10) [ 1163.692] (II) evdev: PixArt USB Optical Mouse: initialized for relative axes. [ 1163.693] (**) PixArt USB Optical Mouse: (accel) keeping acceleration scheme 1 [ 1163.693] (**) PixArt USB Optical Mouse: (accel) acceleration profile 0 [ 1163.693] (**) PixArt USB Optical Mouse: (accel) acceleration factor: 2.000 [ 1163.693] (**) PixArt USB Optical Mouse: (accel) acceleration threshold: 4 [ 1163.695] (II) config/udev: Adding input device PixArt USB Optical Mouse (/dev/input/mouse0) [ 1163.695] (II) No input driver specified, ignoring this device. [ 1163.695] (II) This device may have been added with another device file. [ 1166.523] (II) evdev: PixArt USB Optical Mouse: Close [ 1166.523] (II) UnloadModule: "evdev" [ 1166.523] (II) evdev: Mitsumi Electric Apple Extended USB Keyboard Consumer Control: Close [ 1166.524] (II) UnloadModule: "evdev" [ 1166.524] (II) evdev: Mitsumi Electric Apple Extended USB Keyboard System Control: Close [ 1166.524] (II) UnloadModule: "evdev" [ 1166.524] (II) evdev: Mitsumi Electric Apple Extended USB Keyboard: Close [ 1166.524] (II) UnloadModule: "evdev" [ 1166.524] (II) evdev: ADS7846 Touchscreen: Close [ 1166.525] (II) UnloadModule: "evdev" [ 1167.522] (II) Server terminated successfully (0). Closing log file. dmesg|grep MESA shows nothing. Probably here is the solution https://github.com/agherzan/meta-raspberrypi/issues/1389 rebuilding mesa with some extra dependencies Bookworm containg mesa 22.3.6 right now, but Trixie contains mesa 25.0.5 I tried the same in Trixie and Sid, but still get the same error: not able to load panel-mipi-dbi_dri.so I have a newly built armbian OS with kernel 6.15.x... I will try it later today. Edited July 9, 2025 by robertoj 0 Quote
g00n Posted July 24, 2025 Posted July 24, 2025 orange pi zero 3 image hasn't received an update since may, maybe that's why 0 Quote
SteeMan Posted July 24, 2025 Posted July 24, 2025 1 hour ago, g00n said: orange pi zero 3 image hasn't received an update since may Stable images are produced every three months. Development builds are produced at least weekly depending on the support status. 0 Quote
robertoj Posted July 24, 2025 Author Posted July 24, 2025 I have seen other threads where they recompile mesa to get an updated so module for X11, related to LCD panels and DRM. I haven't had time for that yet. 0 Quote
